    DuetLapse3
    Third-party software
    20
    296
    30.7k
    • chrishammundefined
      chrishamm administrators @T3P3Tony
      @T3P3Tony The DSF plugin service running as root installs them automatically. If the install process returns a non-zero return code, the plugin installation is aborted.
      Duet software engineer
      stuartofmtundefined 1 Reply Last reply Reply Quote 1
      • stuartofmtundefined
        stuartofmt @chrishamm
        @chrishamm
        This is good news! To be clear: sbcPythonDependencies attempts a python -m pip install xyz ?
        Also what's the difference between dfs-python and "regular" python? What python version is it based on ?
        Proschi3Dundefined Falcounetundefined 2 Replies Last reply Reply Quote 0
        • stuartofmtundefined stuartofmt referenced this topic
        • Proschi3Dundefined
          Proschi3D @stuartofmt
          I have a Raspberry Pi 4 and MPEG Streamer installed. Does anyone have clear instructions on how to install Duet laps 3? I can't get it to run 🙈
          or does anyone know Duet Motion https://www.makeit-3d.de/index.php/de/instrumente/duet-motion-zeitraffer-generator.html
          Love my Duet 3 Mini.
          https://www.instagram.com/proschi3d
          https://youtube.com/@proschi3d
          https://www.proschi3d.de
          stuartofmtundefined 1 Reply Last reply Reply Quote 0
          • Falcounetundefined
            Falcounet @stuartofmt
            @stuartofmt said in DuetLapse3:
            @chrishamm
            Actually, it depends on what you have in your /opt/dsf/conf/plugins.json
            it uses the commands defined by InstallPythonPackageCommand and with arguments defined by InstallPythonPackageArguments
            So it does, per default, /usr/bin/pip3 install {package}
            This means you can specify a specific version of a module if you need to, such as "sbcPythonDependencies": ["dsf-python>=3.4.5"]
            dsf-python is a module, it doesn't replace python and is based on the python version you have installed on your system.
            At the moment python 3.7 at least is required (that's the version installed on DuetPi image) but should work on higher versions.
              stuartofmt @Falcounet
              @Falcounet
              Thanks! I’ll be restarting efforts on a Duetlapse plug-in soon.
                stuartofmt @Proschi3D
                @Proschi78 said in DuetLapse3:
                Have you looked at the documentation here:
                https://github.com/stuartofmt/DuetLapse3/blob/main/Documents/DuetLapse3.md
                Also this:
                https://github.com/stuartofmt/DuetLapse3/blob/main/Documents/DuetLapse3 Useage Examples.md
                If you can give some insight into where you are at and what is stopping you from proceeding, we can help.
                It is relatively straightforward but there are lots of options. Only a few are needed to get started.
                Proschi3Dundefined 2 Replies Last reply Reply Quote 0
                  @stuartofmt first of all thank you very much for your offered help. I'll try again later and report back.
                  how can i start Lapse ?
                  pi@RepetierServer:~/Duetlapse $  python3 ./DuetLapse3.py -duet 192.168.178.91 -host 192.168.178.91 -port 8082 -pause yes -movehead 10 10
                  192.168.178.91 MainThread - ################### Options at start of this print job  #####################
                  192.168.178.91 MainThread - # Environment
                  192.168.178.91 MainThread - duet                 192.168.178.91
                  192.168.178.91 MainThread - basedir              /home/pi/Duetlapse
                  192.168.178.91 MainThread - poll                 12
                  192.168.178.91 MainThread - instances            single
                  192.168.178.91 MainThread - logtype              both
                  192.168.178.91 MainThread - nolog                False
                  192.168.178.91 MainThread - verbose              False
                  192.168.178.91 MainThread - host                 192.168.178.91
                  192.168.178.91 MainThread - port                 8082
                  192.168.178.91 MainThread - keeplogs             False
                  192.168.178.91 MainThread - novideo              False
                  192.168.178.91 MainThread - deletepics           False
                  192.168.178.91 MainThread - maxffmpeg            2
                  192.168.178.91 MainThread - keepfiles            False
                  192.168.178.91 MainThread - # Execution
                  192.168.178.91 MainThread - dontwait             False
                  192.168.178.91 MainThread - seconds              0
                  192.168.178.91 MainThread - detect               layer
                  192.168.178.91 MainThread - pause                yes
                  192.168.178.91 MainThread - movehead             [10.0, 10.0]
                  192.168.178.91 MainThread - rest                 1
                  192.168.178.91 MainThread - standby              False
                  192.168.178.91 MainThread - restart              False
                  192.168.178.91 MainThread - # Camera
                  192.168.178.91 MainThread -  camera1             usb
                  192.168.178.91 MainThread - camera2
                  192.168.178.91 MainThread - weburl1
                  192.168.178.91 MainThread - weburl2
                  192.168.178.91 MainThread - # Video
                  192.168.178.91 MainThread - extratime            0
                  192.168.178.91 MainThread - fps                  10
                  192.168.178.91 MainThread - minvideo             5
                  192.168.178.91 MainThread - # Overrides
                  192.168.178.91 MainThread - camparam1
                  192.168.178.91 MainThread - camparam2
                  192.168.178.91 MainThread - vidparam1
                  192.168.178.91 MainThread - vidparam2
                  192.168.178.91 MainThread - # UI
                  192.168.178.91 MainThread - hidebuttons          False
                  192.168.178.91 MainThread - # Special Functions
                  192.168.178.91 MainThread - execkey
                  192.168.178.91 MainThread - -----------------------------------------------------------------------
                  192.168.178.91 MainThread - Command Exception: fswebcam --version
                  192.168.178.91 MainThread - Command 'fswebcam --version' returned non-zero exit status 255.
                  192.168.178.91 MainThread - Module 'fswebcam' is required.
                  192.168.178.91 MainThread - Obtain via 'sudo apt install fswebcam'
                    @stuartofmt
                    Create time lapse video for Duet3D based printer. V4.1.0
                    optional arguments:
                      -h, --help            show this help message and exit
                      -duet DUET            Name of duet or ip address. Default = localhost
                      -poll POLL
                      -basedir BASEDIR      default = This program directory
                      -instances {single,oneip,many}
                                            Default = single
                      -logtype {console,file,both}
                                            Deprecated. Use -nolog
                      -nolog                Do not use log file
                      -verbose              Detailed output
                      -host HOST            The ip address this service listens on. Default = 0.0.0.0
                      -port PORT            Specify the port on which the server listens. Default = 0
                      -keeplogs             Does not delete logs.
                      -novideo              Does not create a video.
                      -deletepics           Deletes images on Terminate
                      -maxffmpeg MAXFFMPEG  Max instances of ffmpeg during video creation. Default = 2
                      -keepfiles            Dont delete files on startup or shutdown
                      -dontwait             Capture images immediately.
                      -seconds SECONDS
                      -detect {layer,pause,none}
                                            Trigger for capturing images. Default = layer
                      -pause {yes,no}       Park head before image capture. Default = no
                      -movehead MOVEHEAD MOVEHEAD
                                            Where to park head on pause, Default = 0,0
                      -rest REST            Delay before image capture after a pause. Default = 1
                      -standby              Wait for command to start.
                      -restart              Will restart when print finishes
                      -camera1 {usb,pi,web,stream,other}
                                            Mandatory Camera. Default = usb
                      -weburl1 WEBURL1      Url for Camera1 if web or stream
                      -camera2 {usb,pi,web,stream,other}
                                            Optional second camera. No Default
                      -weburl2 WEBURL2      Url for Camera2 if web or stream
                      -extratime EXTRATIME  Time to repeat last image, Default = 0
                      -minvideo MINVIDEO    Minimum video length, Default = 5
                      -camparam1 CAMPARAM1  Camera1 Capture overrides. Use -camparam1="parameters"
                      -camparam2 [CAMPARAM2 ...]
                                            Camera2 Capture overrides. Use -camparam2="parameters"
                      -vidparam1 VIDPARAM1  Camera1 Video overrides. Use -vidparam1="parameters"
                      -vidparam2 VIDPARAM2  Camera2 Video overrides. Use -vidparam2="parameters"
                      -fps FPS              Frames-per-second for video. Default = 10
                      -hidebuttons          Hides buttons not logically available.
                      -execkey EXECKEY      string to identify executable command
                    i installed everything.
                    when I start it as shown above this comes up
                      @Proschi78
                      When you say that you installed everything. Do you mean that you installed fswebcam?
                      How do you normally view the webcam i.e independently of DuetLapse ?
                      -host can normally be left out as that is the ip for the web interface to DuetLapse and the program will normally work it out itself.
                      Are you saying that the second image is what you see on the console when you try to start DuetLapse.? What is the command line you are using ? That output should only occur if there is an invalid option used and it would be reported. This looks like the output when -h is used
                      Please use -verbose until we get you running properly as the extra info can be very helpful.
                      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                        @stuartofmt i usually use mjpeg stream to see the camera in the DWC
                        I installed fswebcam.
                        but would like to use mjpeg streamer for that.
                        Then I only have to specify the printer ip when starting?
                        pi@RepetierServer:~/Duetlapse $  python3 ./DuetLapse3.py -duet 192.168.178.91 -pause yes -movehead 10 10
                          Ok - so there is a little confusion here - lets fix that 🙂
                          To get started, its best to use minimal options and make sure DuetLapse can "see" the webcam and your printer. Often the "hard" part is sorting out the camera connection since this can vary quite a lot from camera-to-camera.
                          Lets start with the camera:
                          You want to use mjpeg-streamer? That should be fine. (Shameless plug https://forum.duet3d.com/topic/23759/videostream)
                          Using mjpeg (or other) streamer: make sure its set up so that you can view the stream in your browser. What is that url ? you will use it below.
                          For DuetLapse:
                          The minimum options to start DuetLapse are:
                          - duet # the same ip address you would use for DWC
                          - port # this is the port number you want the DuetLapse http server to use
                          - basedir # not strictly necessary but best to include so as to not clutter the DuetLapse program folder
                          and of course (for now) add:
                          -verbose
                          Now you need some camera settings. Since you will be using a streaming url you do not want to specify usb. Instead try this (its what I do) 🙂
                          -weburl1 the url (that allows you to stream in browser
                          e.g. http://192.168.1.1:8081/mjpeg
                          -camera1 other
                          -camparam1= "'ffmpeg ' + ffmpegquiet + ' -y -i ' +weburl+ ' -vframes 1 ' +fn+debug" take careful note of spaces and " and '
                          When DuetLapse starts successfully: You will be able to access it locally using http://localhost:port where port was set with -port or you can access it locally or remotely with http://ip:port where ip is the ip address if the machine running DuetLapse (this is NOT set as an option).
                          Let me know how you get on.
                          BTW - I have a new / improved version coming out in the next few days. It simplifies things a bit by allowing the options to be placed in a configuration file and it has a much better UI. Once you are up and running the new version is just a file copy as it uses all the same config settings.
                            @stuartofmt no matter what I enter, it always comes up with this message
                            pi@RepetierServer:~/Duetlapse $ python3 DuetLapse3.py -duet 192.168.178.91
                            192.168.178.91 MainThread - host                 0.0.0.0
                            192.168.178.91 MainThread - port                 0
                            192.168.178.91 MainThread - pause                no
                            192.168.178.91 MainThread - movehead             [0.0, 0.0]
                              Proschi3D
                              pi@RepetierServer:~/Duetlapse $ python3 DuetLapse3.py -weburl1 http://192.168.178.70:8081/stream
                              localhost MainThread - ################### Options at start of this print job  #####################
                              localhost MainThread - # Environment
                              localhost MainThread - duet                 localhost
                              localhost MainThread - basedir              /home/pi/Duetlapse
                              localhost MainThread - poll                 12
                              localhost MainThread - instances            single
                              localhost MainThread - logtype              both
                              localhost MainThread - nolog                False
                              localhost MainThread - verbose              False
                              localhost MainThread - host                 0.0.0.0
                              localhost MainThread - port                 0
                              localhost MainThread - keeplogs             False
                              localhost MainThread - novideo              False
                              localhost MainThread - deletepics           False
                              localhost MainThread - maxffmpeg            2
                              localhost MainThread - keepfiles            False
                              localhost MainThread - # Execution
                              localhost MainThread - dontwait             False
                              localhost MainThread - seconds              0
                              localhost MainThread - detect               layer
                              localhost MainThread - pause                no
                              localhost MainThread - movehead             [0.0, 0.0]
                              localhost MainThread - rest                 1
                              localhost MainThread - standby              False
                              localhost MainThread - restart              False
                              localhost MainThread - # Camera
                              localhost MainThread -  camera1             usb
                              localhost MainThread - camera2
                              localhost MainThread - weburl1              http://192.168.178.70:8081/stream
                              localhost MainThread - weburl2
                              localhost MainThread - # Video
                              localhost MainThread - extratime            0
                              localhost MainThread - fps                  10
                              localhost MainThread - minvideo             5
                              localhost MainThread - # Overrides
                              localhost MainThread - camparam1
                              localhost MainThread - camparam2
                              localhost MainThread - vidparam1
                              localhost MainThread - vidparam2
                              localhost MainThread - # UI
                              localhost MainThread - hidebuttons          False
                              localhost MainThread - # Special Functions
                              localhost MainThread - execkey
                              localhost MainThread - -----------------------------------------------------------------------
                              localhost MainThread - Command Exception: fswebcam --version
                              localhost MainThread - Command 'fswebcam --version' returned non-zero exit status 255.
                              localhost MainThread - Module 'fswebcam' is required.
                              localhost MainThread - Obtain via 'sudo apt install fswebcam'
                                @Proschi78
                                In both cases you are still using -camera1 usb (either explicitly of by default). This forced the program to try and use fswebcam. In any case fswebcam does not appear the be installed.
                                In the second example you did not include all the options that I gave in the post above. Mandatory options like -duet and -port are missing, along with others. It cannot work given the command line input you used.
                                Does putting http://192.168.178.70:8081/stream in your browser (on the raspberry pi) display the camera stream ? Do this just to make sure there is no network issue e.g. the camera url is blocked).
                                If so - then the options I gave above should magically work 🙂
                                  @stuartofmt
                                  no such option: -d
                                  pi@RepetierServer:~/Duetlapse $ python3 -m pip -duet 192.168.178.91 -port 8025-verbose -weburl1 http://192.168.178.70:8081/?action=stream
                                  Usage:
                                    /usr/bin/python3 -m pip <command> [options]
                                  no such option: -d
                                    @Proschi78
                                    I'm not sure what you are trying to tell me here? pip is for installing python modules. Also - its best to answer / confirm the interim questions so that the person helping knows what you know. Again, you have not included the options I recommended. What you should be entering is this: Note that its all one line.(I recomend you copy/paste)
                                    python3 ./DuetLapse3.py -duet 192.168.178.91 -port 8025 -verbose -weburl1 http://192.168.178.70:8081/?action=stream -camera1 other -camparam1= "'ffmpeg ' + ffmpegquiet + ' -y -i ' +weburl+ ' -vframes 1 ' +fn+debug"
                                    Depending on whether you have installed the required python modules (it looks like you may have been) then there is no reason why this does not start properly provided (1) the ip address for -duet is correct and (2) -weburl1 when placed in a browser, displays the camera stream.
                                    P.S. you can also try this form. I prefer the one above because it sidesteps some possible issues with certain streaming cameras.
                                    python3 ./DuetLapse3.py -duet 192.168.178.91 -port 8025 -verbose -weburl1 http://192.168.178.70:8081/?action=stream -camera1 stream
                                      @stuartofmt ok the pip was the problem.
                                      thank you very much now I'm testing it.
                                      Duetlapse is now available in the browser
                                        @Proschi78
                                        Great !!
                                        If you like, you can try this version. I'm about to release it but have to update the documentation first. Its fully backward compatible and uses the same options. There are a few fixes but the main difference is the UI.
                                        All you need to do is replace the existing DuetLapse3.py file with this one (rename it first ).
                                        [DuetLapse3.py]
                                          @stuartofmt
                                          I tried again yesterday.
                                          in the browser I see Duetlapse.
                                          Duetlapse is also connected to the printer.
                                          I see the current layer, etc. only pictures are not made
                                          I will test the new version tonight.
                                          Thanks
                                            @stuartofmt
                                            no snapshot is taken
