RepRap Firmware Issue in behavior
LPC
1.4k
    Shadi_Polar
    Hi All Hope I will to find some help here , I have built polar 3D printer with reprap firmware however I am unable to find out why the shapes the machine draw or print are not exact, currently I am using below configuration file as this polar machine however without bed and it rotates around the center like flipped L shape .
    The problems I am facing are the following
    1- round lines some how straight lines are not coming out exactly straight it has some round areas
    2- one corner when i print square it is coming off not as the others
    3- infill is offsetting of the actual frame that printed and I feel it tries to compensate the initial mistakes
    Attached is picture of the out put, hope to find help here20220925_194246.jpg
    ; Configuration file for SKR v1.3 (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.2.1-LPC+9 on Thu Apr 08 2021 18:06:07 GMT+0100 (British Summer Time)
    M550 P"RRF" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S1 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; X physical drive 0 goes forwards using default driver timings
    M569 P1 S1 ; Y physical drive 1 goes forwards using default driver timings
    M569 P2 S1 ; Z physical drive 2 goes forwards using default driver timings
    M569 P3 S1 ; E physical drive 3 goes forwards using default driver timings
    M92 X102.3197900411406 Y69.03866411874756 Z400.00 E420.00 ; set steps per mm
    ;Original value to calculate Y and above code is 143.3/2
    ;M92 X300 Y143.3 Z800.00 E420.00 ; set steps per mm
    M669 K7 R0:550 H150.50 S 0.01 ; polar kenimatic
    ;M669 K7 R0:450 H150 F300 A300 ; polar kenimatic
    ;Original Settings
    M566 X2000.00 Y2000.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M201 X800.00 Y800.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
    M84 S30 ; Set idle timeout
    ;My settings Config
    ;M566 X1800.00 Y1800.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    ;M203 X1000.00 Y1000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    ;M201 X1000.00 Y1000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
    ;M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    ;M84 S30 ; Set idle timeout
    ;M208 X90 Y0 Z0 S1 ; set axis minima
    M208 X550 Y620 Z400 S0 ; set axis maxima
    ;M208 X340 Y360 Z400 S0 ; set axis maxima
    M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
    ;M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
    M574 Y0
    M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin zstop
    M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
    M557 X:550 Y0:620 S20
    ;M557 X15:215 Y15:195 S20 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0
    M307 H1 R0.962 C330.8 D8.38 S1.00 V0.0 ; Modefied as per the PID Auto Tunning -- disable bang-bang mode for heater and set PWM limit
    M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
    M106 P0 S39 H-1 ; set fan 0 value. Thermostatic control is turned off
    M575 P1 S3 B115200 ; enable support for tft
    T0
    undefined 1 Reply Last reply 25 Sept 2022, 17:32 Reply Quote 0
      gloomyandy @Shadi_Polar
      @shadi_polar I think the first steps would be to make sure that your printer is actually configured how you think it is. In a console please enter: M98 P"config.g" and post the results here. Some of the settings you have seem a little strange in particular the S parameter to the M669 does not seem correct, I can't imagine what 0.01 segments per second would mean.
      I'd suggest that you should probably move the M669 command to be before you specify any other movement configuration. So I'd move it to be just after the M584 command as shown in the examples here: https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_Polar
      It would also probably help if you posted a picture of your printer (or a video of it in action) so folks have some idea what it is you are using.
      undefined 1 Reply Last reply 25 Sept 2022, 20:24 Reply Quote 0
        Shadi_Polar @gloomyandy
        @gloomyandy said in RepRap Firmware Issue in behavior:
        M98 P"config.g"
        Hi @gloomyandy I appreciate your help on this below the outcome of M98P "Config.g", I agree with you some information might be strange in my Config.g file like the S because I added it without exact knowledge of the functionality so I thought that might Improve the result. but i do not know the actual value I should add :).
        Actually this is an old project i never finish as not dedicated to however since i am working on again i would like to know how should i move on below is a picture of the machine as i was not able to upload video due to the size
        I uploaded while the machine in action however if you notice that the circle is not exactly circle it looks like defected circle you can tell however in the square it is more clearer
        9/26/2022, 12:21:35 AM M98 P"config.g"
        HTTP is enabled on port 80
        FTP is enabled on port 21
        TELNET is disabled
        Error: bad grid definition: Too many grid points; suggest increase spacing to 58.4mm
        9/26/2022, 12:17:55 AM M122
        RepRapFirmware for LPC176x based Boards (biquskr_1.4) version 3.2_4 running on LPC176x at 100Mhz
        Used output buffers: 1 of 16 (11 max)
        Static ram: 4956
        Dynamic Memory (RTOS Heap 5): 7896 free, 7856 never used
        Allocations: 178 Frees: 21
        Never used RAM 256, free system stack 14 words
        Tasks: NETWORK(ready,187) HEAT(blocked,243) MAIN(running,354) IDLE(ready,21)
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:01:25 ago, cause: [software]
        Last software reset at 2022-09-26 00:16, reason: User, GCodes spinning, available RAM 256, slot 0
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0042a000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        Supply voltage: under voltage events: 0
        Driver 0: position 0, standstill, SG min/max 0/10, error r/w 0/1, ifcnt 73, cnt r/w 7165/15, timeout 0, failedOp 0xff
        Driver 1: position 0, standstill, SG min/max 0/0, error r/w 0/1, ifcnt 68, cnt r/w 7168/12, timeout 0, failedOp 0xff
        Driver 2: position 0, standstill, SG min/max 0/18, error r/w 0/1, ifcnt 73, cnt r/w 7165/15, timeout 0, failedOp 0xff
        Driver 3: position 0, standstill, SG min/max 0/0, error r/w 0/1, ifcnt 63, cnt r/w 7169/11, timeout 0, failedOp 0xff
        Driver 4: position 0
        Driver 5: position 0
        Driver 6: position 0
        Date/time: 2022-09-26 00:17:51
        Slowest loop: 20.93ms; fastest: 0.13ms
        Step timer: target 34955404 count 84948299 delta -49992896 late 0
        USBSerial connected 0
        ADC not ready 2 ADC error threshold 10 ADC Init 1
        Ints: 51516; Calls 51516; fast: 3uS; slow 20uS adj 0 bad 0 big delta 0
        PWM Channels
        Delta -822796941 Start -1 End -1
        === Storage ===
        Free file entries: 6
        SD card 0 detected
        SD card longest read time 2.3ms, write time 0.0ms, max retries 0
        DMs created 40, maxWait 20302ms, bed compensation in use: none, comp offset 0.000
        === DDARing ===
        Scheduled moves 7, completed moves 7, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
        Bed heaters = 0, chamberHeaters = -1
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 42.51ms; fastest: 0.00ms
        Responder states: HTTP(0) HTTP(0)
        HTTP sessions: 1 of 2
        • WiFi -
          Network state is active
          WiFi firmware version 1.25-01LE-D
          WiFi MAC address c0:56:27:45:b2:f9
          WiFi Vcc 3.37, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 35944
          WiFi IP address 192.168.1.134
          WiFi signal strength -68dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00181001
          Socket states: 0 0
          Untitled.jpg20220926_230657.mp4
        1 out of 3
