    Height Map Display Error
      A Former User
      This post is deleted!
        Can you measure the probe trigger height at each of those corners?
        Manually set Z0 with G92 when touching nozzle to the bed.
        Move up 10mm
        G30 S-1
        Does the trigger height vary between the 4 corners?
          When you send G29 and have a mesh.g file it runs that file. But your mesh.g file doesn't contain G29 S0, so it's not actually running a meshing routine, it's just probing your points. I'm not sure how this will differ. Can you use M557 to setup your 4 point grid and then send G29 S0 to create an actual mesh?
            A Former User @Phaedrux
            Phaedruxundefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @A Former User
              @herve_smith said in Height Map Display Error:
              I have probed manually each corner as in your first post and that shows no deviation
              With resetting the Z0 point at each?
                that doesnt explain why it has been fine for a long time then suddenly starts showing this issue when i have changed nothing (other than updating firmware)
                You can roll back firmware to see if that's the case or just a coincidence. The other thing that changes over time is mechanical drift.
