    Lite6 mounting on smart effector?
    Smart effector for delta printers
    1.0k
    • sungod3kundefined
      sungod3k
      Im trying to get a 2 in 1 out setup going and one of the recomendations is to use a lite6 rather than v6.
      That in mind I just checked if the traditional horseshoe/groovemount would work with the 3 spare holes but it doesnt.
      So before I start designing a custom groovemount that fits the smart effector does anyone have another (maybe simpler) suggestion on how to mount that?
      Cheers
      http://www.42dimensions.de/
      https://printnewworlds.blogspot.com/
      • DjDemonDundefined
        DjDemonD
        Not exactly but to get it to work you'll need to ensure (especially if you use the 3 holes to mount some sort of adaptor) it will have to transmit vertical forces through the centre of the smart effector for it to trigger.
        www.precisionpiezo.co.uk
        • raykholoundefined
          raykholo
          Search for "v6 throat" on aliexpress and get the kind with a full 4.1mm bore. That's actually what the TL pics illustrate if you look closely.
          I'll reply to your other thread when I'm at PC.
          • sungod3kundefined
            sungod3k
            I Didnt consider that because of my high volume extrusion experiments i stopped using china heatbreaks. That makes things much easier.
            I just looked through my spare parts but the only one that has a 4mm internal bore only has an m6 thread.
            You mean this here (1st pic on the right) right?
            https://de.aliexpress.com/item/5-pcs-bowden-wade-V6-hotend-Heat-Break-Throat-for-1-75-3-00-mm-Filament/32810212860.html?ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10344_10068_10345_10342_10343_10340_10341_10541_10084_10083_10560_10304_10307_10301_10177_10060_10155_10154_10056_10055_10539_10537_10312_10536_10059_10313_10314_10534_10533_100031_10103_10073_10102_10557_10142_10107,searchweb201603_14,ppcSwitch_5&btsid=aabb659f-9408-49b9-b2e5-55db3223c7ca&algo_expid=efac3a8a-e51d-4f70-87a2-fdb47a0a195b-0&algo_pvid=efac3a8a-e51d-4f70-87a2-fdb47a0a195b
            • raykholoundefined
              raykholo
              On your link, I mean the rightmost one labeled 4.1, yes. "41 without ptfe".
              I just ordered:
              https://www.aliexpress.com/item/5pcs-Lot-Stainless-Steel-V6-Throat-For-1-75-mm-3mm-Filament-3D-Printers-Parts-With/32806791964.html
              • PlasticMetalundefined
                PlasticMetal
                FWIW I asked E3D a few weeks ago about sinks for the SE, and was told the V6 version will eventually be sold individually, but they had no plans to make a Lite version compatible with the SE.
                • sungod3kundefined
                  sungod3k
                  Shame. Ill try china then.
