Pneumatic Probe
I'm trying to set up a custom pneumatically controlled probe on my printer, and as far as I can tell it's basically going to function exactly like a bltouch, except instead of a servo it's a relay to deploy/retract. The problem I'm having is that the M401 and M402 commands aren't running deploy/retractprobe.g
Any ideas what I'm doing wrong?
; Configuration file for Duet 3 MB 6XD (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.15 on Fri Dec 09 2022 12:10:26 GMT-0600 (Central Standard Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P" MyPrinter" ; set printer name ; Wait a moment for the CAN expansion boards to start G4 S2 ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drive Setup M98 P"DefaultDriveSetup.g" ;Bed Leveling M671 X-405.7848:1541.3704:1541.3704:-405.7848 Y-226.27405:-226.27405:1472.34965:1472.34965 S1 P5 F1 ;Define Z screw X Y locations, max correction, pitch, fudge factor ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X1200 Y1200 Z1200 S0 ; set axis maxima ; Z-Probe ; servo pin defined in fan accessories section ; create servo pin for BLTouch M558 P9 C"0.io8.in" H5 F120:12 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X0:1200 Y0:1200 P10:10 ; define mesh grid ; Heaters M308 S0 P"0.temp0" Y"thermistor" A"Bed" T100000 B4725 C7.06e-8 ; configure bed sensor 0 as thermistor on pin temp0 M950 H0 C"0.out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang for bed and set pwm M140 P0 H0 S0 R0 ; bed heater 0 uses heater 0 M143 H0 S255 P0 T0 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S1 P"0.temp1" Y"thermistor" A"Chamber" T100000 B4725 C7.06e-8 ; configure chamber sensor 1 as thermistor on pin temp1 M950 H1 C"0.out1" T1 ; create chamber heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang for chamber and set pwm M141 P0 H1 S0 R0 ; chamber heater 1 uses heater 1 M143 H1 S255 P0 T1 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S2 P"3.spi.cs0" Y"rtd-max31865" A"Pulsar Top" ; configure pulsar sensor top as PT100 on pin spi.cs0 M950 H2 C"3.out6" T2 ; create pulsar heater output on out3 and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang for pulsar and set pwm M143 H2 S505 P0 T2 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S3 P"3.spi.cs1" Y"rtd-max31865" A"Pulsar Middle" ; configure pulsar sensor bottom as PT100 on pin spi.cs1 M950 H3 C"3.out7" T3 ; create pulsar heater output on out4 and map it to sensor 3 M307 H3 B0 S1.00 ; disable bang-bang for pulsar and set pwm M143 H3 S505 P0 T3 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S4 P"4.spi.cs0" Y"rtd-max31865" A"Pulsar Nozzle" ; configure pulsar sensor nozzle as PT100 on pin spi.cs0 M950 H4 C"4.out8" T4 ; create pulsar heater output on out0 and map it to sensor 4 M307 H4 B0 S1.00 ; disable bang-bang for pulsar and set pwm M143 H4 S505 P0 T4 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S5 P"3.temp0" Y"PT1000" A"Mosquito 1A" ; configure mosquito 1 sensor A as PT1000 on pin temp0 M950 H5 C"3.out0" T5 ; create mosquito heater output on out0 and map it to sensor 5 M307 H5 B0 S1.00 ; disable bang-bang for pulsar and set pwm M143 H5 S505 P0 T5 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition; M308 S6 P"3.temp1" Y"PT1000" A"Mosquito 1B" ; configure mosquito 1 sensor B as PT1000 on pin temp1; M950 H6 C"3.out1" T6 ; create mosquito heater output on out1 and map it to sensor 6 M307 H6 B0 S1.00 ; disable bang-bang for pulsar and set pwm M143 H6 S505 P0 T6 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S7 P"4.temp0" Y"PT1000" A"Mosquito 2A" ; configure mosquito 2 sensor A as PT1000 on pin temp2 M950 H7 C"4.out0" T7 ; create mosquito heater output on out2 and map it to sensor 7 M307 H7 B0 S1.00 ; disable bang-bang for pulsar and set pwm M143 H7 S505 P0 T7 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S8 P"4.temp1" Y"PT1000" A"Mosquito 2B" ; configure mosquito 2 sensor B as PT1000 on pin tem;p0 M950 H8 C"4.out1" T8 ; create mosquito heater output on out0 and map it to sensor 8 M307 H8 B0 S1.00 ; disable bang-bang for pulsar and set pwm M143 H8 S505 P0 T8 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition ; Accessories M950 F0 C"0.out7" ; create chassis fan 0 on relay M106 P0 S0 H-1 C"Chassis Fan" ; set fan 0 value, thermostatic control off M950 F1 C"0.out8" ; create chamber fan 1 on relay M106 P1 S0 H1 T30 C"Chamber Fan" ; set fan 1 value, thermostatic control from sensor 1 M950 F2 C"1.out0" ; create pulsar pc fan 2 M106 P2 S0 H-1 C"Pulsar PC Fan" ; set fan 2 value, thermostatic control off M950 F3 C"1.out1" ; create mosquito pc fan 3 M106 P3 S0 H-1 C"Mosquito PC Fan" ; set fan 3 value, thermostatic control off M950 F4 C"1.out2" ; create bed vac valve 1 M106 P4 S0 H-1 C"Vacuum Zone 1" ; set fan 5 value, thermostatic control off M950 F5 C"2.out0" ; create bed vac valve 2 M106 P5 S0 H-1 C"Vacuum Zone 2" ; set fan 5 value, thermostatic control off M950 F6 C"2.out1" ; create bed vac valve 3 M106 P6 S0 H-1 C"Vacuum Zone 3" ; set fan 5 value, thermostatic control off M950 F7 C"2.out2" ; create bed vac valve 4 M106 P7 S0 H-1 C"Vacuum Zone 4" ; set fan 5 value, thermostatic control off M950 F8 C"1.out3" ; create door locks on relay M106 P8 S0 H1 T65 C"Door Locks" ; set fan 5 value, thermostatic control on M950 F9 C"2.out4" ; create radiator on relay M106 P9 S0 H1 T30 C"Radiator Fans" ; set fan 8 value, thermostatic control on M950 F10 C"1.out4" ; create probe on relay M106 P10 S0 H-1 C"Probe Solenoid" ; Trigger Inputs M950 J0 C"1.io0.in" ; assign input j0 to 1.io0.in for right door lock status M581 P0 T0 S0 R1 ; configure external trigger, pin 0, trigger 0, active-inactive, during print M950 J1 C"1.io1.in" ; assign input j1 to 1.io1.in for left door lock status M581 P1 T1 S0 R1 ; configure external trigger, pin 1, trigger 1, active-inactive, during print M950 J2 C"1.io2.in" ; assign input j2 to 1.io2.in for front door lock status M581 P2 T2 S0 R1 ; configure external trigger, pin 2, trigger 2, active-inactive, during print M950 J3 C"1.io3.in" ; assign input j3 to 1.io3.in for right door open status M581 P3 T3 S0 R1 ; configure external trigger, pin 3, trigger 3, active-inactive, during print M950 J4 C"1.io4.in" ; assign input j4 to 1.io4.in for left door open status M581 P4 T4 S0 R1 ; configure external trigger, pin 4, trigger 4, active-inactive, during print M950 J5 C"1.io5.in" ; assign input j5 to 1.io5.in for front door open status M581 P5 T5 S0 R1 ; configure external trigger, pin 5, trigger 5, active-inactive, during print ;configure a trigger to control the venturi ; Tools M563 P0 S"Pulsar" D0 H2:3:4 F2 ; define tool 0 as pulsar, extruder 0, Heaters 2 3 4, Fan 2 G10 P0 R0 S0 ; set tool 0 active and standby temperatures to 0C G10 P0 X0 Y0 Z0 U0 V0 W0 ; set tool 0 axis offests M563 P1 S"Mosquito 1" D1 H5:6 F3 ; define tool 1 as Mosquito 1, extruder 1, Heaters 5 6, Fan 3 G10 P1 R0 S0 ; set tool 1 active and standby temperatures to 0C G10 P1 X0 Y0 Z0 U10 V0 W0 ; set tool 1 axis offests M563 P2 S"Mosquito 2" D2 H7:8 F3 ; define tool 2 as Mosquito 1, extruder 1, Heaters 7 8, Fan 3 G10 P2 R0 S0 ; set tool 2 active and standby temperatures to 0C G10 P2 X0 Y0 Z0 U0 V10 W0 ; set tool 2 axis offests ; Custom settings are not defined ; Miscellaneous T0 ; select first tool
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.3.15 on Fri Dec 09 2022 12:10:26 GMT-0600 (Central Standard Time) ;M280 P11 S10 ; deploy BLTouch M106 P10 S255
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.3.15 on Fri Dec 09 2022 12:10:26 GMT-0600 (Central Standard Time) ;M280 P11 S90 ; retract BLTouch M106 P10 S0
@p8blr probe type 9 (BLTouch) in M558 is special in that the probe in only deployed at the start of the probing move and it is retracted as soon as the probe makes contact. Perhaps you should use probe type 8 instead?
@dc42 That fixed it, thank you!
