    Update fail on very first step!
    Firmware installation
    1.9k
      With everything else disconnected connect via USB and send M997 to reflash both firmware. You can then send M552 S1 to enable the wifi module and it should connect. See if that makes an improvement.
      Andy Cohenundefined 1 Reply Last reply Reply Quote 0
      • Andy Cohenundefined
        Andy Cohen @Phaedrux
        @phaedrux said in Update fail on very first step!:
        M997
        SO... on the M997, shouldn't it return OK afterward? It doesn't.
        Andy Cohenundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          Andy Cohen @Andy Cohen
          @andy-cohen No change. I can't get it to connect wifi at all now.
            Phaedrux Moderator @Andy Cohen
            @andy-cohen said in Update fail on very first step!:
            M997
            I'm not familiar with serial tools so I don't know what it would return there, but on YAT it should give you some indication that the firmware is being flashed.
            Does the module have a blue light showing?
            If you send these commands what does it return?
            M552 S-1
            M552 S0
            M552 S1
            Is there no chance you could use YAT?
              @phaedrux Yeah... they worked...
              and the router changed the IP address! I looked in the router map too and could not find the Duet.
              So it connects, but then the connection is immediately interrupted and it tries to reconnect.
                Can you set a DHCP reservation on the router to keep the Duet IP the same?
                  @phaedrux Did it. But it still can't keep the connection.
                    @andy-cohen Too bad it has to use wifi. It looked like it was stable so I tried to upload the 3.3 zip file and it disconnected.
                      @andy-cohen and now it won't connect again.
                        @andy-cohen Which LED should be blue to show the wifi is working? The three LEDs below the USB port are all lit Yellow, Red and blue.
                          @andy-cohen The LED by the wifi ant is NOT lit.
                            @andy-cohen I did the M552 S1 and got it to flash then it stays lit. So wifi should be on.
                              @andy-cohen and it connects then immediately disconnects. Blue light stays on.
                                The blue light on the module itself indicates the wifi status. Blinking means connecting, and then solid light means connected. Off means the module is off.
                                How far is it from the router? Are you able to move it closer just to test?
                                  When you say this, what exactly do you mean?
                                    @phaedrux There is a window and a door between the router and the machine. It's no more then about 10 feet. It's worked fine for over two years.
                                    Right now it refuses to connect. When it did connect within 1 second I'd get a error message (501) and it disconnects and attempts to reconnect.
                                      So is DWC actually loaded or are you just getting the error in the browser?
                                      What browser are you using? Have you done a hard refresh of the page? The DWC files would have changed between 2.x and 3
                                        @phaedrux I get the DWC it looks OK for about 1 second then the red alert pops up and it tries to reconnect.
                                          Can you grab a screen shot?
                                            @phaedrux I can't get it to connect now.
