    Independent Z Motors- Endstop Error
    Using Duet Controllers
    353
      What is the U axis? You have two endstops defined for Z, but only a single driver. You have two drivers assigned to U, but only a single endstop.
      You also seem to be referencing a V axis...
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 V6000
      M906 X800 Y800 Z800 E800 U800 V 800 I60
      JRCLundefined 1 Reply Last reply Reply Quote 1
      • JRCLundefined
        JRCL @Phaedrux
        @phaedrux U axis is an external carriage for thermoforming. What is a driver in this case? One end stop on the U was intentional as it doesn't need to be very level.
        Whoops the V's should be gone, the firmware was copied from an old one to start which had a V axis. Looks like I missed a few!
          You can only use independent Z motor leveling with 2 endstops if you are using 2 independent drives for the Z axis.
          • JRCLundefined
            JRCL @Phaedrux
            @phaedrux Ohhh, I see. So I can't use both the Z drive connections, the other has to use a different driver.
              The 2 Z motor connectors on the board are wired in series to the same driver. To get independant control, you'd need to use a second driver for the second motor.
              See here for more details.
              https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling
              You're on the right start. Once you fix up the driver mappings and clean up the U/V stuff it should work.
              JRCLundefined 2 Replies Last reply Reply Quote 1
              • JRCLundefined
                JRCL @Phaedrux
                @phaedrux Awesome! Wouldn't have figured that one out for a bit 🙂 should be an easy fix then, thanks for the help.
                • JRCLundefined JRCL has marked this topic as solved
                • JRCLundefined JRCL has marked this topic as unsolved
                • JRCLundefined
                  JRCL @Phaedrux
                  @phaedrux
                  Here is my new config.g with updated driver setup and elimination of V axis. Made sure my end stop wiring corresponded to the drivers in the same order as the pin call out "zstop+e2stop" as well. I'm still getting a G28 Z Failed to Enable End Stops, error message.
                  M569 P0 S1                                      ; physical drive 0 goes forwards (eventually X)
                  M569 P1 S1                                      ; physical drive 1 goes forwards (eventually Y)
                  M569 P2 S1                                      ; physical drive 2 goes forwards (eventually Z1)
                  M569 P3 S1                                      ; physical drive 3 goes forwards (eventually E)
                  M569 P4 S0										; physical drive 4 goes backwards (eventually U1)
                  M569 P5 S0										; physical drive 5 goes backwards (eventually U2)
                  M569 P6 S1										; physical drive 6 goes forwards (eventually Z2)
                  M950 P0 C"duex.pb6" 							; assign servo control to port 0 and link to PB6 GPIO on duex
                  ; Motor Speeds and Accelerations
                  M584 X0 Y1 Z2:6 E3 U4:5                               ; set drive mapping
                  M350 X16 Y16 Z16 E16 U16 I1                     		 	; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z400.00 E415.38918 U80        					; set steps per mm
                  M566 X900.00 Y900.00 Z60.00 E120.00 U900    				; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z180.00 E1200.00 U6000 				; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00 E250.00 U500.00 				; set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E800 U800 I40                	; set motor currents (mA) and motor idle factor in per cent
                  M208 X-40 Y-10 Z0 U0 S1                                ; set axis minima
                  M208 X160 Y170 Z300 U500 S0                          	; set axis maxima
                  M574 X2 S1 P"xstop"                            	; configure switch-type (e.g. microswitch) endstop for high end on X
                  M574 Y2 S3                                      ; configure sensorless endstop for high end on Y
                  M574 Z2 S1 P"zstop+e2stop" 						; configure active-high endstops on Z via pins zstop and e1stop
                  M574 U2 S1 P"e1stop" 							; configure switch-type (e.g. microswitch) endstop for high end on U via pin e1stop
                  M915 Y R0 F0 S3 								; configure stall detection for Y
                  M950 S0 C"duex.pwm1" 							; Duet 2 WiFi/Ethernet + DueX2/5
                  M558 P9 C"^zprobe.in" H5 F120 T6000 			; Duet 2 WiFi/Ethernet, DueX2/5
                  G31 P500 X-7 Y0 Z6.017        				; set Z probe trigger value, offset and trigger height
                  Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    Phaedrux Moderator @JRCL
                    @jrcl said in Independent Z Motors- Endstop Error:
                    You're only getting that error when you send G28 Z?
                    Does homeall work?
                    Can you send M119 and share the results?
                    Can you send M574 and share the results?
                      dc42 administrators @JRCL
                      I suspect that line isn't working as intended. As you have a DueX in the system, you should use this:
                      M574 Z2 S1 P"zstop+duex.e2stop"
                      JRCLundefined 1 Reply Last reply Reply Quote 2
                      • JRCLundefined
                        JRCL @dc42
                        @dc42 Aha! That fixed the problem, Z is homing as expected now. Thank you!
