I could use some help
682
63.5k
    fcwilt @A Former User
    @mac said in I could use some help:
    @fcwilt I haven't even started measuring again. I did turn the printer off so I could move the bed back to the end-stop. I'd like to use that 0-point to measure from. But getting to it is brutal!
    Understood.
    And it's true that the longer move you measure the less slight inaccuracies in the measurement will affect the results.
    One good measurement is all you should need to verify the the Y setting of 100 in the M92 command is the correct value for your printer.
    At least my mistake with G92 was corrected in time and you didn't get messed up by it. That's a relief.
      A Former User @A Former User
      @fcwilt OKAY, I've moved the bed back, right to the point where the endstop clicks. I've taped the metal ruler to the frame. The beginning of the measure is absolutely lining up with the very back of the metal bed.
      So, I had to Home Y to get the machine movement points back. The bed was already right at the switch, but it decided to pound on the motor for a bit, then it stopped.
      With the movement buttons back, I jogged the bed forwards 10 times (Y+10 each time). The front of the bed is at 12 and 7/8 right now. If it had started at the endstop, I think it would be at 13 inches exactly right now.
      ? undefined 2 Replies Last reply 28 Jun 2022, 04:07 Reply Quote 0
        @fcwilt 13 inches of travel is 300mm. We're talking round numbers, Frederick!
          I really don't quite understand what you did but that doesn't matter as long as...
          You are satisfied that the Y value of 100 for M92 in the config.g file is correct.
          If you are we can proceed to measure the Y axis.
          ? 1 Reply Last reply 28 Jun 2022, 04:08 Reply Quote 0
            A Former User @fcwilt
            @fcwilt It makes sense, let's go with it.
            undefined ? 2 Replies Last reply 28 Jun 2022, 04:10 Reply Quote 0
              OK
              This is next.
              To use jogging of Y to measure the max travel of Y is simple:
              • execute M564 H0 S0 (from the DWC console is fine) so you can jog the entire axis without being limited by the current M208 limits
              • jog the bed as far back as possible
              • execute G92 Y0
              • jog the bed as far forward as possible
              • read the current Y position as displayed by the DWC
              When jogging near the ends try to "sneak" up on the ends so you don't over shoot them. The firmware will think the move happened even if the bed stayed still.
                @fcwilt I'm going to follow your instructions, and I'll report them to you as soon as I have them. Just hang on, we'll get there.
                ? 1 Reply Last reply 28 Jun 2022, 04:15 Reply Quote 0
                  @fcwilt Y is EXACTLY 350!
                  undefined ? 2 Replies Last reply 28 Jun 2022, 04:16 Reply Quote 1
                    Does it seem possible that the bed actually moved 350mm?
                      @fcwilt THE FRONT OF THE BED IS AT 18 INCHES FROM WHERE IT STARTED.
                      ? 1 Reply Last reply 28 Jun 2022, 04:18 Reply Quote 0
                        @fcwilt 18 inches is 457.2 mm.
                        ? 1 Reply Last reply 28 Jun 2022, 04:20 Reply Quote 0
                          @mac ![alt text](FBD3A47D-8359-4529-AE5C-3603EFE8BAA0.jpeg 7060EEA5-5D54-44D0-8C3F-35E20D3135B6.jpeg image url)
                          ? 1 Reply Last reply 28 Jun 2022, 04:22 Reply Quote 0
                            @fcwilt The bed started at 0 inches, and travelled to 18 inches. DWC called it 350.0. It's 18 inches. All of the numbers are whole numbers. We're golden.
                              fcwilt
                              But 18 inches is 457.2 mm - how is that possible?
                              ? 1 Reply Last reply 28 Jun 2022, 04:23 Reply Quote 0
                                @fcwilt I have an inches to metric calculator doing that for me.
                                ? undefined 2 Replies Last reply 28 Jun 2022, 04:23 Reply Quote 0
                                  @fcwilt link text
                                  ? 1 Reply Last reply 28 Jun 2022, 04:25 Reply Quote 0
                                    No I mean if the bed actually moved 18 inches which is 457.2 mm the DWC should read the same 457.2 mm, assuming the DWC was reading 0 when you started. Which is should have since you execute G92 Y0.
                                    ? 1 Reply Last reply 28 Jun 2022, 04:26 Reply Quote 0
                                      @fcwilt maybe the question is, what is the relationship between DWC reporting 350, and my metal measuring stick reporting 18 inches?
                                      undefined 1 Reply Last reply 28 Jun 2022, 04:25 Reply Quote 0
                                        When converting inches to mm the DWC should read out what you measured.
                                          @fcwilt we have to subtract the depth of the bed!!!!! Which is 220. I'm getting 247?
                                          ? undefined 2 Replies Last reply 28 Jun 2022, 04:26 Reply Quote 0
                                          358 out of 682
