    Issues after updating firmware for first time
    Firmware installation
    293
    • OSCORPundefined
      OSCORP
      Hello!
      I haven't updated anything since I bought the printer back in early 2020 and now that I've updated all the way to the latest version of DuetWifi it's throwing all kinds of errors including not detecting my hotend or bed. Please if someone has any clue how to fix this that would be awesome. Thank you. Attached is my diagnostic. Let me know if additional info is needed. console.txt
      • OSCORPundefined
        OSCORP
        Printer is a Troodon CoreXY
          jay_s_uk @OSCORP
          @oscorp did you update from RRF2 to RRF3? Your config needs updating for RRF3.
          Theres a config available here https://forum.duet3d.com/topic/16997/formbot-troodon-rrf-3-1-1-update?_=1653141263734
          OSCORPundefined 1 Reply Last reply Reply Quote 1
          • OSCORPundefined
            OSCORP @jay_s_uk
            @jay_s_uk
            Hi Jay
            So I just input this config file and it's at least picking up the bed and hotend now! But it's giving me a Fan number 3 error code. Also I see this file is configured for the 300x300x400 troodon and I have to 400x400x500 one so not sure how much would have to be changed about that.
            OSCORPundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
            • OSCORPundefined
              OSCORP @OSCORP
              @oscorp I'm also on the absolute latest version 3.4 for Reprap
              OSCORPundefined 1 Reply Last reply Reply Quote 0
                jay_s_uk @OSCORP
                @oscorp you'd have to change the M208 in config. and you'd have to adjust the M557 for a larger bed. Whats the error with the fan?
                Ideally though, you should try and understand what each line means rather than blindly copying someone elses config.
                • OSCORPundefined
                  OSCORP @OSCORP
                  @oscorp and the printer screen is stuck on connecting, even after trying to swap baud rate so I can only control it through the Wi-Fi connection
                  • OSCORPundefined
                    OSCORP @jay_s_uk
                    @jay_s_uk
                    This is the fan error
                    M98 P"0:/macros/Preheat/preheat_PLA"
                    Error: Fan number 3 not found
                    Ok yea i'll have to work on swapping over everything to adjust for my bed size, thank you so much. Any ideas as to why the print screen is stuck on connecting now though?
                      jay_s_uk @OSCORP
                      @oscorp make sure your config has M575 P1 B57600 S1 in.
                      Theres no fan3 defined so thats why you get that error so you'll have to check the old config and see where it was plugged into etc and add it to the config.
                      • OSCORPundefined
                        OSCORP @jay_s_uk
                        @jay_s_uk
                        Ah perfect yea that fixed the issue with the screen stuck on connecting.
                        I have to head to bed for work tomorrow but I'm very glad to have most issues fixed.
                        Thanks a ton Jay, i'll be sure to ask you for any other help I need.
