    Help how do i configure two drivers for the Z axis
    Gcode meta commands
    • Gasstaldyundefined
      Gasstaldy
      How to configure two drivers for the Z axis?
      I have one motor connected to driver 2. And the other to driver 3
        Phaedrux Moderator @Gasstaldy
        @gasstaldy said in Help how do i configure two drivers for the Z axis:
        Your M584 would need to change. Currently driver 3 is an extruder, so you'd need to move it to the Z axis.
        M584 X0.0 Y0.1 Z0.2:0.3 E0.4
        If you have 2 extruders, you'd need another driver for it as well. Otherwise you can remove the double values for the extruder from the other commands you show. Like M92 E420.00:420.00 would only be M92 E420. Also note that the Z axis (or any other none extruder axis) doesn't need multiple values. Only extruders. A single value will apply to all drivers in a motion axis.
        Gasstaldyundefined 1 Reply Last reply Reply Quote 0
          Gasstaldy @Phaedrux
          @phaedrux thank you, I see that it is quite simple, I just couldn't find where to start
            You can see an example here: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling
              Gasstaldy @Phaedrux
              @phaedrux Thanks, the Z axes turned out well.
              Now I have the problem that the extruder does not appear in DWG or in the Duet panel
              M569 P0.0 S1                                       ; physical drive 0.0 goes forwards	//X
              M569 P0.1 S1                                       ; physical drive 0.1 goes forwards	//Y
              M569 P0.2 S1                                       ; physical drive 0.2 goes forwards	//Z
              M569 P0.3 S0                                       ; physical drive 0.3 goes forwards	//Z
              M569 P0.4 S1                                       ; physical drive 0.4 goes forwards	//E
              M584 X0.0 Y0.1 Z0.2:0.3 E0.4                       ; set drive mapping
              M350 X32 Y32 Z16 E16 I1                         ; configure microstepping with interpolation
              M92 X160.21 Y160.28 Z400.00 E420.00        ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E120.00        ; set maximum instantaneous speed changes (mm/min)	//cambios instantaneos de direccion (jerk)
              M203 X21000.00 Y21000.00 Z500 E3000.00  ; set maximum speeds (mm/min)	//Maximas velocidades que puede alvanzar los ejes
              M201 X6000 Y6000 Z20 E250.00         ; set accelerations (mm/s^2)	//la forma en la que acelera por segundo los ejes
              M906 X800 Y800 Z1100 E800 I30                  ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                            ; Set idle timeout
              M208 X0 Y0 Z0 S1                                   ; set axis minima
              M208 X600 Y570 Z498.75 S0                           ; set axis maxima
              M574 X1 S1 P"!io1.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io1.in
              M574 Y1 S1 P"!^io2.in"                             ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !^io2.in
              M574 Z2 S1 P"!^io3.in"                             ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !^io3.in
              M950 S0 C"io4.out"                                 ; create servo pin 0 for BLTouch
              M558 P9 C"io4.in" H5 F6000 T6000 P5               ; set Z probe type to bltouch and the dive height + speeds //H altura a la que se despliega la sonda
              G31 P500 X45 Y0 Z-0.71                             ; set Z probe trigger value, offset and trigger height	//-3.04
              M557 X0:600 Y0:570 S150                            ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B3950 ;U"TMK8"       ; configure sensor 0 as thermistor on pin temp0 //U nombre del sensor
              M950 H0 C"out1" T0                                 ; create nozzle heater output on out1 and map it to sensor 0 //H numero de hotend -
              M307 H0 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
              M143 H0 S280                                       ; set temperature limit for heater 0 to 280C
              M950 F0 C"out8" Q500                               ; create fan 0 on pin out8 and set its frequency
              M106 P0 C"FanExtrusor" S0 H0 T100                  ; set fan 0 name and value. Thermostatic control is turned on
              M950 F1 C"out7" Q500                               ; create fan 1 on pin out7 and set its frequency
              M106 P1 C"FanCapa" S1 H-1                          ; set fan 1 name and value. Thermostatic control is turned off
              M563 P1 S"MK8" D1 H0 F0:1                          ; define tool 1
              G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
              G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
              M501                                               ; load saved parameters from non-volatile memory
              T1                                                 ; select first tool
              PDBealundefined droftartsundefined 2 Replies Last reply Reply Quote 0
              • PDBealundefined
                PDBeal @Gasstaldy
                @gasstaldy I believe you need to define Tool 0 and not Tool 1. You probably need to change your config similar to the one listed below.
                M563 P0 S"MK8" D0 H0 F0:1                          ; define tool 0
                G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                T0                                                 ; select first tool
                  droftarts administrators @Gasstaldy
                  @gasstaldy don’t assign thermostatically controlled fans to tools. Your fan 0 is assigned as such, so remove it from the M563 tool definition.
