    Print status percent incorrect
    Duet Web Control
    • shirnschallundefined
      shirnschall
      I recently noticed that the print status percent is extremely off for some prints and I am unsure what this percentage is based on. I tend to run a simulation before starting the print to get an accurate print time estimate (Although the slicer estimation is very close for my printer). I have attached screenshots of two different prints, both with the issue described above. I guess this statistic it is based on "File Progress" as it is very wrong for all other stats available (layers, filament usage, slicer estimate, and simulation). I am not sure if there is a better way for doing this.🤔
      I am using a duet 2 wifi with firmware version 3.4.0.
      My printer: DIY 2020 extrusion CoreXY with E3D Tool-changing and Duet3 (https://github.com/shirnschall/HS-Bot-Project)
        Can you share an example gcode file?
        Can you confirm that your DWC version matches your firmware version?
        shirnschallundefined 1 Reply Last reply Reply Quote 0
          shirnschall @Phaedrux
          @phaedrux Hi,
          yes I am using DWC 3.4.0 as well.
          Please download the gcode from github as it was too large to upload here.
          Here is the M122 output (just in case).
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DGM-9T6BU-FG3SN-6JKDJ-3S86N-98ZHF
          Used output buffers: 3 of 24 (24 max)
          Static ram: 23868
          Dynamic ram: 76252 of which 24 recycled
          Never used RAM 11792, free system stack 118 words
          Tasks: NETWORK(ready,15.5%,232) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,305) DUEX(notifyWait,0.0%,24) MAIN(running,84.3%,466) IDLE(ready,0.2%,30), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:10:23 ago, cause: software
          Last software reset at 2022-07-24 00:59, reason: User, GCodes spinning, available RAM 8144, slot 1
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x04
          Step timer max interval 0
          MCU temperature: min 39.4, current 41.8, max 42.1
          Supply voltage: min 1.0, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0
          Driver 1: standstill, SG min 0
          Driver 2: standstill, SG min 0
          Driver 3: standstill, SG min n/a
          Driver 4: standstill, SG min 0
          Driver 5: standstill, SG min n/a
          Driver 6: standstill, SG min n/a
          Driver 7: standstill, SG min 0
          Driver 8: standstill, SG min n/a
          Driver 9: standstill, SG min 0
          Driver 10:
          Driver 11:
          Date/time: 2022-07-24 01:10:14
          Slowest loop: 69.92ms; fastest: 0.11ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.9ms, write time 120.6ms, max retries 0
          DMs created 83, segments created 6, maxWait 81367ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 89, completed 89, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 59], CDDA state -1
          === AuxDDARing ===
          Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty
          === DueX ===
          Read count 1, 0.10 reads/min
          === Network ===
          Slowest loop: 233.93ms; fastest: 0.00ms
          HTTP sessions: 2 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.26
          WiFi MAC address 84:f3:eb:41:aa:d2
          WiFi Vcc 3.42, reset reason Power up
          WiFi flash size 4194304, free heap 23920
          WiFi IP address 192.168.0.111
          WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
            Please update to 3.4.1
              @phaedrux OK. Thank you 🙂
                dc42 administrators @shirnschall
                @shirnschall to expand on the response from @Phaedrux, the release notes for DWC 3.4.1 at https://github.com/Duet3D/DuetWebControl/wiki/Changelog-DWC-3.x include this bug fix:
                Job progress did not use filament information if available
                  shirnschall @dc42
                  @dc42 Thank you for the clarification 😊
                  I have already updated to the new version.
