    Elegant way to cancel a print during start
    Gcode meta commands
    639
      jay_s_uk
      I'm adding some checks to my start print file and would like to be able to abort a print if some criteria aren't met (such as nozzle diameter, missing parameters etc).
      I'm not sure what the most appropriate way to do this is.
      I could use M226 to pause the print and then cancel it, but I don't want pause.g or cancel.g to be ran as the printer isn't even in a state where running those would be sensible.
      Does anyone know of a better way to achieve this?
      • chrishammundefined
        chrishamm administrators @jay_s_uk
        @jay_s_uk I invoke a macro file check-filament.g from my start G-code to check the loaded filament (M98 P"check-filament.g" F"PLA" e.g.). It's simple as this:
        if move.extruders[0].filament != param.F
          abort "Incorrect filament loaded!"
        That will effectively abort the print if the wrong filament is loaded without running any pause/stop macros.
        Duet software engineer
        sinned6915undefined 1 Reply Last reply Reply Quote 6
          jay_s_uk
          @chrishamm fantastic. I'll give that a go now
          • jay_s_ukundefined jay_s_uk marked this topic as a question
          • jay_s_ukundefined jay_s_uk has marked this topic as solved
          • Phaedruxundefined Phaedrux moved this topic from General Discussion
          • sinned6915undefined
            sinned6915 @chrishamm
            @chrishamm said in Elegant way to cancel a print during start:
            How would this work? What is the piece that you are looking at to compare in the logic statement?
            Where/How are you defining the filament?
            sinneD
              chrishamm administrators @sinned6915
              @sinned6915 It's the F parameter passed to the check-filament.g macro, see the first line. My start G-code looks like this (PrusaSlicer):
              M98 P"check-filament.g" F"[filament_type]"
              M140 S[first_layer_bed_temperature]
              M116 ; wait for all temps to be reached
              T0 ; select first tool
              M703 ; configure it
              G10 P0 S[first_layer_temperature] ; set nozzle temperature
              G28 ; home all axes
              G1 X235 Y5 F30000 ; go to corner of the bed
              G1 Z0.5 ; lower nozzle
              Note that you need to create filaments in DWC and PrusaSlicer where the name must equal the value defined in PS -> Filament -> Advanced -> Type.
              sinned6915undefined 1 Reply Last reply Reply Quote 1
                @chrishamm so do you you use the 'Filaments' to do things like organize, track usage, retraction and such too?
                OwenDundefined 1 Reply Last reply Reply Quote 0
                • OwenDundefined
                  OwenD @sinned6915
                  @sinned6915
                  Yes, the filaments folders are being used.
                  If you look at the start g code there is an M703.
                  Anything filament specific would be implemented in the filament config.g
                  • Diamondbackundefined
                    Diamondback
                    Fantastic idea, I will certainly add this to my setup! 🙂
                      Diamondback
                      Does anyone have an idea how I can detect in PrusaSlicer which tools will be used during a print? I'm already sending over the filaments and the nozzle sizes, but since I have a toolchanger, ideally I'd also need to know which tools are used during a given print...
