ReleaseMgr DWC Plugin v1.3.3 (20-09-24)
Plugins for DWC and DSF
2.0k
    MintyTrebor
    ReleaseMgr is a DWC plugin to help with the RRF firmware updating experience.
    It enables you to view RRF related firmware & software release details inside DWC, and scans your current hardware and config.g details, highlighting information in the published RRF release notes that may impact your current configuration.
    After choosing a release, the plugin will fetch the accompanying release information, and provide links for the Release Files to download to your local machine.
    The plugin currently supports RRF, DWC, DSF (SBC), and Team Gloomy releases.
    ReleaseMgr uses the GitHub api, and requires an internet connection to be able to fetch release details.
    I am working with the Duet team to improve the matching dataset used by the plugin, so while we work out the kinks, hardware matching may not be at an acceptable accuracy level. Please highlight any matching errors in this post, so we can update the matching dataset, and amend release notes accordingly.
    Please read the Wiki for more information.
    The latest plugin files are available here
    Important Notes:
    • The plugin does not alter the standard way of updating. All files are downloaded to your local environment, and must be uploaded through DWC using the existing interface.
    • The plugin is not intelligent and its ability to match is based on how the release notes are formatted, and its ability to find matches based on your current configuration. Matches are not contextual, and the information highlighted may only be a small part of a larger change. YOU are responsible for evaluating the impact of these changes in the context of the full release details.
    Change log :
    V1.3.3 - For DWC 3.5.3
    V1.3.2 - For DWC 3.5.2
    V1.3.0 - For DWC 3.5.1
    -Updated to support the new Team Gloomy release approach
    -Updated UI
    V1.2.0 - For DWC 3.5.1
    -Updated to support DWC 3.5.1 and updated Duet release numbering approach
    V1.1.20 - For DWC 3.5.0-rc.1
    -Updated to support 3.5.0-rc.1
    V1.1.19 - For DWC 3.5.0-beta.4
    -Updated to support new Object Model Keys for SBC
    V1.1.18 - For DWC 3.5+
    • Updated to include support for new github version numbering syntax for RRF in 3.5.0-Beta.3
    • removed release versions older than 3.5 as they are redundant
    • Fixed issue with toggle button groups
    V1.1.17 - For DWC 3.5+
    • Updated to include support for new github version numbering syntax for DWC & DSF coming in 3.5.0-Beta.2
    • Added link to RRF update instructions
    • Switch plugin version number syntax to be semver 2 compliant
    v0.01.16 - NOTE for DWC 3.5+
    • Re-coded to support 3.5
    • Bug Fixes
    v0.01.15:
    • Added an auto check for firmware updates feature
    • Team Gloomy users can now access the RRF files panel if they choose to dismiss the warning.
    v0.01.14:
    Fixed issue with RC release notes displaying the correct info for DWC & DSF
    v0.01.13:
    Repackaged for 3.4 full release, minor bug fixes and layout changes.
    v0.01.12:
    Bugfixes & Improved release button layout
    v0.01.11:
    Now ignores commented out gcodes in config.g.
    Supports matching sub gcodes.
    Where possible gcodes in the RRF release notes will now hyperlink to the relevant page @ docs.duet3d.com
    Added Release Information and files for Team Gloomy ESP Wifi Firmware releases.
    NodeDSF - Native Node-Red integration with Duet boards.
    BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
    ReleaseMgr - Duet update info inside DWC.
    Repo
    undefined undefined 4 Replies Last reply 1 Mar 2022, 18:22 Reply Quote 12
      T3P3Tony administrators @MintyTrebor
      @mintytrebor thanks so much for this!
        MintyTrebor @MintyTrebor
        Published 0.01.11 Beta
        Change Log:
        • Now ignores commented out gcodes in config.g.
        • Supports matching sub gcodes.
        • Where possible gcodes in the RRF release notes will now hyperlink to the relevant page @ docs.duet3d.com
        • Added Release Information and files for Team Gloomy ESP Wifi Firmware releases.
        Repo
          New update published v0.01.13
          Changelog :
          v0.01.13:
          Note: If you install the DWC 3.3 compatible version of this plugin, and then update DWC to 3.4, you will need to update the plugin to the 3.4 compatible version for it to operate correctly.
          Repo
          undefined 1 Reply Last reply 7 Jul 2022, 15:29 Reply Quote 2
          • undefined T3P3Tony referenced this topic 4 May 2022, 04:31
          • undefined chrishamm referenced this topic 25 May 2022, 22:36
          • undefined chrishamm referenced this topic 3 Jun 2022, 10:54
          • undefined chrishamm referenced this topic 3 Jun 2022, 11:03
            New update published v0.01.14
            Changes:
            Repo
            • undefined chrishamm referenced this topic 14 Sept 2022, 14:23
              Release 0.01.15 available on GitHUb
              Added an auto check for firmware updates feature, which checks GitHub for an updated firmware version when DWC loads, and pushes an alert to the user. The feature can be enabled in settings. Users can also choose to stop duplicate alerts for the same update if desired.
              Repo
              undefined 1 Reply Last reply 24 Dec 2022, 14:14 Reply Quote 2
                Released v0.01.16 for DWC 3.5+
                Repo
                undefined 1 Reply Last reply 15 Jan 2023, 12:56 Reply Quote 4
                  Released v1.1.17 for DWC 3.5+
                  Change Log:
                  Repo
                  undefined 1 Reply Last reply 15 Apr 2023, 08:08 Reply Quote 3
                    Released v1.1.18 for DWC 3.5+
                    Change Log:
                    Repo
                    undefined 1 Reply Last reply 9 Jun 2023, 15:33 Reply Quote 0
                      Released V1.1.19 - For DWC 3.5.0-beta.4 Only
                      Change log :
                      -Updated to support new Object Model Keys for SBC in beta 4
                      Repo
                      undefined 1 Reply Last reply 2 Sept 2023, 09:24 Reply Quote 0
                        Released V1.1.20 - For DWC 3.5.0-rc.1 Only
                        Change log :
                        -Updated to support DWC 3.5.0-rc.1
                        Repo
                        undefined 1 Reply Last reply 19 Apr 2024, 11:02 Reply Quote 0
                          Released V1.1.20 - For DWC 3.5.1
                          Change log :
                          -Updated to support DWC 3.5.1 and the updated Duet release numbering approach
                          Repo
                          undefined 1 Reply Last reply 24 Apr 2024, 16:21 Reply Quote 1
                            Released v1.3.0 - For DWC 3.5.1
                            Change log :
                            -Updated UI
                            Repo
                            undefined 1 Reply Last reply 12 Jun 2024, 11:30 Reply Quote 2
                              Released 1.3.2
                              Re-Packaged for DWC 3.5.2
                              Repo
                              undefined 1 Reply Last reply 20 Sept 2024, 09:32 Reply Quote 3
                                Updated to V1.3.3 for DWC 3.5.3
                                Repo
