    Brake motors 1XD
    Using Duet Controllers
    649
    • 3Dreamundefined
      3Dream
      Good morning everyone,
      use of duet 3 + 1XD to drive closed loop stepper motors.
      On the Z I mount 4 motors of this type, but with brakes.
      Sometimes (not always) it happens to me that by doing the Home of Z the engine starts before the brake releases, sending the engine into alarm.
      I would need a slight brake release delay before the motors start.
      Can you tell me if it is possible? I did not find anything reading.
      Thanks to everyone and have a nice day
      David
        dc42 administrators @3Dream
        @3dream the easiest way would be to use M17 Z followed by a short G4 delay command in your homing file, before the homing move.
        3Dreamundefined 2 Replies Last reply Reply Quote 1
        • 3Dreamundefined
          3Dream @dc42
          a thousand thanks
          very kind as always
          • 3Dreamundefined
            3Dream @dc42
            Good morning DC42,
            even after inserting home Z and home all, M17 (not specific Z) and G4 P800 in the file, sometimes (not always) only 2 or 3 Z motors start. I switch the machine off and on again and everything works correctly. Can you give me some other solution to this problem please? Thank you
              @3dream do you have a G4 delay call near the start of config.g, earlier than any commands that refer to devices on expansion boards such as the M569.7 commands used to configure the brakes?
              3Dreamundefined 2 Replies Last reply Reply Quote 0
              • 3Dreamundefined
                3Dream @dc42
                I put G4 S2 as the first line in config.g
                • 3Dreamundefined
                  3Dream @dc42
                  Perhaps I have not explained myself well, I mean that in the config.g there is already the G4 command in the first line. Maybe I need to insert it just before M569.7? or even before M569?
                  Thanks
                  G4 S2; Pausa per avvio 1XD
                  G21; Unit millimetri
                  G90; Posizioni assolute
                  M83; Estrusore posizione relativa
                  ;Impostazioni rete
                  M550 P3Dream 1300 HYBRID ; Nome macchina
                  M552 P192.168.44.30
                  M554 P192.168.44.10
                  M553 P255.255.255.0
                  M552 S1
                  M586 P0 S1
                  M586 P1 S0
                  M586 P2 S0
                  M669 K0
                  ;Impostazione motori
                  M569 P40.0 R0 S1 T5:5:5:5; Senso rotazione motori Z0 Ant DX
                  M569 P41.0 R0 S1 T5:5:5:5; Senso rotazione motori Z1 Ant SX
                  M569 P42.0 R0 S1 T5:5:5:5; Senso rotazione motori Z2 Post SX
                  M569 P43.0 R0 S1 T5:5:5:5; Senso rotazione motori Z3 Post DX
                  M569 P44.0 R0 S0 T5:5:5:5; Senso rotazione motori X
                  M569 P45.0 R0 S1 T3:3:5:0; Senso rotazione motori E Antiorario visto da alto
                  M569 P46.0 R0 S1 T5:5:5:5; Senso rotazione motori Y0 Ant SX
                  M569 P47.0 R0 S1 T5:5:5:5; Senso rotazione motori Y1 Ant DX
                  M569.7 P40.0 C"out1";Freno Z0
                  M569.7 P41.0 C"out1";Freno Z1
                  M569.7 P42.0 C"out1";Freno Z2
                  M569.7 P43.0 C"out1";Freno Z3
                    G4 S2 at the start of config.g should be enough, but perhaps try increasing that to G4 S4 to give it another couple seconds just in case it's a bit slower.
                    • 3Dreamundefined
                      3Dream @Phaedrux
                      @phaedrux
                      ok, I'll try thanks
                      • 3Dreamundefined
                        3Dream @Phaedrux
                        @phaedrux
                        Good morning,
                        even after inserting a 4 second pause the problem persists.
                        It would seem that the problem is always at the first start in the morning where 1 or 2 Z motors don't want to go.
                        I switch the machine off and on again several times and the problem disappears. The problem occurs only if the machine remains off for a few hours. Do you have any other ideas please?
                        3Dreamundefined 1 Reply Last reply Reply Quote 0
                        • 3Dreamundefined
                          3Dream @3Dream
                          @3dream said in Brake motors 1XD:
                          @phaedrux
                          Good morning,
                          config.g
                          G4 S4; Pausa per avvio 1XD
                          ;Impostazioni rete
                          M552 P192.168.44.30
                          M554 P192.168.44.10
                          M553 P255.255.255.0
                          M552 S1
                          M586 P0 S1
                          M586 P1 S0
                          M586 P2 S0
                          M669 K0
                          M584 X44.0 Y46.0:47.0 Z40.0:41.0:42.0:43.0 E45.0 P3; Assegnazione motori
                          M92  X400 Y400:400 Z1280:1280:1280:1280 E224.6; Step giro motori
                          M566 X500 Y500:500 Z40:40:40:40 E300; Jerk motori
                          M203 X5000 Y5000:5000 Z600:600:600:600 E9000; Velocita motori
                          M201 X500 Y500:500 Z40:40:40:40 E2000; Accelerazione motori
                          ;M572 D0 S0.05
                          ;Corse macchina
                          M208 X0 Y0 Z0 S1; Posizione corsa minima
                          M208 X1300 Y1290 Z1030.3 S0; Posizione corsa massima era 1031.5
                          ;Finecorsa
                          M574 X1 S1 P"io2.in"
                          M574 Y1 S1 P"46.io0.in+47.io0.in" ; doppio finecorsa microswitch su assi Y SU 1XD 46.io0.in
                          M574 Z2 S1 P"!40.io0.in+!41.io0.in+!42.io0.in+!43.io0.in" ; quadruplo finecorsa proximity su assi Z SU 1XD
                          ;Posizione proximity e bed levelling
                          M558 P8 C"^!io8.in" H8 R1 F120 T8000
                          G31 P600 X-28 Y60 Z0.5; era Z-0.8 con pellicola PP
                          M557 X100:1200 Y100:1200 S550:550
                          ;limiti temperatura estrusione
                          M302 P0 S150 R150
                          ;Piano riscaldato
                          M308 S0 P"temp_0" Y"thermistor" A"Piano" T100000 B3950
                          M950 H0 C"out0" T0
                          M143 H0 S120
                          M307 H0 B1 S1.00
                          M140 H0
                          M570 H0 P1000000 T1000000
                          ;Estrusore Alto
                          M308 S1 F60 P"spi.cs0" Y"rtd-max31865" A"Alto"   ; definizione
                          M950 H1 C"out1" T1 Q100                   ; heater 1 uses the high current output pin sensor 1
                          M143 H1 S400                              ; set temperature limit for heater 1 to 300C
                          M570 H1 P1000 T1000
                          M307 H1 S0.50
                          ;Estrusore Centro
                          M308 S2 F60 P"spi.cs1" Y"rtd-max31865" A"Centro"  ; define E0 temperature sensor
                          M950 H2 C"out2" T2 Q100                   ; heater 1 uses the high current output pin sensor 1
                          M143 H2 S400                              ; set temperature limit for heater 1 to 300C
                          M570 H2 P1000 T1000
                          M307 H2 S0.50
                          ;Estrusore Ugello
                          M308 S3 F60 P"spi.cs3" Y"rtd-max31865" A"Nozzle"  ; define E0 temperature sensor
                          M950 H3 C"out3" T3 Q100                   ; heater 1 uses the high current output pin sensor 1
                          M143 H3 S400                              ; set temperature limit for heater 1 to 300C
                          M570 H3 P1000 T1000
                          M307 H3 S0.50
                          ;Camera
                          M308 S4 P"temp_1" Y"thermistor" A"Camera" T100000 B3950
                          Attivazioni varie
                          M950 P8 C"43.out0" ; Creazione GPIO pin 8 su 1XD Can 43 out0 alimentazione proximity finecors Z3
                          M42 P8 S1 ; abilita uscita 24V proximity Z3
                          M950 P9 C"42.out0" ; Creazione GPIO pin 9 su 1XD Can 42 out0 alimentazione proximity finecors Z2
                          M42 P9 S1; abilita uscita 24V proximity Z2
                          M950 P10 C"41.out0" ; Creazione GPIO pin 10 su 1XD Can 41 out0 alimentazione proximity finecors Z1
                          M42 P10 S1; abilita uscita 24V proximity Z1
                          M950 P11 C"40.out0" ; Creazione GPIO pin 11 su 1XD Can 40 out0 alimentazione proximity finecors Z0
                          M42 P11 S1; abilita uscita 24V proximity Z0
                          M950 P12 C"45.out0" ; Creazione GPIO pin 12 su 1XD Can 45 out0 alimentazione sensore granulo
                          M42 P12 S1; abilita uscita 24V sensore granulo
                          M950 P13 C"45.out1" ; Creazione GPIO pin 13 su 1XD Can 45 out 1 alimentazione valvola exair granulo tramoggia
                          M42 P13 S1; abilita uscita 24V sensore granulo tramoggia
                          ;M950 J7 C"45.io0.in" ; Creazione input Pin7 su 1XD Can 45 per sensore granulo
                          M591 D0 P2 C"45.io0.in" S1
                          ;M950 J14 C"^io0.in" ; Creazione input Pin 14 sensori porte
                          ;M581 P14 S1 T6 R1 ; invoca trigger 6 apertura porte
                          ;Ventole
                          M950 F0 C"out7" Q250
                          M106 P0 S0 H-1
                          M563 P0 D0 H1:2:3 S"Pulsar"        	 ; define tool 0
                          G10 P0 X0 Y0 Z0
                          G10 P0 S0 R0            ; set tool 0 axis offsets
                          ;Autopoweroff
                          ;M911 S23 P"G91 M83 G1 Z3 E-2 F1000"
                          M106 S0
                          M671 X1450:-150:-150:1450 Y-150:-150:1450:1450 S5
                          M501
                            Phaedrux Moderator @3Dream
                            M92 X400 Y400:400 Z1280:1280:1280:1280 E224.6; Step giro motori M566 X500 Y500:500 Z40:40:40:40 E300; Jerk motori M203 X5000 Y5000:5000 Z600:600:600:600 E9000; Velocita motori M201 X500 Y500:500 Z40:40:40:40 E2000; Accelerazione motori
                            These are incorrect. Only multiple extruder motors require multiple values. If the axis is made up of multiple motors, there only needs to be a single value for the axis, not for each motor. So remove the duplicate Y and Z values. I don't know if this would cause an issue like what you are seeing, but it isn't helping.
                            You can also send M98 P"config.g" to get a syntax check of your config.g file.
                            It may also help to see the results of M122 and M122 B# where # is the can address of your expansion boards.
