    VSSA fuse
    1.7k
    • myschetzkyundefined
      myschetzky
      Both hotend and bed are showing 2000c. So from what I can read in other posts the VSSA fuse is most likely blown. 😞
      But when I try to measure the resistance from an end stop ground pin to the VSSA pin on the back, it shows no resistance at all.
      Could you provide a diagnostic and repair guide for dummies? 😞
      Kind regards, Niklas
        myschetzky
        Oh now I found this
        https://duet3d.com/wiki/Connector_and_spare_part_numbers#VSSA_fuse
        haha always one step ahead huh Dave
        But isn't it odd that I can't measure any resistance at all?
          Yes that is odd. What is the smallest resistance that your multimeter can distinguish from zero? Even with the fuse intact, the resistance should be 1 ohm or greater.
            myschetzky
            Well if I set my multimeter to 200 ohm, it can register down to 0.1 ohm.
            But when I put the probes on the VSSA and ground it still displays 1 on the display. As it does when the probes are not touching anything.
              myschetzky
              Here is a video of it ..
              Sorry about the upside down. It was difficult to probe and hold the phone at the same time! 😄
              https://www.youtube.com/watch?v=p4fdPfm9vks
                That 1 on the display means that the resistance is too high to measure on that range, just as if the probes are not touching anything. So it confirms that the VSSA fuse has blown.
                  myschetzky
                  Ah but even if I turn the multimeter up to 2000K ohm's it doesn't register anything.
                  Oh well, I ordered a few spares which will arrive tomorrow. Thanks to the efficient Farnell!
                  Ordered this:
                  MF-MSMF014-2 MULTIFUSE, SMD, 0.14A
                  http://dk.farnell.com/bourns/mf-msmf014-2/multifuse-smd-0-14a/dp/9350284?CMP=i-ddd7-00001003
                  So I will add a self resetting fuse as per your instructions.
                  Connect the fuse between the E0 thermistor VSSA pin and the E1 endstop ground pin.
                  Will this fix all thermistors? Or do I need to add one for E1 and bed temp also?
                    One fuse handles all the thermistor inputs.
                      myschetzky
                      Great. Then hopefully This Will work
                      https://drive.google.com/open?id=0B55_VkyZJuz0cGV3X3puZ1RXQUE
                        myschetzky
                        It did! Yay! Almost an 1.02 board now. Hehe
