    wait for...
    Gcode meta commands
    350
    • MintyTreborundefined
      MintyTrebor
      M109 - eg in PrusaSlicer : M109 S[first_layer_temperature]
      M190 - eg in PrusaSlicer : M190 S[first_layer_bed_temperature]
      NodeDSF - Native Node-Red integration with Duet boards.
      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
      ReleaseMgr - Duet update info inside DWC.
      Repo
      tecnoundefined A Former User? 2 Replies Last reply Reply Quote 0
      • tecnoundefined
        tecno @MintyTrebor
        @MintyTrebor
        Thanks!
        I now have following in my start
        M104 S[first_layer_temperature] ; set extruder temp
        M140 S[first_layer_bed_temperature] ; set bed temp
        M190 S[first_layer_bed_temperature] ; wait for bed temp
        M109 S[first_layer_temperature] ; wait for extruder temp
          A Former User @MintyTrebor
          This post is deleted!
          tecnoundefined MintyTreborundefined 2 Replies Last reply Reply Quote 0
          • tecnoundefined
            tecno @A Former User
            @Herve_Smith
            Yes
              MintyTrebor @A Former User
              @Herve_Smith They are prusaslicer variables or as they call them placeholders.
              Repo
                A Former User @tecno
                  MintyTreborundefined 1 Reply Last reply Reply Quote 0
                    @Herve_Smith The syntax is described here
                    Repo
                      dc42 administrators @tecno
                      @tecno said in wait for...:
                      How do I setup following start gcode in slicer Prusa or Superslicer.
                      Have start to read temperature settings from gcodefile for bed and hotend and wait for temperatures to reach set values?
                      To wait for all temperatures to reach set values, use M116.
                      tecnoundefined 1 Reply Last reply Reply Quote 0
                      • tecnoundefined
                        tecno @dc42
                        So is this then correct?
                        M116
                        How about chamber temp if I want it to reach xC before start print?
                          @tecno there are multiple ways of doing it. M104, M140 and M141 set the hot end, bed and chamber temperatures respectively without waiting for them to reach temperature before proceeding to the next command. So they will all heat concurrently. Then you can use M116 to wait for them all to be reached:
                          M104 S225 ; set extruder temp
                          M140 S70 ; set bed temp
                          M141 S60 ; set chamber temp
                          M116 ; wait for all temps to be reached
                          Or if the hot end heats quickly but the bed and chamber heat slowly, you might want to do this instead:
                          M116 ; wait for bed and chamber temperatures to be reached before heating the hot end
                          You can substitute variables in [ ] for the actual values if the slicer supports that.
                          Using M104 followed by M109, or M140 followed by M190 is the old (Marlin) way of doing things.
