    Duet3D 3 6HC COM port as "device description request error"
    Firmware installation
    383
    • Gasstaldyundefined
      Gasstaldy
      I have a duet 3 6HC board. It is new, and when I connect it to the PC, it marks the port as; "device description request error"
      DIAG led stays on dim all the time
      I have the indicated drivers installed on the PC, I have already followed many procedures, including erasing the memory by bypassing the erase pins.
      I already tried with many USB cables, I already used all the ports of the PC. even another PC. and nothing.
      I don't know what to do I need help.
      https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
      Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
        Do you have a raspberry pi to try?
        Gasstaldyundefined 1 Reply Last reply Reply Quote 0
          Gasstaldy @Phaedrux
          @phaedrux I don't have raspberry pi
            Phaedrux Moderator @Gasstaldy
            @gasstaldy said in Duet3D 3 6HC COM port as "device description request error":
            Can you get a screen shot of the complete error?
              Gasstaldy @Phaedrux
                When and where did you purchase the Duet 3?
                  dc42 administrators @Gasstaldy
                  @gasstaldy if the Diag LED is dim then somehow the firmware has been erased, or perhaps was never installed if it isn't a genuine Duet. In this state the board presents the Bossa port over USB ready for programming, but the port is in high speed mode and is very fussy about the cable. So try a different USB cable and/or a different USB port on your PC. Don't use a USB extender cable.
                  Once the board is running RepRapFirmware, the USB port is in standard speed mode and is much less fussy about the cable.
                    Gasstaldy @Phaedrux
                    @phaedrux A few months ago on Amazon, I bought it and now I want to use it
                      Which Amazon seller did you purchase from? It's most likely a clone board.
                        Gasstaldy @dc42
                        @dc42 Thanks to your technical clarification, I was able to understand more about the problem, and connected the DUET with another cable to port C of my PC, and problem solved. already loaded with BOSSA. And my DUET is working perfectly.
                        Thanks to everyone who contributed and helped me.
                        • droftartsundefined droftarts marked this topic as a question
                        • droftartsundefined droftarts has marked this topic as solved
