    Microswitch for Z-probing
    2.9k
    • number40fanundefined
      number40fan
      I did some editing, so make sure you catch it all. I have successfully use a micro switch for Z probing using P4 and E0 and it worked great. Bad thing is I had to remove it after each use. I then tried sandwiching a couple between the effector and hotend and got great probing results, but the hotend wobbled just enough while printing to make it not worth it. Went back to using the IR probe which worked great, but I had some thoughts on the switches.
      • DocTruckerundefined
        DocTrucker
        Good to hear. The main application for this is the home project where I've cut out a dead Up Plus 2 driver card and replaced it with a Duetwifi. This has a clip on micro switch for bed level correction. It also has a little assembly where the nozzle pushes a piece of spring steel across some contacts to detect bed level, and a high end end stop. The end stop was the only device permanently connected, the others relied on the user moving a jack lead.
          number40fan
          That should work out good then. Don't mind my bed.g that I posted, it is for a Delta, but it should give you the idea of how to set up the probing area for your printer.
            DocTrucker
            Ok, been a while since I was able to do some work on this but I thing things are nearly sorted. This is a board swap on a Up Plus 2 printer that comes with a nozzle height detection switch on the platform and a microswitch that is used for bed level correction.
            Homing runs on the end of axis limit switches.
            The bed.g is as follows:
            M561
            ; Use a normally open (I1) switch connected to E1 limit (P6).
            ; Probe speed of 500mm/min and travel between points of 6000mm/min
            M558 P6 X0 Y0 Z1 H5 I1 F500 T6000
            ; Set up the offsets for the switch.
            G31 X0 Y10 Z18.1
            ; Four clockwise probe points and centre.
            G30 P0 X10 Y10 Z-99999
            G30 P1 X41.25 Y10 Z-99999
            G30 P2 X72.5 Y10 Z-99999
            G30 P3 X103.75 Y10 Z-99999
            G30 P4 X72.5 Y63.75 Z-99999 S0
            ; Move to the head.
            G1 Z20 F6000
            I've a macro that I run after that sets the zero level by touching the head on the platform switch as follows:
            G1 X0 Y63.75 Z10 F6000
            ; Use a normally open (I1) switch connected to E0 limit (P4).
            ; Probe speed of 500mm/min and travel between points of 2000mm/min
            M558 P4 I1 X0 Y0 Z1 F500 T2000 H30
            G31 X0 Y0 Z0
            G30
            G92 Z0
            G1 X72.5 Y63.75 Z80 F6000
            So my start up procedure for the user is:
            G28 to home all axis
            Fit the bed level microswitch
            G32 to run bed level compensation
            Remove the bed level microswitch
            M98 P/macros/NozzleHeight
            How do you add more points to the bed level correction for averaging?
            Edit: thought the -99999 was a dive height on the G30. It's not. Goes screwy with z-20!
            Edit2 Needed a G92 Z0 in the nozzle height macro.
              I don't understand why you needed a G92 Z0 command in your macro. A successful G30 command with no other parameters will set the Z height to the configured trigger height, which you have set in the preceding command to zero.
              You are using the old 5-point bed compensation scheme. This has been superseded by mesh bed compensation (G29).
                DocTrucker
                After the G30 command the web control was reporting a Z position of 0.52mm. I'll have another look this evening but that is why I added the reset to 0.
                I'll read up on the G29. I thought this was for correcting for an uneven beds? If so how does it deal with a wonky bed. Does it remap the head path to move relative to the bed surface then gradually move back to moves parrallel to the x-y plane? In other words if I printed a solid block would the final surface match the debiations detected by the G29 process?
                If the G32 or G29 does detect a tilt on the bed plane does it realign the z-axis to be equal to normal of the tilted bed, or keep the centre of each layer in the same position relative to the machine's x/y axis?
                Feel free to answer with a webpage for further reading!
                  DocTrucker
                  I've repeated the tests and not seen the same issue that led me to believe I needed the z=0 current position reset, Not sure what was going on but I can't repeat that. Other questions about the build platform normal and whether the layers gradually corret from a wonky bed still stand.
                    See https://duet3d.com/wiki/G-code#M376:_Set_bed_compensation_taper.
                      DocTrucker
                      Thanks, I'll make sure that is in my configuration file.
                      Is that being applied to both correction for unevenness and z-axis to build surface normal correction? Is the axis to normal correction corrected for by rotating the whole dataset or a skew where only the z-component gets altered?
                      Does the build simulation warn if build surface normal, buid surface unevenness, or the octagonal correction shift data out of the buildable volume? Bit of a delay to the build process but it would appear advisable to run the simulation after G32 if these warnings are presented.
                      Edit: Strikes added because found bed mesh correction is applied to z only.
                        DocTrucker
                        The wiki would appear to suggest the mesh bed compensation is a correction to the nozzle z-position only.
                        This bit concerns me though: "On a Cartesian printer, you can use either mesh levelling (G29) or G30/G32 probing, not both."
                        Does this mean that I can't run a single G30 to set the z=0 plane after G29? If the G30 resets the height map can I run g29, then g30, then g29 S1 to reload the height map? I appreciate hardware changes would simplify this but that is not an option at this juncture.
                        For other readers here is the wiki page: https://duet3d.com/wiki/Using_mesh_bed_compensation
                        Edit: Lack of sleep, but questions self answered! Strikes added.
                          DocTrucker
                          This is a good read through for others learning bed mesh compensation:
                          https://www.duet3d.com/forum/thread.php?id=499&p=1
                          I understand now why G30 and G29 don't play well together. I need my nozzle height macro to define an offset rather than reset the global position. I need to read up on the macros and gcode a bit more.
                            DocTrucker
                            Here is a video of the two switches in action: https://m.youtube.com/watch?v=kpatyPvD5oU
                            I was hoping to avoid the need for the user to read and write gcode strings but I think the following is the best procedure:
                            (user)
                            Load bed level switch.
                            (macro1)
                            Home machine
                            Move to over nozzle height switch and run g30 to reset on bed level switch trigger.
                            Run g29
                            (user)
                            Unload bed level switch
                            Connect nozzle height switch.
                            (macro2)
                            Move to over nozzle height switch and run g30 s-1 to move until nozzle height swith is triggered
                            (user)
                            Use value from m114 to set tool z offset.
                            Edit: added user/macro sections for clarity.
                              DocTrucker
                              Macro - init1
                              M80
                              M561
                              G28
                              G31 X0 Y0 Z0
                              G1 X0 Y53.75 Z25 F6000
                              G30
                              G1 Z15
                              G31 X0 Y10 Z0
                              G29
                              Macro - init2
                              G1 X0 Y63.75 Z-10 F6000
                              M558 P4 I1 X0 Y0 Z1 F50 T2000 H30
                              G31 X0 Y0 Z0
                              G30 S-1
                              User tool offset (applying -1 * value reported to console eg: "Stopped at height -17.587 mm")
                              G10 P0 X0 Y0 Z-17.587
                              Ok, redoing the full G29 each time seems a little extreme but the build surface is removed for each build and isn't extremely rigid. Besides the build surface heater is underpowered and it takes over 15 min to reach temperature, so the time cost of the g29 doesn't seem too bad!
