Complete download needed for new installation… confused!
You are already running RepRapFirmware 1.19. Go to the Settings page of Duet Web Control, then the System Files Editor tab, there you will find the config.g file and you can edit it. If for any reason isn't there, go to https://configurator.reprapfirmware.org to generate a new one. You can upload just config.g or the whole zip file generated by configtool through the Settings General tab of Duet Web Control.
Finally. Although I've yet to print (having motion and homing difficulties) I can interact with the machine with consistency on both WiFi and PanelDue. I've got heat everywhere I need it and the extruder is working accurately from my previous steps/mm config. I release you to roam freely in new vistas and stop coddling me through my incompetencies.
Thank you very much, David. The Duet seems great and I have no doubt I will get it figured out sometime this week. It is better for me to struggle a while right now so I can learn it more effectively.Cheers,
Dean -
Good day . please tell me .I accidentally pressed the ERASE button and flew all the firmware reading on the website I realized that you need to install Bossa . I installed it but do not understand which files and where to download please tell me .DuetWiFi
All you need to know should be at https://duet3d.com/wiki/Updating_main_firmware#Fallback_procedure_.233. If there is anything there that you don't understand, feel free to ask again.
Good day . The link you advised . I did SC was listed on the page of the link . but that does not work out . can you write the process how to do it and what firmware need and do I need a flash drive for flashing process.
I have written the process, it's on the page I linked to. What didn't work for you? What do you mean by "SC" ?
You don't need a flash drive to install new firmware, you need either the SAM-BA program or the Bossa program in your PC as described on that page, and a USB cable between your PC and the Duet.
I use the Bossa program is ran the program and connected the DUET cost WIFI downloaded DuetWiFiFirmware.bin and did as said If you can't run SAM-BA (e.g. because you want to update the firmware with a Mac), you can also use Bossa 1.18 (not earlier versions) with https://github.com/shumatech/BOSSA/releases Interactive version (Bossa) does not work on high resolution screens, but you can still use the command line version (bossac). If you use the interactive version, you need to select to Wipe everything, Lock, and Boot from the Flash before pressing the Write key. If you are using the command line, try this command line: After that I pressed reset and no result
Did Bossa or bossac report "Verify successful"?
Yes exactly . report from Bossa was . now that's just . filled it with firmware 1.18 . uploaded it has disabled the usb wire put the flash drive with my settings and the result has not changed . diag lamp continues to burn
Ignore the diag lamp, whether it will be on or off depends on your Z probe configuration.
After programming, if you reset the board then the Bossa port will disappear from your mac but the Duet 3D port should appear.
tried all the firmware or what does not work . help what to do ?
3D-port of the Duo and not appearing Bossa program port too
3D port of Duo and not see Bossa program port sees. when you wipe the Boss is seen again
tell me what am I to do with my problem ?
Are saying that after flashing the firmware and restarting, you don't see the Duet 3D port in Windows Device Manager?
If so:
- Make sure you have downloaded the correct firmware file. Check that the file size is about 300K.
- Make sure that the M552 S1 command in config.g on the SD card has a semicolon in front of it to deactivate it.
- Check in Device Manager for an "Unknown device"
- If you are running Windows, you may need install the device driver from https://github.com/dc42/RepRapFirmware/tree/dev/Driver.
can you give me a link to the correct firmware ?
As it says on the wiki in several places, latest stable firmware is always at https://github.com/dc42/RepRapFirmware/releases.
