    RFF 3.42 DUET WIFI 1.05+DUEX0.11
    Duet Web Control
    509
    • paolozampini1973undefined
      paolozampini1973 @paolozampini1973
      @paolozampini1973 said in RFF 3.42 DUET WIFI 1.05+DUEX0.11:
      @dc42 said in RFF 3.42 DUET WIFI 1.05+DUEX0.11:
      @paolozampini1973 please send command M122 to the Duet and post the response here.
      Thanks for answering me
      console (1).txt
      Good morning. Let me know something please. Thank you
        Phaedrux Moderator @paolozampini1973
        M307 H0 B1 S2.00 normally S1 You are right but for me it is S2 Because otherwise I have problems
        M106 P1 S0 H-2 No this setting is correct for my configuration
        Both of those commands are invalid.
        Please send M98 P"config.g" and post the response.
        paolozampini1973undefined 1 Reply Last reply Reply Quote 0
          paolozampini1973 @Phaedrux
          @phaedrux said in RFF 3.42 DUET WIFI 1.05+DUEX0.11:
          M98 P "config.g"
          console (2).txt
            Your command didn't work because youhave a space between M98 P and "config.g". It must be all together.
            M98 P"config.g"
              M98 P"config.g"
              console (3).txt
              tankes
                What problems are you getting?
                Why do you say that?
                  This post is deleted!
                      Can you share a sliced gcode file?
                      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue May 04 2021 22:49:42 GMT+0200 (Ora legale dell’Europa centrale)
                      G90                                                ; send absolute coordinates...
                      M564 S1 H0                                         ; manual movement enabled H1 = forbid movement of axes , H0 allows movement of the axes , Snnn S1 = limit movement within axis boundaries, S0 = allow movement outside boundaries
                      M83                                                ; ...but relative extruder moves
                      M550   P"    PAOLO ZAMPINI"                              ; set printer name
                      M552 S1                                            ; s1 enable s0 disable network
                      M587 S"infinity" P"cccccccc" I192.168.1.15         ; IP address
                      M554 192.168.1.1                                   ; Gateway
                      M553 255.255.255.0                                 ; Netmask
                      M586 P0 S1                                         ; enable HTTP
                      M586 P1 S1                                         ; enable FTP
                      M586 P2 S0                                         ; disable Telnet
                      M569 P0 S0 R-1                                     ; X FREE physical drive 0 goes forwards
                      M569 P1 S0 R1                                      ; Y = Z1 physical drive 1 goes forwards
                      M569 P2 S1                                         ; Z2 physical drive 2 goes forwards
                      M569 P3 S1                                         ; E0 extruder 1 physical drive 3 goes forwards
                      M569 P4 S0                                         ; E1 extruder 2 physical drive 4 goes forwards
                      M569 P5 S0                                         ; A = DRIVER 5 nozzle nozzle 1.2 E2 physical drive 5 goes forwards
                      M569 P6 S0                                         ; B = DRIVER 6 nozzle nozzle 0.4 E3 physical drive 6 goes forwards
                      M569 P7 S0 R0 T4:4:8:8                             ; E4 X external drive 7 goes forwards
                      M569 P8 S1 R0 T4:4:8:8                             ; E5 Y external drive 8 goes forwards
                      ;M569 P9 S1 R-1                                    ; E6 FREE physical drive 9 goes forwards
                      M584 X7 Y8 Z1:2 A5 B6 E3:4 S0                      ; set drive mapping
                      M671 X0:0 Y0:0 S0.5                                ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                      M350 X16 Y16 Z16 A16 B16 E16:16 I1                 ; configure microstepping without interpolation
                      M92  X99.975 Y99.975 Z800.10 A3200 B3200 E95.30:95.30                ; set steps per mm
                      M566 X600.00 Y600.00 Z1400.00 A10 B10 E1500.00:1500.00               ; set maximum instantaneous speed changes (mm/min)
                      M203 X10000.00 Y10000.00 Z3500.00 A1000 B1000 E10000.00:10000.00     ; set maximum speeds (mm/min)
                      M201 X3000.00 Y3000.00 Z1400.00 A10 B10 E3000.00:3000.00             ; set accelerations (mm/s^2)
                      M906 X0 Y2000 Z2000 A800 B800 E1200:1200 I50                         ; set motor currents (mA) and motor idle factor in per cent
                      M84 S10                                                              ; Set idle timeout
                      M208 X-25 Y10 Z0 A0 B0 S1                           ; set axis minima
                      M208 X520 Y500 Z350 A61 B61 S0                      ; set axis maxima
                      M574 X0 S1 P"!xstop"                                ; configure active-LOW endstop for low end on X via pin xstop
                      M574 Y1 S1 P"!ystop"                                ; configure active-LOW endstop for low end on Y via pin ystop
                      M574 Z1 S1 P"!zstop+!e1stop"                        ; configure active-LOW endstop for low end on Z via pin null
                      M574 B1 S1 P"!duex.e2stop"                          ; DRIVER 6 E0 nozzle 0.4 WIRE COLOR RED and BROWN Wire detection detection module
                      M574 A1 S1 P"!duex.e3stop"                          ; DRIVER 5 E1 nozzle 1.2 WIRE COLOR WHITE and GREY Wire detection detection module
                      ;Filament Sensing
                      M591 P2 C"e0stop" S1 D0                            ;NOZZLE 0.4  3 PIN WIRE COLOR BLACK RED YELLOW extruder 1 nozle 0.4 s1=on s0=off D = 0 or 1 or 2 or 3 Number Sensing
                      M591 P2 C"duex.e4stop" S1 D1                       ;NOZZLE 1.2  3 PIN WIRE COLOR GREEN ORANGE YELLOW extruder 2 nozle 1.2 s1=on s0=off D = 0 or 1 or 2 or 3 Number Sensing
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138                  ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"bedheat" T0                                           ; create bed heater output on bedheat and map it to sensor 0
                      M307 H0 B1 S2.00                                                ; enable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                                         ; map heated bed to heater 0
                      M143 H0 S120                                                    ; set temperature limit for heater 0 to 120C
                      ;____________________________________________________________________________________________________________________________________
                      M308 S1 P"e0temp" Y"thermistor" T100000 B3950                   ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                                            ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00                                                ; disable bang-bang mode for heater  and set PWM limit D10= SECONDI RITARDO ERRORE
                      M143 H1 S270                                                    ; set temperature limit for heater 1 to 280C
                      M570 H1 P4 T20                                                  ; An anomaly on heater 1 must persist for 4 seconds, and must be greater or less than 20°C from the setpoint, to raise a heater fault.
                      ;_____________________________________________________________________________________________________________________________________
                      M308 S2 P"e1temp" Y"thermistor" T100000 B3950                   ; configure sensor 2 as thermistor on pin duex.e2temp
                      M950 H2 C"e1heat" T2                                            ; create nozzle heater output on !duex.e2heat and map it to sensor 2
                      M307 H2 B0 S1.00                                                ; disable bang-bang mode for heater  and set PWM limit D10= SECONDI RITARDO ERRORE
                      M143 H2 S270                                                    ; set temperature limit for heater 2 to 280C
                      M570 H2 P4 T20                                                  ;An anomaly on heater 2 must persist for 4 seconds, and must be greater or less than 20°C from the setpoint, to raise a heater fault.
                      M950 F0 C"fan0" Q600                                 ; PWM ESTRUDER E0 WIRE BLACK BLUE create fan 0 on pin fan0 and set its frequency
                      M106 P0 S0 H-1                                       ; PWM ESTRUDER E0 WIRE BLACK BLUE set fan 0 value. Thermostatic control is turned off
                      M950 F1 C"fan1" Q600                                 ; PWM ESTRUDER E1 WIRE BLACK WHITE create fan 1 on pin fan0 and set its frequency
                      M106 P1 S0 H-2                                       ; PWM ESTRUDER E1 WIRE BLACK WHITE set fan 1 value. Thermostatic control is turned off
                      M950 F2 C"fan2" Q100                                 ; F2  FAN ESTRUDER 1.2 WIRE RED BROWEN create fan 3 on pin fan0 and set its frequency
                      M106 P2 X0.6 T40  H2                                 ; F2  FAN ESTRUDER 1.2 WIRE RED BROWEN set fan 3 value. Thermostatic control is turned off
                      M950 F3 C"duex.fan3" Q65535                          ; F3  FAN ESTRUDER 0.4 WIRE RED BLACK create fan 3 on pin fan0 and set its frequency
                      M106 P3 S1 H1 T30                                    ; F3  FAN ESTRUDER 0.4 WIRE RED BLACK set fan 3 value. Thermostatic control is turned off
                      M950 F4 C"duex.fan4" Q600                            ; F4  DUAL LED BED create fan 4 on pin fan0 and set its frequency
                      M106 P4 S1 H1:2 T180                                 ; F4  DUAL LED BED set fan 4 value. Thermostatic control is turned off
                      M950 F5 C"duex.fan5" Q500                            ; FAN 5 X create fan 5 on pin fan1 and set its frequency
                      M106 P5 S1 H-1                                       ; FAN 5 X set fan 5 value. Thermostatic control is turned on
                      M950 F6 C"duex.fan6" Q500                            ; FAN 6 Y create fan 6 on pin fan1 and set its frequency
                      M106 P6 S1 H1:2 T20                                  ; FAN 6 Y set fan 6 value. Thermostatic control is turned on
                      M950 F7 C"duex.fan7" Q65535                          ; FAN 7 Duex 0.11 create fan 7 on pin fan1 and set its frequency
                      M106 P7 S255 H-1                                     ; FAN 7 Duex 0.11 set fan 7 value. Thermostatic control is turned on
                      M950 F8 C"duex.fan8" Q65535                          ; FAN 8 DUET WIFI create fan 8 on pin fan1 and set its frequency
                      M106 P8 S1 H-1;:2 T180                               ; FAN 8 DUET WIFI set fan 8 value. Thermostatic control is turned on
                      M563 P0 D0 H1 F0 S"nozzle 0.4 MM"                   ; define tool 0
                      G10 P0 X0 Y0 Z0                                     ; set tool 0 axis offsets
                      G10 P0 R0 S0                                        ; set initial tool 0 active and standby temperatures to 0C
                      M563 P1 D1 H2 F1 S"nozzle 1.2 MM"                   ; define tool 1
                      G10 P1 X0 Y0 Z0                                     ; set tool 1 axis offsets
                      G10 P1 R0 S0                                        ; set initial tool 1 active and standby temperatures to 0C
                      M575 P1 S1 B57600                                  ; enable support for PanelDue
                      T0                                                 ; select first tool
                      M302 S20 R20
                      ;M572 D4 SS0.025                                   ;nozzle 0.4
                      ;M572 D3 SS0.025                                   ;nozzle 1.2
                      M501                                               ; load saved parameters from non-volatile memory
                        @phaedrux thanks I solved I simply got a command wrong on the silicer
