    Crash into bed on Z home
    IR Height Sensor
    1.8k
    • okamitokundefined
      okamitok
      For the life of me cannot solve an issue with my new IR sensor.
      Below are my setting, following these instructions, https://miscsolutions.wordpress.com/mini-height-sensor-board/
      Sending G92 Z0 and then G30 S-1 works fine and it homes.
      [[language]]
      M558 P1 X0 Y0 Z1 H5 F120 T6000
      G31 P500 X0 Y2.4 Z0.949 ; Set Z probe trigger value, offset and trigger height
      But when I then run the homez it always crashes into the bed.
      Here is my homez file:
      [[language]]
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool on Sat Oct 21 2017 21:17:08 GMT-0500 (Central Daylight Time)
      ; Lift Z relatively to current position
      G91
      G1 Z5 F6000
      ; Back to absolute positioning
      G90
      ; Go to first bed probe point and home the Z axis
      G1 X30 Y27.6 F6000
      G30
      ;G91
      ;G1 Z5 F100
      ;G90
        If you send these commands manually:
        G1 X30 Y27.6 F6000
        G30
        does it work?
        • okamitokundefined
          okamitok
          Nope the LED turns on on the sensor and it just continues to press towards the bed.
          Here is a copy of my config.g
          https://pastebin.com/Yadsckyx
          And here is the Duet version:
          [[language]]
          Firmware Name:	RepRapFirmware for Duet WiFi
          Firmware Electronics:	Duet WiFi 1.0
          Firmware Version:	1.19.2 (2017-09-01)
          WiFi Server Version:	1.19.2
          Web Interface Version:	1.19
            Sounds like a configuration or wiring problem then. Duet Web Control displays the Z probe reading on the Control and Print Status pages. The reading should rise to about 535 when you hold a target close to the underside of the sensor so that the LED illuminates. Please check this. Also please post your config.g file.
            • okamitokundefined
              okamitok
              I linked the config.g up above: https://pastebin.com/Yadsckyx
              I do get the correct readings but for some reason when it goes to actually probe it ignores the signal.
              I did the following:
              G92 Z0
              G30 S-1
              Then took the reading and used the value for the Z parameter in G31 command in config.g
              • okamitokundefined
                okamitok
                Not sure if it makes a difference but I have a black heater bed with a 6mm glass plate on top, but as mentioned the G30 S-1 command worked fine.
                  Just to be clear: are you saying that if you position the head about 5mm above the bed and run G30 S-1 then the probe stops when the LED comes on; but if you position the head 5mm above the same point and send G30 without the S-1 then it doesn't stop? Please check this.
                  • okamitokundefined
                    okamitok
                    So I just did a test because nothing was working again even with S-1.
                    If I lay a piece of paper on the glass, then it probes every time no problem, it isn't probing to the exact same spot it's quite a bit above the paper but the probe stops every time without crashing.
                    Which is weird because I see the numbers go 464 and then 538 with only the glass bed but it wont stop. Where as with the paper it does the same thing but it stops.
                    • SolarOHundefined
                      SolarOH
                      I wanted to piggyback onto this as i have the same issue. (DuetWIFI coreXY build with IR probe, X and Y endstops are on high ends of build plate i.e 300, 290)
                      I was running 1.19 and was having connectivity issues to the webcontrol UI, but no issues with homing.
                      I updated just the other day to 1.20, and when i ran homeall, x and y homed, then z crashed to the bed.
                      So i recalibrated my z probe per the wordpress article, and the z probe was triggering as expected at the same value i had set before in G31. I tested G30 S-1, AND G30 both probed the bed and stopped before a crash.
                      My thought is that in the release notes there was mention of adding S2 to the M574 section, but doing that just caused the x and y to crash, never getting to Z.
                      Below is my config.g and homeall.g files, maybe someone can shed some light on this for me.
                      –---Config.g:-------
                      ; Configuration file for testing Duet Ethernet and Wifi
                      ; Communication and general
                      M111 S0 ; Debug off
                      M550 PHC300 ; Machine name and Netbios name (can be anything you like)
                      M551 Pcheats5 ; Machine password (used for FTP)
                      ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
                      M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
                      ;*** Networking - Enable for both WiFi and Ethernet boards.
                      M552 S1 ; Turn network on
                      ;*** Ethernet networking: Adjust the IP address and gateway in the following 2 lines to suit your network
                      M552 P10.10.10.250 ; (0 = DHCP)
                      M554 P10.10.10.1 ; Gateway
                      M553 P255.255.255.0 ; Netmask
                      M555 P2 ; Set output to look like Marlin
                      G21 ; Work in millimetres
                      ; Disable Fan 1 thermostatic mode
                      M106 P1 H-1
                      ; Axis and motor configuration
                      M569 P0 S0 ; Drive 0 goes forwards
                      M569 P1 S0 ; Drive 1 goes forwards
                      M574 X2 Y2 Z0 S0 ; set endstop configuration (all endstops at high end, active high)
                      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
                      M667 S1 ; switch to CoreXY mode
                      M208 X290 Y240 Z270 S0 ; Set axis maxima
                      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
                      M350 X16 Y16 Z16 E16:16 I1 ; Set 16x microstepping with interpolation
                      M92 X80 Y80 Z400 ; Set axis steps/mm
                      M906 X500 Y500 Z500 E1120 I40 ; Set motor currents (mA) and increase idle current to 40%
                      M201 X1500 Y1500 Z1000 E1000 ; Accelerations (mm/s^2)
                      M203 X1000 Y1000 Z200 E3600 ; Maximum speeds (mm/min)
                      M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
                      ; Thermistors
                      M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
                      M305 P1 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set first nozzle thermistor ADC correction
                      M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set 2nd nozzle thermistor ADC correction
                      M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
                      ; Adjustments for J-heads used as dummy heaters on test rig
                      M307 H0 A250 C140 D5.5 B1
                      M307 H1 A250 C140 D5.5 B0
                      M307 H2 A250 C140 D5.5 B0
                      M557 X0:250 Y0:225 S25 ;mesh grid probe pattern
                      M106 P1 S-1 ; disable thermostatic mode for fan 1
                      ; Tool definitions
                      M563 P0 D0 H1 ; Define tool 0
                      G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
                      ;*** If you have a single-nozzle build, comment the next 2 lines
                      ;M563 P1 D1 H2 ; Define tool 1
                      ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
                      M92 E837:837 ; Set extruder steps per mm
                      M143 H1 S290 ;set max hot end temp
                      M307 H1 A576.4 C196.8 D6 B0 S1 ;Set PID values for hot end
                      M143 H0 S125 ;set max bed temp
                      M307 H0 A146.6 C693.4 D9 B0 S1 ;Set PID values for Bed Heater
                      ; Z probe and compensation definition
                      ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
                      M558 P1 X0 Y0 Z1 ; Z probe is an IR probe and is used for homing Z axis
                      G31 Z1.5 P500 ; Set the zprobe height and threshold (put your own values here)
                      ;*** If you are using axis compensation, put the figures in the following command
                      M556 S78 X0 Y0 Z0 ; Axis compensation here
                      ;M208 S1 Z-1.95 ; set minimum Z
                      T0 ; select first hot end
                      -------Homeall.g–-------
                      G91 ; relative mode
                      G1 S1 X340 Y340 F3000 ; course home X or Y
                      G1 S1 X340 ; course home X
                      G1 S1 Y340 ; course home Y
                      G1 X-4 Y-4 F600 ; move away from the endstops
                      G1 S1 X10 ; fine home X
                      G1 S1 Y10 ; fine home Y
                      ; Z homing section follows for IR Z probe
                      G1 X-30 F3000 ; X offset to get z probe to bed
                      G1 S1 Z-400 F500 ; course home Z
                      G1 Z2 F500 ; move away from the Z Probe
                      G1 S1 Z-4 F100 ; fine home Z
                      G90 ;back to absolute mode
                      G92 Z1.5 ;tell printer that it is at Z=1.5 (trigger height of z probe during homing)
