Duet 3 External IO input trigger
    M7460
    Hi ,
    I’m struggling to get an external trigger to work on my duets 3 board.
    I have tried lots of things now...
    Can some help with explains how to wire the trigger : what pins to use .... I can get a trigger to work if i use the IOin (get 24V from a PLC) and GND but this only works with 1 trigger when i add a second it doesn’t work ...
    I have also tried using a relay and connecting IOin and GND together this works well as i no longer is false triggers when triggering the second IO but again I can’t get 2 triggers to work...
    As I’m using a Solid state relay i can give the board what any signal it wants to see ! I welcome advice.
    Config
    M950 J2 C"io3.in"
    M581 P2 S0 T0 R0 ; e-stop
    M950 J3 C"io4.in"
    M581 P2 S0 T2 R0 ; 2trigger.g
    undefined 1 Reply Last reply 1 Nov 2022, 19:53 Reply Quote 0
      dc42 administrators @M7460
      @M7460 said in Duet 3 External IO input trigger:
      The trigger macro file name will be trigger2.g not 2trigger.g.
      undefined 1 Reply Last reply 2 Nov 2022, 08:17 Reply Quote 0
        M7460 @dc42
        @dc42 Thanks that was a typo , I can get a file to trigger , but not using 24v . Can you please help with that part ?
        Thanks
        undefined 1 Reply Last reply 8 Nov 2022, 13:41 Reply Quote 0
          @M7460 are you saying that it works with io3.in but not with io4.in?
          What exactly have you connected to io3.in and io4.in?
          undefined 1 Reply Last reply 29 Nov 2022, 15:58 Reply Quote 0
            M7460 @dc42
            A KUKA robot , it seems i was getting ''NOISE'' I have now contacted via a relay ! sorted
