echo commands
Firmware wishlist
428
    Aitor
    Good morning to all,
    I would like to request a new function for echo commands.
    Currently echo>> writes to a new line of the specified file, but I would like to be able to write to the end of the last line for example using echo>>>, this way I would have no problem writing longer lines and I think it would consume less resources than increasing the number of characters allowed in a single line.
    This could be used to write comments or in my case to generate a superlicer profile automatically from the machine.
    By the way I love the new features of the M291.
    Best regards
    Aitor
    undefined 1 Reply Last reply 30 Dec 2022, 16:02 Reply Quote 1
    • undefined T3P3Tony moved this topic from Beta Firmware 30 Dec 2022, 10:57
      Aitor
      Good morning @T3P3Tony,
      Thanks for moving the conversation, I didn't see that this title existed.
      I guess this is something that @DC42 should see, can you tell me if this is a good idea and if you see it possible for 3.5beta2? I have to go planning a route of changes in our machines for 2023 and knowing if this could be implemented would help me a lot.
      Greetings and happy new year to all the DUET3D team.
      Aitor
        dc42 administrators @Aitor
        @Aitor since the newline is added at the end of the string added by echo >> we would need to do it the other way round, i.e. have a variant of the echo command that does not add the newline at the end, on the assumption that you will follow it eventually with an echo command that does add the newline.
        How long is the string that you need to write as a single line?
          Aitor
          Good morning @DC42,
          I think I have not understood well what you say, possibly the translator is confusing me a bit, so I'll explain better what I want to achieve.
          These are some of the lines of code I have to generate with which I have the problem:
          start_gcode = M190 S{first_layer_bed_temperature}\nG10 P0 S{first_layer_temperature[0]} R{temperature[0]}\nG10 P1 S{first_layer_temperature[1]} R{temperature[1]}\nM98 P"ginicioMIRROR.g"
          compatible_printers = "NX PRO HR-HR_Left_Left Only"; "NX PRO HR-HR_Right Only"; "NX PRO HR-HR_Dual"; "NX PRO HR-HR_Copy"; "NX PRO HR-HR_Mirror"
          output_filename_format = {input_filename_base}_T0_{filament_type[0]}_{nozzle_diameter[0]}_T1_{filament_type[1]}_{nozzle_diameter[1]}.gcode
          my idea to be able to write this in a single line, without having the problem of number of characters, would be something like this:
          echo >>"ini" "start_gcode = M190 S{first_layer_bed_temperature}"
          echo >>>"ini" "\nG10 P0 S{first_layer_bed_temperature[0]} R{temperature[0]}"
          echo >>>"ini" "\nG10 P1 S{first_layer_temperature[1]} R{temperature[1]}"
          echo >>>"ini" "\nM98 P""ginicioMIRROR.g"""
          to output as a single line:
          If you don't understand something let me know
          Best regards
          Aitor
          undefined 1 Reply Last reply 30 Dec 2022, 17:22 Reply Quote 0
            T3P3Tony administrators @Aitor
            @Aitor whats the reason fro embedding the new line characters into a single line?
            undefined 1 Reply Last reply 30 Dec 2022, 22:19 Reply Quote 0
              dc42 administrators @T3P3Tony
              @T3P3Tony I recall that some slicers expect a single line with the literal character sequence "\n" (not newline) between commands.
              undefined 1 Reply Last reply 2 Jan 2023, 08:31 Reply Quote 0
                Aitor @dc42
                It is as @DC42 says, superlicer that is this case, does not allow me to separate lines, I am also preparing the profiles of S3D-V5 and the same thing happens to me, in V4 I had no problem in separating the lines that now does not allow me to separate, although this I have landazo the consultation to S3D also, but seen what seen I do not know how long it will take.
                Is it clear what is the new functionality of the echo command that I propose? Did I explain myself correctly?
                I hope you had a good holiday season and I wish you great achievements for this new year.
                Best regards
                Aitor
                undefined 1 Reply Last reply 10 Jan 2023, 08:52 Reply Quote 0
                  Aitor @Aitor
                  Good morning @DC42,
                  Sorry for the insistence, can you tell me if you see possible to implement this function of the echo command in a near version?
                  Or if it will be possible to do it?
                  Or if it is something impossible to do?
                  I would like to know, as we have many types of printers and I need to know if I should look for another alternative.
                  Best regards
                  Aitor
                  undefined 1 Reply Last reply 10 Jan 2023, 10:25 Reply Quote 0
                    @Aitor I have implemented this in the RRF 3.5 source code. So it should be available in RRF 3.5beta2. The use of echo >>>file ... will append to the file and not add a terminating newline, so you can use further echo commands to append to the same line. The final one should use echo >>file ... so as to include a newline.
                    undefined 1 Reply Last reply 11 Jan 2023, 08:31 Reply Quote 1
                      Aitor @dc42
                      Good morning @DC42,
                      Thank you very much, you don't know how glad I am to hear it, I'm looking forward to try beta2, I'll be preparing my codes to test it.
                      It's really wonderful to work with you
                      Best regards
                      Aitor
