    Unexpected behaviour - 3.5.0b1
    Beta Firmware
    • OwenDundefined
      OwenD
      I was pondering doing PID auto-tuning from a macro and how to cancel the tuning mid way.
      According to the docs, sending M0 would do so (which it does in 3.4.5)
      I tried to use the new M291 functions in 3.5.0b1 to allow for the macro to continue after "Cancel" had been pressed.
      Here is my macro
      M303 T0 P1 S240 F1 Q1
      while heat.heaters[1].state = "tuning"
      	if state.messageBox = null
      		M291 R"Tuning" P"Tuning in progress" S4 K{"OK","Cancel"}
      	if {input = 1}
      		M0
      		M99
      M291 R"Finished tuning" P"OK to save results, cancel to discard" S3
      M500
      However when I press "Cancel" I get an error
      Error: M0: Pause the print before attempting to cancel it
      Despite no print being in progress.
      If I add M25 before the M0 then I get
      Error: Cannot pause print, because no file is being printed!
      Error: Pause the print before attempting to cancel it
      If I add abort prior to M0, it suppresses the errors, but tuning is not cancelled.
        dc42 administrators @OwenD
        @OwenD thanks, I'll list this as a known issue. I'll probably replace the use of M0 to cancel tuning by M303 H-1 or something like that.
        OwenDundefined 1 Reply Last reply Reply Quote 1
          @OwenD I had forgotten that M0 cancels tuning. Does M0 sent manually work to cancel tuning in 3.5b1?
          OwenDundefined 2 Replies Last reply Reply Quote 0
          • OwenDundefined
            OwenD @dc42
            No, M0 doesn't cancel tuning in 3.5.0 even from console
            • OwenDundefined
              OwenD @dc42
              Also M0 didn't give any errors about cancelling the print first in 3.4.5
                  @OwenD PS - where do the docs say that M0 cancels heater tuning? Found it!
                  • OwenDundefined
                    OwenD @dc42
                    @dc42 said in Unexpected behaviour - 3.5.0b1:
                    That would make more sense in my mind as it avoids stop.g being run.
                    I'll mark this as solved for now.
                    • OwenDundefined OwenD has marked this topic as solved
                    • OwenDundefined OwenD referenced this topic
                    • droftartsundefined droftarts referenced this topic
