Solved After upgrading Duet Wifi to 3.0 Wifi connection cannot be setup
After upgrading Duet Wifi to V3.0 by installing Duet2and3Firmware-3.0.zip I cannot connet to a WiFi network. I also generated a basic config-file with the config tool incl. Wifi-Setup. But it does not work.
Do you have any hints for me?Best regards
Holger -
It would help to see what you have in your config.g, the results of sending M122 to get a diagnostic report, and what happens when you send M552 S-1. M552 S0. M552 S1.
It's possible that the wifi module didn't flash correctly during the update, in which case you can re-flash it by sending M997 S1
Thanks a lot for your fast reply! Couldn't test before today. With your help it is working now. Reinstalling firmware to WiFi module has solved the problem!
Thanks a lot!Best regards
Holger -
