DWC 3.4 reverts to 3.2.2 after shutdown
Duet Web Control
    man_mar
    As per title, I have this weird issue that I can't figure out.
    I'm in SBC mode, I upgraded the firmware to the 3.4 release, but I noticed the DWC was still 3.2.2.
    So I proceeded to upgrade the DWC manually uploading the .zip package using the "Upload System Files" in "System". All went smooth, I can see it upgraded to DWC 3.4.
    I do some stuff, then shutdown the machine, turn it back on and I noticed the old UI. I check and it's DWC 3.2.2. What the hell?! I tried several times the same procedure, but no luck.
    I then tried to upgrade using PuTTY, sudo apt-upgrade/update, it does some stuff, but no DWC 3.4.
    I tried also manually deleting the "www" folder in the boot partition of the SD card and replacing it with the 3.4 version: at first I get the DWC3.4, but at the next start up I get DWC3.2.2.
    As last resort I tried formatting the SD card and did a fresh installation with the latest .img, but I still have DWC 3.2.2.
    The only way I'm able to get DWC3.4 is to upload the "DuetWebControl-SD.zip" every time I turn on the machine. But then again if I turn off the machine and turn on I get DWC 3.2.2.
    TBH it wouldn't be that big of a deal if the "Height Map" didn't tell me "Invalid Height Map", and it's a bit annoying 😞
    So...I'm sure I missed something but I can't figure out what.
    undefined 1 Reply Last reply 3 Jun 2022, 09:18 Reply Quote 0
      jay_s_uk @man_mar
      @man_mar connect to the SBC via SSH and send sudo apt update && sudo apt upgrade -y
      DO NOT update RRF manually using the interface when in SBC mode
      undefined 1 Reply Last reply 6 Jun 2022, 10:10 Reply Quote 0
        man_mar @jay_s_uk
        @jay_s_uk said in DWC 3.4 reverts to 3.2.2 after shutdown:
        well...this is driving me insane.
        I took the microSD card, formatted, and followed the instructions I found here ( https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup ).
        Connected via PuTTY and then used sudo apt-get update and then sudo apt-get upgrade, process went apparently well. When I use my browser and I go to "duet3.local", it connects to the DWC but I can already see that it's the old 3.2.2.
        At least the firmware is updated:
        Board: Duet 3 MB6HC (MB6HC)
        DSF Version: 3.4.1
        Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.1 (2022-06-01)
        But the DWC:
        Duet Web Control 3.2.2
        GitHub
        Web Interface developed by Christian Hammacher for Duet3D.
        Licensed under the terms of the GNU General Public License v3
        How the hell am I supposed to update the DWC in order for it to NOT go back to the 3.2.2?
        undefined 1 Reply Last reply 6 Jun 2022, 10:11 Reply Quote 0
          jay_s_uk @man_mar
          @man_mar then it sounds like a caching issue with your browser.
          clear the cache and try connecting again. DSF is the right version
          undefined 1 Reply Last reply 6 Jun 2022, 10:15 Reply Quote 1
            man_mar @jay_s_uk
            @jay_s_uk
            I'll be damned. I tried with an "new incognito window" and it works. So it's obviously a caching issue, as you predicted.
            Thank you very much for the help.
            • undefined Phaedrux marked this topic as a question 6 Jun 2022, 18:50
            • undefined Phaedrux has marked this topic as solved 6 Jun 2022, 18:50
            1 out of 5
