    Homeall.g pauses in front of the Z Home for about 15 seconds
    RepRapFirmware on other controllers
    401
    • Proschi3Dundefined
      Proschi3D
      when pressing all axes Homen. Homed he x y u and then pauses for 15 seconds before homed the z axis.
      ; homeall.g
      ; called to home all axes
      M561
      G91
      G1 H2 Z5 F6000 ; raise head 4mm to keep it clear of the bed
      G1 H1 X-35 Y-400 U355 F3000 ; coarse home X, Y and U
      G1 H2 X4 Y4 U-4 F3000  ; move 4mm away from the homing switches
      G1 H1 X-400 Y-10 U400 F600      ; fine home X, Y and U
      G91
      ; Now home Z using the Z probe
      G1 H2 X170 Y110 F3000  ; move to bed centre for probing
      G30 ; probe the bed and set Z height
      G1 H1 X-400 Y-400 U400 F3000
      G90
      G29 S1
      Homez
      G91 ; relative mode
      G1 H2 Z4 F2000 ; raise head 4mm to ensure it is above the Z probe trigger height
      G90 ; back to absolute mode
      G1 H2 X170 Y110 F6000 ; put head over the centre of the bed, or wherever you want to probe
      G30 ; lower head, stop when probe triggered and set Z to trigger height
      G1 H1 X-35 U355 F3000
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
        Phaedrux Moderator @Proschi3D
        @Proschi78 said in Homeall.g pauses in front of the Z Home for about 15 seconds:
        ; Now home Z using the Z probeG1 H2 X170 Y110 F3000 ; move to bed centre for probing
        Do not use H2 for this move. H2 is only needed when you are trying to move an axis that has not yet been homed, such as when you want to lift the Z axis slightly before an XY travel move.
        You're also sending another homing move for XYU after homing Z. Is that actually intentional?
        For example, your file should probably look like this instead.
        ; homeall.g
        M561
        G91
        G1 X4 Y4 U-4 F3000  ; move 4mm away from the homing switches
        G90 ; absolute positioning
        G1 X170 Y110 F3000  ; move to bed centre for probing
        G29 S1
        Proschi3Dundefined 1 Reply Last reply Reply Quote 1
          Proschi3D @Phaedrux
          @Phaedrux I tried it
          ; homeall.g
          M561
          G91
          G29 S1
          the pause before the Z Homen is still there.
          i homed x y u to z again so that the extruder is not in the middle of the table
            Is it pausing before it moves to the probe point, or is it pausing before it does the g30 to probe?
            Try this one with some messages inserted so we can see what point it's pausing on.
            M561
            G91
            M117 Homing XYU
            M117 XYU homed
            M117 Moving to center
            M117 Moved to Center
            M117 Probing Z
            M117 Probed Z
            G29 S1
            In that case just use a normal G1 move without an H parameter.
            Proschi3Dundefined 2 Replies Last reply Reply Quote 1
              Proschi3D @Phaedrux
              @Phaedrux
              I just found the bug.
              M561
              G91
              G1 H1 X-35 Y-245 U355 F3000 ; coarse home X, Y and U
              G1 H1 X-400 Y-10 U400 F600        **y-10 instead of Y-245**
              G1 x-35 y-245 U365 F3000
              G29 S1
              then the Y axis was not at zero but +4
                Proschi3D @Phaedrux
                @Phaedrux Now the homing runs cleanly.
                Thank you for your help.
                M561
                G91
                G1 H1 X-400 Y-245 U400 F600      ; fine home X, Y and U
                G29 S1
                  G1 H1 X-35
                  Is that a long enough of a move to ensure the X endstop is hit?
                    Proschi3D @Phaedrux
                    @Phaedrux yes the x and u limit switch is hit.
                    Unfortunately, because I have little space to install something to clean the nozzles
                      What if your farther than 35mm away from the endstop?
                      Generally it's best practice to have the homing move by at least as long as the length of the axis.
                        Proschi3D @Phaedrux
                        @Phaedrux I have extended the way thank you
                        • dc42undefined dc42 marked this topic as a question
                        • dc42undefined dc42 has marked this topic as solved
