    Where stores Macros?
    Firmware installation
    • peirofundefined
      peirof
      examining my SD card inserted in DUET, i have find the same macro (Name only the same) in /SYS and /MACROSS folder… and they are diferent.
      When i run a Macro, which runs?
      I must have the macro file in 2 directories? or can erase 1 file
      Why are duplicated?
      • Martin_Sundefined
        Martin_S
        Folder structure should be like this:
        https://duet3d.com/wiki/SD_card_folder_structure
        Macros must be inside the /MACROS folder. It's safe to delete the other one.
        But just in case, make a backup of the SD card before deleting anything.
        If it ain't broke, fix it till it is =)
          If you want your macros added to the Macros list in Duet Web Control and PanelDue, put them in the /macros folder. If you only intend to run them explicitly from within gcode files or other macros, put them in /sys instead.
