Baby stepping from panel due.
Can you do this? Only seen where you can move, but no baby stepping like web interface.
What version are you running on the Panel I can babystep with no issues
I thought latest as I updated it all just a few weeks ago, but I'll double check.
The baby stepping option is displayed on the Print page when you are printing a file.
Donald had the right of it, my version was 1.15c, upgraded to 1.17, and shows up as expected, so dc42, great work. Thanks both for quick reply
How would one change babystepping from panel due to 0.01 instead of 0.05?
I intend to reduce it to 0.02 in the next beta. In the longer term I will make it configurable.
0.01? Are you saying you need 10 microns adjustment resolution on your first layer? Maybe if your first layer is 50 microns thick⦠I can see the change of 50 microns per babystep with the current setup at 0.3mm first layer height but much less and you won't know if its getting better or not unless you press it 3-4 times, in which case might as well leave it set to 50 microns.
Just my twopence worth. If its configurable I'm good with that.
