    DuetLapse3
    Third-party software
    20
    296
    30.9k
    • stuartofmtundefined
      stuartofmt @T3P3Tony
      @t3p3tony said in DuetLapse3:
      @stuartofmt Yes they main point from the front end is it brings it into the structure of plugins ......
      Can you point me to a "step by step" document / example? I've searched and searched but all I seem to find is descriptions of folder structures within a zip file, or git references that are just source code. I get that bit (more or less).
      What's missing for me is a clear explanation of what goes in which folder, how those components need to be structured (internally) , and the structure (and switch meaning) for the main config file. Especially: what is the mechanism for linking to the http interface.
      I've made some interim changes to my code to support the idea of its own configuration file (previously all cmd line). I need to understand what other changes may be needed.
      Thx in advance.
      • chrishammundefined
        chrishamm administrators @stuartofmt
        @stuartofmt You can find current documentation about plugins here:
        • for DSF: https://github.com/Duet3D/DuetSoftwareFramework/wiki/Third-Party-Plugins
        • for DWC: https://github.com/Duet3D/DuetWebControl/wiki/Third-Party-Plugins
          There is an automated build script for DWC plugins as well, it should be described in the second link, too.
        DWC is being heavily changed at the moment but as a general starting point I suggest you read through these two articles and have a look at either the endstops plugin or the motion webcam server plugins. In both repos you can find a short README section explaining how they can be built.
        Duet software engineer
        • osteracundefined
          osterac
          Hi
          This is a great solution for timelapses. Thanks!
          I was wondering how I can change the webcam capture resolution. I read through the documentation but some of it was a bit over my head. My camera is capable of 1440p but duetlapse3 records at 720p. I think 1080p would be a good resolution for my videos. I use this command to start duetlapse3:
          sudo python3 /home/pi/ftp/files/DuetLapse/DuetLapse3.py -duet 192.168.1.8 -deletepics -seconds 20 -fps 30  -detect none -restart -camera1 web -weburl1 http://192.168.1.30/picture/2/current/ -extratime 3 -basedir /home/pi/ftp/files/DuetLapse -standby
          Thanks!
          PS I think a great addition would be an option to set how long the video will be and automatically adjust settings so it always comes out that length. This way you don't get timelapses of short prints that are only a few seconds long, and really long prints won't be too long and slow. Octolapse has this feature.
          stuartofmtundefined 1 Reply Last reply Reply Quote 0
            stuartofmt @osterac
            @osterac said in DuetLapse3:
            Hi
            PS I think a great addition would be an option to set how long the video will be and automatically adjust settings so it always comes out that length. .......
            DuetLapse uses ffmpeg to "stitch" together the individual frames. The primary resolution is set by the software controlling the camera. In your case, this is whatever is serving up images at http://192.168.1.30/picture/2/current/. That is where you will have the control over resolution.
            I do have a companion program videostream which allows the resolution to be changed for most usb cameras (and Pi cameras).
            https://forum.duet3d.com/topic/23759/videostream/12
            On the question of video length. In a naïve way - x seconds of fixed length video would be easy to achieve. Number of images / fixed length = fps. Whether the results would be pleasing to the eye might be a value judgement. 😵
            I'm guessing this is what Octolapse does?
            osteracundefined 1 Reply Last reply Reply Quote 0
            • osteracundefined
              osterac @stuartofmt
              @stuartofmt
              I dug up some old octolapse videos and they were all at different framerates so yes, it does work that way. I looked at my webcam (motioneye) settings and it was set to 1440p. I set it to 1080p and the video was still 720p. It also had problems, it started in the middle of the print and skipped forward and backward a couple of times. It was also at 10 FPS when I requested 30 FPS. Here's the media info:
              Video
              Format : AVC
              Format/Info : Advanced Video Codec
              Format profile : High@L3.1
              Format settings : CABAC / 4 Ref Frames
              Format settings, CABAC : Yes
              Format settings, Reference frames : 4 frames
              Codec ID : avc1
              Codec ID/Info : Advanced Video Coding
              Duration : 25 s 300 ms
              Bit rate : 1 975 kb/s
              Width : 1 280 pixels
              Height : 720 pixels
              Display aspect ratio : 16:9
              Frame rate mode : Constant
              Frame rate : 10.000 FPS
              Color space : YUV
              Chroma subsampling : 4:2:0
              Bit depth : 8 bits
              Scan type : Progressive
              Bits/(Pixel*Frame) : 0.214
              Stream size : 5.96 MiB (100%)
              Writing library : x264 core 155 r2917 0a84d98
              Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=10 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
              Color range : Full
              Codec configuration box : avcC
              I'll give videostream a try, do I install it on the webcam server or the pi running Duetlapse 3? I don't think I could install it on motioneye, because it's buildroot. You can install motioneye on top of a full linux distro though.
              Here's a link to the faulty timelapse:
              https://1drv.ms/v/s!ArZNmx9oeG5CzQKqBpTQqJG-LFmP?e=7BoTKS
              Thanks
                stuartofmt @osterac
                @stuartofmt
                Video
                Format : AVC
                Codec ID : avc1
                Height : 720 pixels
                Color space : YUV
                Bit depth : 8 bits
                Color range : Full
                Thanks
                osteracundefined stuartofmtundefined 2 Replies Last reply Reply Quote 0
                • osteracundefined
                  osterac @stuartofmt
                  @stuartofmt
                  Did you mean to make a post with only a quote of me in it?
                    stuartofmt @stuartofmt
                    @stuartofmt
                    Hmm - let me ponder the resolution side of things.
                    The frame-rate ought to follow the settings. I'm wondering if there is a problem with ffmpeg (would not be the first time). What version are you running ffmpeg -version will tell
                    I've bever seen a video jump around like that. The -camera1 web setting uses wget to retrieve the images. Afterwards ffmpeg creates the video by taking the frames in sequence. I'm wondering if there is some sort of strange timing issue?
                    As an experiment we can get the images using ffmpeg. This is my usual way, mainly because it exercises more of the code. What happens if you use this set of options?:
                    -weburl1 http://192.168.1.30/picture/2/current/ -camera1 other -camparam1="'ffmpeg ' + ffmpegquiet + ' -y -i ' +weburl+ ' -vframes 1 ' +fn+debug"
                      stuartofmt @osterac
                      @stuartofmt
                      Yes 😖 See above
                      osteracundefined 2 Replies Last reply Reply Quote 0
                      • osteracundefined
                        osterac @stuartofmt
                        @stuartofmt
                        ffmpeg-version didn't work, so I typed sudo apt install ffmpeg and it said it was already installed with this version:
                        7:4.1.9-0+deb10u1+rpt1)
                        I tried your settings (I took the liberty of adding the duet url) and the print stopped early both times I tried. There weren't enough frames captured to make a timelapse of at least 5 seconds. The printer told me that insufficient axes were homed.
                        pi@octopi:~ $ sudo python3 /home/pi/ftp/files/DuetLapse/DuetLapse3.py -weburl1 h               ttp://192.168.1.30/picture/2/current/ -camera1 other -camparam1="'ffmpeg ' + ffm               pegquiet + ' -y -i ' +weburl+ ' -vframes 1 ' +fn+debug" -duet 192.168.1.8
                        [sudo] password for pi:
                        192.168.1.8 MainThread - ################### Options at start of this print job                 #####################
                        192.168.1.8 MainThread - # Environment
                        192.168.1.8 MainThread - duet                 192.168.1.8
                        192.168.1.8 MainThread - basedir              /home/pi/ftp/files/DuetLapse
                        192.168.1.8 MainThread - poll                 12
                        192.168.1.8 MainThread - instances            single
                        192.168.1.8 MainThread - logtype              both
                        192.168.1.8 MainThread - nolog                False
                        192.168.1.8 MainThread - verbose              False
                        192.168.1.8 MainThread - host                 0.0.0.0
                        192.168.1.8 MainThread - port                 0
                        192.168.1.8 MainThread - keeplogs             False
                        192.168.1.8 MainThread - novideo              False
                        192.168.1.8 MainThread - deletepics           False
                        192.168.1.8 MainThread - maxffmpeg            2
                        192.168.1.8 MainThread - keepfiles            False
                        192.168.1.8 MainThread - # Execution
                        192.168.1.8 MainThread - dontwait             False
                        192.168.1.8 MainThread - seconds              0
                        192.168.1.8 MainThread - detect               layer
                        192.168.1.8 MainThread - pause                no
                        192.168.1.8 MainThread - movehead             [0.0, 0.0]
                        192.168.1.8 MainThread - rest                 1
                        192.168.1.8 MainThread - standby              False
                        192.168.1.8 MainThread - restart              False
                        192.168.1.8 MainThread - # Camera
                        192.168.1.8 MainThread -  camera1             other
                        192.168.1.8 MainThread - camera2
                        192.168.1.8 MainThread - weburl1              http://192.168.1.30/picture/2/curr               ent/
                        192.168.1.8 MainThread - weburl2
                        192.168.1.8 MainThread - # Video
                        192.168.1.8 MainThread - extratime            0
                        192.168.1.8 MainThread - fps                  10
                        192.168.1.8 MainThread - minvideo             5
                        192.168.1.8 MainThread - # Overrides
                        192.168.1.8 MainThread - camparam1            'ffmpeg ' + ffmpegquiet + ' -y -i                ' +weburl+ ' -vframes 1 ' +fn+debug
                        192.168.1.8 MainThread - camparam2
                        192.168.1.8 MainThread - vidparam1
                        192.168.1.8 MainThread - vidparam2
                        192.168.1.8 MainThread - # UI
                        192.168.1.8 MainThread - hidebuttons          False
                        192.168.1.8 MainThread - # Special Functions
                        192.168.1.8 MainThread - execkey
                        192.168.1.8 MainThread - -------------------------------------------------------               ----------------
                        192.168.1.8 MainThread - #######################################################               ###
                        192.168.1.8 MainThread - Will start capturing images on first layer change
                        192.168.1.8 MainThread - Video will be created when printing ends
                        192.168.1.8 MainThread - or if requested from the browser interface or M117 Duet               Lapse3. message
                        192.168.1.8 MainThread - If running from a console using the command line
                        192.168.1.8 MainThread - Press Ctrl+C one time to stop the program and create a                video.
                        192.168.1.8 MainThread - #######################################################               ########
                        192.168.1.8 MainThread - Connected to printer at 192.168.1.8
                        192.168.1.8 MainThread - Using Duet version 3.4.1
                        192.168.1.8 MainThread - Using  API interface rr_model
                        192.168.1.8 gcodeLoop - ###########################
                        192.168.1.8 MainThread - Initiating with action set to start
                        192.168.1.8 gcodeLoop - Starting gcode Listener
                        192.168.1.8 MainThread - ++++++ start state requested ++++++
                        192.168.1.8 captureLoop - ****** Duet status changed to: Not yet determined ****               *
                        192.168.1.8 MainThread - ++++++ Entering start state ++++++
                        192.168.1.8 captureLoop - ****** Print State changed to: Waiting *****
                        192.168.1.8 captureLoop - ****** Duet status changed to: idle *****
                        192.168.1.8 captureLoop - ****** Print State changed to: Capturing *****
                        192.168.1.8 captureLoop - ****** Duet status changed to: processing *****
                        192.168.1.8 gcodeLoop - M117 Command: DuetLapse3.start
                        192.168.1.8 gcodeLoop - Already in start state
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 1 at layer 1 after la               yer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 2 at layer 2 after la               yer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 3 at layer 3 after la               yer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 4 at layer 4 after la               yer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 5 at layer 5 after la               yer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 6 at layer 7 after la               yer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 7 at layer 9 after la               yer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 8 at layer 11 after l               ayer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 9 at layer 13 after l               ayer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 10 at layer 15 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 11 at layer 17 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 12 at layer 20 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 13 at layer 22 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 14 at layer 24 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 15 at layer 26 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 16 at layer 29 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 17 at layer 32 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 18 at layer 34 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 19 at layer 37 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 20 at layer 40 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 21 at layer 42 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 22 at layer 45 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 23 at layer 48 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 24 at layer 50 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 25 at layer 52 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 26 at layer 55 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 27 at layer 57 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 28 at layer 59 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 29 at layer 61 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 30 at layer 63 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 31 at layer 66 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 32 at layer 68 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 33 at layer 70 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 34 at layer 72 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 35 at layer 73 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 36 at layer 74 after                layer change
                        192.168.1.8 captureLoop - Layer - Camera1: capturing frame 37 at layer 75 after                layer change
                        192.168.1.8 captureLoop - M117 Command: DuetLapse3.completed
                        192.168.1.8 captureLoop - nextAction is available
                        192.168.1.8 nextAction - ++++++ completed state requested ++++++
                        192.168.1.8 terminate - Terminating
                        192.168.1.8 nextAction - ++++++ Entering terminate state ++++++
                        192.168.1.8 makeVideo - Command Success : ffmpeg  -loglevel quiet -y -i http://1               92.168.1.30/picture/2/current/ -vframes 1 /home/pi/ftp/files/DuetLapse/octopi/19               2-168-1-8/19613_CE4_Cylindar_MORE_twisted2/Camera1_00000038.jpeg > /dev/null 2>&               1
                        192.168.1.8 makeVideo - Create Video from /home/pi/ftp/files/DuetLapse/octopi/19               2-168-1-8/19613_CE4_Cylindar_MORE_twisted2
                        192.168.1.8 makeVideo - Error: Camera1: Cannot create video of less than 5 secon               ds.
                        192.168.1.8 terminate - ********* Waiting for captureLoop to complete *********
                        192.168.1.8 terminate - Exited captureLoop
                        192.168.1.8 terminate - nextAction is available
                        192.168.1.8 terminate - Wait for video to complete
                        192.168.1.8 terminate - makeVideo is not running
                        192.168.1.8 terminate - Cleaning up files for phase:  terminate
                        192.168.1.8 terminate - gcodeLoop is not running
                        192.168.1.8 terminate - Could not terminate http listener
                        192.168.1.8 terminate - name 'listener' is not defined
                        192.168.1.8 terminate - Program Terminated
                        Killed
                        • osteracundefined
                          osterac @osterac
                          @stuartofmt
                          The stopping early thing was actually a problem with my end gcode.
                            stuartofmt @osterac
                            @osterac
                            I'm using version 4.x of ffmpeg, only because I had to compile it some time ago for the Pi. With V7 you should 🤞 be OK.
                            You should take a look at the captured images to see what resolution they are (with the alternate capture options I provided).
                            I'll wait until you generate a video and we can take a look to see if anything changed.
                            As an aside (and I will check), to the best of my knowledge the video creation command does not alter the resolution at all. I did check some of my captures (set to 800x600 in videostream) and the video resolution matches.
                            • osteracundefined
                              osterac @stuartofmt
                              @stuartofmt
                              I managed to capture a time lapse with your settings on a longer print.
                              https://1drv.ms/v/s!ArZNmx9oeG5CzQMVW0IGIgVbwagj?e=QrnVhR
                              Don't know why my printer is making little poops, but whatever. That's a different issue.
                              • osteracundefined
                                osterac @osterac
                                @stuartofmt
                                The captured images are 720p
                                  stuartofmt @osterac
                                  @stuartofmt
                                  Its hard to say - but it looks like excess filament is adhering to the nozzle then dropping off. You might have the nozzle a tad too hot (the initial bridging is drooping quite a bit over that short distance).
                                  In any case - there is a very complete set of calibration steps here:
                                  https://www.youtube.com/watch?v=kgCjDy_IgXg
                                    stuartofmt @osterac
                                    @stuartofmt
                                    Ok - so there you have it. Motioneye is serving up the images at 720p (1280 x 720).
                                    I did a print last night and set the resolution (in videostream) to 1920x1080. It worked as expected, creating the same resolution in the individual images and the resulting video.
                                    I realize that I did not answer one of your earlier questions: videostream is installed on the computer to which the camera is attached i.e. USB or direct.
                                    Are you using an IP camera? If so - you will likely need to wrestle with motioneye settings to get the video stream to the resolution you want. If the camera can be used (without motioneye in the middle) as a USB camera then videostream will likely work.
                                    Video cameras are inconsistent from one setup to another.
                                    This may help (in the case of a USB camera):
                                    https://github.com/stuartofmt/Pi-Notes/blob/master/Resolution Testing.md
                                    • osteracundefined
                                      osterac @stuartofmt
                                      @stuartofmt I think I will load pi os on my webcam server and install motioneye on top of that. That way I can use videostream, and it will be a newer version of motioneye.
                                        stuartofmt @osterac
                                        What type of camera do you have? Is it USB? Or is motioneye embedded in the camera itself and provides http access ?
                                        The reason I ask is that you likely don't want motioneye and videostream both. One or the other.
                                        • osteracundefined
                                          osterac @stuartofmt
                                          @stuartofmt it's a pi 4 with 2 USB webcams. I'll hold off with videostream then.
                                            stuartofmt @osterac
                                            Once you get the resolution set correctly (with motioneye) you should be fine.
                                            I'm working on DuetLapse as a plugin (The DuetLapse code will be common.) . I'll add in the fixed duration option as part of that effort. Fitting it in with other things at the moment - so could be a few weeks . 🤞
