Update fail on very first step!
Firmware installation
1.9k
    Andy Cohen
    Trying to go from 2.04 to 2.05.1 before moving to 3.0, etc...
    On the very first step, when I upload the update zip file I get...
    "Failed to upload app.db918b7e.css.gz
    Network error"
    Any clues?
    undefined 1 Reply Last reply 26 Aug 2022, 17:24 Reply Quote 0
      dc42 administrators @Andy Cohen
      @andy-cohen does it do that every time you try it?
        Are you trying to upload the intact single zip file, or did you extract it first?
          Andy Cohen
          @phaedrux I tried to update from the entire zip file. Per your chat message I simply just went to 3.0... and surprise! I'm dead in the water again just like the last time I updated from 2.x to 3. Sigh...
          The web control does not connect.
            Connect via USB terminal and send M115 and M122 and see what response you get. It's possible the wifi firmware did not flash correctly in which case you would need to reflash it by sending M997 S1.
            Based on the results of those commands we'll be able to make further advice.
            undefined 2 Replies Last reply 26 Aug 2022, 20:38 Reply Quote 0
              Andy Cohen @Phaedrux
              @phaedrux Yeah... well...
              The machine is a tool changer out in the garage so I have to use my laptop.
              Serialtools installs on the Mac side but it won't run!
              I switch over to Windows... YAT won't install.
                @phaedrux OK... had to download SerialTools directly from the dev...
                M115 I get...
                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-01-03b3
                M122 returns nothing
                I tried M997 S1 and I get nothing.
                undefined 1 Reply Last reply 26 Aug 2022, 21:06 Reply Quote 0
                  Andy Cohen @Andy Cohen
                  @andy-cohen So... the port was sucking too much voltage.. attached the PS to the laptop...
                  M122 S1
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DGM-917DA-G4MS8-6JKF0-3SJ6R-K9V79
                  Used output buffers: 10 of 24 (10 max)
                  Static ram: 30516
                  Dynamic ram: 92616 of which 28 recycled
                  Exception stack ram used: 280
                  Never used ram: 7632
                  Tasks: NETWORK(ready,824) HEAT(blocked,1464) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156)
                  Owned mutexes:
                  Last reset 00:01:15 ago, cause: power up
                  Last software reset at 2022-08-26 09:39, reason: User, spinning module GCodes, available RAM 7612 bytes (slot 2)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                  Error status: 0
                  Free file entries: 9
                  MCU temperature: min 26.6, current 31.3, max 31.6
                  Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 5: standstill, SG min/max not available
                  Driver 6: standstill, SG min/max not available
                  Driver 7: standstill, SG min/max not available
                  Cache data hit count 193604767
                  Slowest loop: 2.61ms; fastest: 0.09ms
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                  === MainDDARing ===
                  === AuxDDARing ===
                  Segments left: 0
                  Movement lock held by null
                  http is idle in state(s) 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is ready with "M122 S1" in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 15.68ms; fastest: 0.00ms
                  Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                  HTTP sessions: 0 of 8
                  • WiFi -
                    Network state is running
                    WiFi firmware version 1.23
                    WiFi MAC address ec:fa:bc:2d:df:6e
                    WiFi Vcc 3.48, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 21112
                    WiFi IP address 192.168.1.85
                    WiFi signal strength -51dBm, reconnections 0, sleep mode modem
                    Socket states: 2 0 0 0 0 0 0 0
                    ok
                  undefined 1 Reply Last reply 26 Aug 2022, 21:07 Reply Quote 0
                    @andy-cohen and...
                    now I can connect via wifi!
                    Whats up with that??
                    undefined 1 Reply Last reply 26 Aug 2022, 21:09 Reply Quote 0
                      @andy-cohen but it keeps disconnecting. Sigh..
                        When you're able to connect to DWC can you now upload the zip file for 3.3?
                        If 3.3 works, then do 3.4.1.
                        undefined 1 Reply Last reply 26 Aug 2022, 22:09 Reply Quote 0
                          @phaedrux The connection is not reliable enough. No idea whats going on here.
                          undefined 2 Replies Last reply 26 Aug 2022, 22:18 Reply Quote 0
                            @andy-cohen Now it won't connect at all. Its not my wifi signal. I can connect other things just fine.
                              @andy-cohen The terminal connection is flakey as well. It is random as to whether or not it works.
                                Is it connected to VIN at the same time as USB?
                                Do you have other things connected at the same time?
                                When it loses connection do the lights on the board change as well?
                                Is it losing power entirely or just dropping wifi?
                                undefined 1 Reply Last reply 26 Aug 2022, 22:28 Reply Quote 0
                                  @phaedrux The lights stay on. Only USB then only wifi(with cable disconnected). Both act flakey. Not losing power at all as far as I can see.
                                    With everything else disconnected connect via USB and send M997 to reflash both firmware. You can then send M552 S1 to enable the wifi module and it should connect. See if that makes an improvement.
                                    undefined 1 Reply Last reply 26 Aug 2022, 22:49 Reply Quote 0
                                      @phaedrux said in Update fail on very first step!:
                                      M997
                                      SO... on the M997, shouldn't it return OK afterward? It doesn't.
                                      undefined undefined 2 Replies Last reply 26 Aug 2022, 22:51 Reply Quote 0
                                        @andy-cohen No change. I can't get it to connect wifi at all now.
                                          Phaedrux Moderator @Andy Cohen
                                          @andy-cohen said in Update fail on very first step!:
                                          M997
                                          I'm not familiar with serial tools so I don't know what it would return there, but on YAT it should give you some indication that the firmware is being flashed.
                                          Does the module have a blue light showing?
                                          If you send these commands what does it return?
                                          M552 S-1
                                          M552 S0
                                          M552 S1
                                          Is there no chance you could use YAT?
                                          undefined 1 Reply Last reply 26 Aug 2022, 23:03 Reply Quote 0
                                          2 out of 54
