    problem update from 3.0 to 3.4.1
    Firmware installation
    • Ladusseundefined
      Ladusse
      I do the update from 2.X to 3.0 without a problem. I start the update from 3.0 to 3.4.1 and now I'm not able to connect via my browser. Did I need to remove the SD and modify the WIFI setting into the config file?
        If it's not connecting to wifi again after the update it may be that the wifi module flash failed silently. The solution is to connect via USB and send M997 S1 to re-flash the wifi module. See if that works.
        Ladusseundefined 1 Reply Last reply Reply Quote 0
        • Ladusseundefined
          Ladusse @Phaedrux
          @phaedrux I restart the card and now it's working.
