    Write a plugin for DWC- solved using BtnCmd.
    Duet Web Control
    4.3k
    • MintyTreborundefined
      MintyTrebor @moth4017
      @moth4017 I have just published the latest version with the following changes:
      Changes:
      • Enabled Auto Restore Feature - read more here
      • New Experimental Feature for SBC users - read more here
      • Added the ability to include object model values in MQTT msgs, and HTTP Post data - read more here
      https://github.com/MintyTrebor/BtnCmd/releases
      NodeDSF - Native Node-Red integration with Duet boards.
      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
      ReleaseMgr - Duet update info inside DWC.
      Repo
      moth4017undefined 2 Replies Last reply Reply Quote 1
      • moth4017undefined
        moth4017 @MintyTrebor
        @mintytrebor
        Thanks will do testing today .
        • moth4017undefined
          @mintytrebor
          re backup auto recovery
          "By renaming a standard BtnCmd backup file to BtnCmdAutoRestore.json in the SDCard SYS folder, BtnCmd will load the file automatically when any of the above conditions are met."
          The standard file name being "BtnCmdSettings" and rename this to BtnCmdAutoRestore.json is this correct?
          I tried installing the new version over the top of the old one, first stopping the plugin , but my printer would not start after that so recreated the files on the SD card and installed the new version and thats working OK .
          im getting this http message when i post this command
          MintyTreborundefined 1 Reply Last reply Reply Quote 0
            @moth4017 said in Looking for someone to write a plugin for DWC:
            It's whatever you named the backup file when you created it. The default backup file name is BtnCmdSettings.json.
            In the img there is no post data - so it cannot post anything.
            Repo
            moth4017undefined 1 Reply Last reply Reply Quote 0
            • moth4017undefined
              @mintytrebor
              im not sure if im using "post" correctly. it is working but the http error being reported.
              "http://192.168.0.10/tare" is what i need to post. i have tried putting "tare" in the data field but this didnt work. i also tried using "Get" this works too but i get the same http error message . It also says "check Browser Console for more details " but there is never any details.
              Other wise were about 80% of the way through the project .
                @moth4017 If you don't want to send any data then put
                in the post data field.
                Repo
                • moth4017undefined
                  @mintytrebor
                  Hi tried the { } still get the http error, are you expecting a returned code like 200?
                    @moth4017 when you type the Post URL into your browser what is returned?
                    Repo
                    moth4017undefined 2 Replies Last reply Reply Quote 0
                    • moth4017undefined
                      @mintytrebor
                      putting this into the browser :- http://192.168.0.10/tare{}
                      "Path Not Found
                      URI: /tare%7B%7D
                      Method: GET
                      Arguments: 0"
                      reply
                      "tare ok"
                      the tare ok message is the response from the esp32
                      • moth4017undefined
                        @mintytrebor
                        still having a few issues with post does this look correct
                        MintyTreborundefined moth4017undefined 2 Replies Last reply Reply Quote 0
                          @moth4017 it's missing the http:// in the URL
                          Repo
                          • moth4017undefined
                            @mintytrebor
                            it was a long day and just over looked that one..
                            Ok i tried the auto restore today renamed file
                            closed down the browser , which clears all the cached data, restarted DWC , but when i opened up the btncmd interface it had reloaded the default page with the single panel . not the backup, did manaul of install of backup and this was ok
                              @moth4017 take a new backup and replace the BtnCmdAutoRestore.json with the new version. Now open your printer in a private browser window, does it auto restore then?
                              Repo
                              • moth4017undefined
                                moth4017
                                @mintytrebor
                                Did a new backupAutoRestore file , opened up browser in "incognito" mode put in ip address of the printer , the BtnCmd file did not autorecover .
                                  @moth4017 when you click the "info" button in settings, what version does it report?
                                  Edit - On further thought, given your installation issues with the plugin version upgrade. I think it would be wise if you stop the plugin, uninstall it, clear your browser cache, download and install the plugin again, then re-test the auto restore feature with a fresh backup file.
                                  If that does not work send me your backup file please.
                                  Repo
                                  moth4017undefined 4 Replies Last reply Reply Quote 0
                                  • moth4017undefined
                                    @mintytrebor
                                    BtnCmd Beta v0.10.13
                                    Cobbled together by Minty Trebor
                                    BtnCmd uses the following libraries/modules:
                                    DeepMerge, MQTT.js, vue-draggable-resizable, axios, jsonpath, vuedraggable
                                    Plus re-uses components and code from DWC.
                                    BtnCmd Wiki
                                    Material Design Icon Library
                                    Ill do the unistall reinstall a bit later on today
                                    • moth4017undefined
                                      @mintytrebor
                                      Ok i did the unistall , create new file , do new back up etc etc
                                      opened new browser , and the restore worked, ill keep an eye on it while doing the software on the esp32. cheers
                                      • moth4017undefined
                                        moth4017 @moth4017
                                        This post is deleted!
                                        • moth4017undefined
                                          @mintytrebor
                                          Hi well , almot there , jus have some OCD things 🙂 now to sort
                                          how do i get the buttons and input boxes to line up.
                                            @moth4017 turn on Snap to Grid in tab settings
                                            Repo
