V3 Smart Effector Defect
Smart effector for delta printers
482
    starworts
    I just picked up my second smart effector (first was a V2 and still working fine). Thought it would be handy to have a second one. The V3 isn't triggering with taps from a finger or even a light tap of some needle nose. I adjusted sensitivity from low to high hoping to see a change but nothing has changed. It drives into the bed hard. I hooked up my old one to see if something in the setup has changed (bad/loose wiring), works perfectly fine. Everything is rigid nothing loose. when giving it some higher pressure it seems to trigger, green led lights up with no errors (two blinks). Everything else on the board seems to work, fans, heater thermocouple.
    I took it under a scope and started really looking at the board. turns out there was a solder bridge between two pins of the Attiny. I'm guessing something got through QC from the board house. After removing the solder I looked into the board files to see what the possible damage could be. Turns out it was shorting the 2.8V rail to ADC1 net. I removed the bridge and ran it.
    ;Settings
    M558 P8 R0.4 F1200 C"zprobe.in+zprobe.mod" H5 A3 S0.15 T10000;
    M672 S131:131
    The output after a few tests...
    measured height (mm)
    0.437
    0.438
    0.442
    0.430
    0.425
    0.439
    0.430
    0.418
    0.429
    0.425
    0.438
    0.438
    this gave an average 0f 0.432417mm
    a min of 0.418mm
    a max of 0.442mm
    which gives a delta of 0.024mm
    I can't remember the tooth count on my steppers but I am using 0.9 degree steppers.
    does this sound about right? I'm wondering if that short has damaged something to where the noise floor has become higher.
    thanks for any help!
    undefined 1 Reply Last reply 20 May 2022, 06:53 Reply Quote 0
      dc42 administrators @starworts
      @starworts I'm sorry you received a faulty Smart Effector, and I'm glad you got it working. I'm very surprised that the board passed testing.
      A short between +2.8V and ADC1 would not cause any damage.
      undefined 1 Reply Last reply 21 May 2022, 22:41 Reply Quote 1
        starworts @dc42
        @dc42 So I can't for the life of me get this thing to read consistently and within any sort of reasonable tolerance. This is the output of ~25 G30 S-1 up 5mm as the commissioning tutorial runs just repeated with a one second delay between movements. Seems all over the place. The sensitivity settings are at the bottom to keep track of what tests I'm running.
        5/21/2022, 3:35:51 PM Stopped at height -0.370 mm
        5/21/2022, 3:35:48 PM Stopped at height -0.460 mm
        5/21/2022, 3:35:45 PM Stopped at height -0.599 mm
        5/21/2022, 3:35:42 PM Stopped at height -0.688 mm
        5/21/2022, 3:35:38 PM Stopped at height -0.451 mm
        5/21/2022, 3:35:36 PM Stopped at height -0.641 mm
        5/21/2022, 3:35:32 PM Stopped at height -0.688 mm
        5/21/2022, 3:35:29 PM Stopped at height -0.634 mm
        5/21/2022, 3:35:26 PM Stopped at height -0.641 mm
        5/21/2022, 3:35:23 PM Stopped at height -0.671 mm
        5/21/2022, 3:35:20 PM Stopped at height -0.630 mm
        5/21/2022, 3:35:17 PM Stopped at height -0.474 mm
        5/21/2022, 3:35:14 PM Stopped at height -0.541 mm
        5/21/2022, 3:35:11 PM Stopped at height -0.623 mm
        5/21/2022, 3:35:08 PM Stopped at height -0.670 mm
        5/21/2022, 3:35:05 PM Stopped at height -0.715 mm
        5/21/2022, 3:35:02 PM Stopped at height -0.617 mm
        5/21/2022, 3:34:58 PM Stopped at height -0.677 mm
        5/21/2022, 3:34:56 PM Stopped at height -0.676 mm
        5/21/2022, 3:34:52 PM Stopped at height -0.632 mm
        5/21/2022, 3:34:49 PM Stopped at height -0.640 mm
        5/21/2022, 3:34:46 PM Stopped at height -0.814 mm
        5/21/2022, 3:34:43 PM Stopped at height -0.455 mm
        5/21/2022, 3:34:40 PM Stopped at height -0.374 mm
        5/21/2022, 3:34:37 PM M98 P"0:/macros/Z_Tuning/8_Repeatability"
        Stopped at height -0.572 mm
        5/21/2022, 3:34:31 PM M672 S105:20:235
        5/21/2022, 3:34:30 PM M558 P8 R0.4 F1000 C"zprobe.in+zprobe.mod" H5 A3 S0.15 T10000;
        undefined 1 Reply Last reply 22 May 2022, 09:12 Reply Quote 0
          @starworts I am using a Smart Effector on my delta. I did have to make some changes to my previous setup using a version 2 effector to get it working well. In particular, I increased the sensitivity. I can't remember the exact value I used, I think it was about 20.
          When using high sensitivities (i.e. lower numbers), there are a couple of things you can do to help them work reliably:
          1. Remove capacitor C8 from the Smart Effector. This reduces the internal noise.
          2. Make sure that the hot end fan wires run parallel (so either use figure-of-8 cable, or twist the two wired around each other) and not close to the electronics on the effector. The fan itself should be far away from the electronics.
          undefined 1 Reply Last reply 23 May 2022, 16:23 Reply Quote 0
            starworts @dc42
            @dc42 during
            Fan lines are all far away from the electronics. Also currently not running fans during this testing due to any possibility of EMF issues. I removed C8 and am still getting a pretty big spread. I ran sensitivities from 10 to 30 (30 seems to not always trigger and crash).
            5/23/2022, 9:21:44 AM Stopped at height 0.303 mm
            5/23/2022, 9:21:41 AM Stopped at height 0.336 mm
            5/23/2022, 9:21:38 AM Stopped at height 0.413 mm
            5/23/2022, 9:21:35 AM Stopped at height 0.289 mm
            5/23/2022, 9:21:32 AM Stopped at height 0.297 mm
            5/23/2022, 9:21:29 AM Stopped at height 0.443 mm
            5/23/2022, 9:21:06 AM Stopped at height 0.412 mm
            5/23/2022, 9:21:03 AM Stopped at height 0.330 mm
            5/23/2022, 9:21:00 AM Stopped at height 0.261 mm
            5/23/2022, 9:20:57 AM Stopped at height 0.447 mm
            5/23/2022, 9:20:54 AM Stopped at height 0.483 mm
            5/23/2022, 9:20:51 AM Stopped at height 0.205 mm
            5/23/2022, 9:20:48 AM Stopped at height 0.311 mm
            5/23/2022, 9:20:45 AM Stopped at height 0.425 mm
            5/23/2022, 9:20:42 AM Stopped at height 0.422 mm
            5/23/2022, 9:20:39 AM Stopped at height 0.209 mm
            5/23/2022, 9:20:37 AM Stopped at height 0.308 mm
            5/23/2022, 9:20:34 AM M98 P"0:/macros/Z_Tuning/8_Repeatability"
            Stopped at height 0.449 mm
            5/23/2022, 9:20:03 AM M672 S105:20:235
            undefined 1 Reply Last reply 23 May 2022, 16:38 Reply Quote 0
              @starworts what M558 command are you using?
              undefined 1 Reply Last reply 23 May 2022, 21:44 Reply Quote 0
                starworts @dc42
                undefined 1 Reply Last reply 25 May 2022, 09:42 Reply Quote 0
                  @starworts that looks OK to me.
                  Two suggestions:
                  1. Here is a macro do probe a point on the bed repeatedly and report the mean and standard deviation. Please try it and see what results you get. You should send M558 A1 first so that it doesn't do multiple probing. You can change the X and Y coordinates if you want. I usually get standard deviation of 0.005 or better, except that if filament has oozed form the nozzle then the first probe throws it out.
                  2. To check whether any fans or heaters are causing interference, you can run the macro with the hot end cold, and also with the heater and hot end cooling fan running. The print cooling fan should be off.
                  var x=0
                  var y=0
                  var numProbes=20
                  while iterations < var.numProbes-1
                  G30 P{iterations} X{var.x} Y{var.y} Z-9999
                  G30 P{var.numProbes-1} X{var.x} Y{var.y} Z-9999 S-1
                  undefined 1 Reply Last reply 25 May 2022, 15:36 Reply Quote 0
                    starworts @dc42
                    Hot end cold
                    5/25/2022, 8:31:19 AM Error: Probe was not triggered during probing move
                    G32 bed probe heights: 0.570 0.441 0.240 0.430 0.492 0.213 0.223 0.329 -1.567 -2.932 -2.856 -2.898 probing failed probing failed probing failed -2.830 -2.969 -2.959 -2.827 -2.841, mean -1.087, deviation from mean 1.530
                    5/25/2022, 8:31:14 AM Error: Probe was not triggered during probing move
                    5/25/2022, 8:31:12 AM Error: Probe was not triggered during probing move
                    5/25/2022, 8:31:11 AM M98 P"0:/macros/dc42"
                    5/25/2022, 8:30:49 AM M558 A1
                    Hot end at 205C and bed at 60C No print cooling fans
                    5/25/2022, 8:35:45 AM M98 P"0:/macros/dc42"
                    G32 bed probe heights: 0.297 0.298 0.280 0.356 0.182 0.294 0.473 0.204 0.374 0.279 0.355 0.146 0.179 0.205 0.443 0.253 0.366 0.359 0.356 0.089, mean 0.289, deviation from mean 0.097
                    5/25/2022, 8:35:12 AM M558 A1```
                    undefined 1 Reply Last reply 25 May 2022, 16:42 Reply Quote 0
                      @starworts that looks very wrong. What sensitivity have you set? With the nozzle cold, if you tap the bottom of the nozzle upwards, does the green LED flash?
                      undefined 1 Reply Last reply 25 May 2022, 17:08 Reply Quote 0
                        starworts @dc42
                        Sensitivity
                        M672 S105:20:235
                        It does not flash when tapping the nozzle
                        undefined 1 Reply Last reply 25 May 2022, 17:10 Reply Quote 0
                          @starworts please submit a warranty claim to warranty@duet3d.com, linking to this post in your email. I'm sorry it has taken a while to sort out.
                          undefined 1 Reply Last reply 25 May 2022, 17:19 Reply Quote 0
                            starworts @dc42
                            No need for apologies! I am very happy with responses and working with me to figure out what was going on.
                            3 out of 13
