    Play with Input Shaping
    • samu_87undefined
      samu_87
      Hello I had install the accelerometer on my home made delta (R400 H500) printer:
      Now I'm trying to understand how it works, This is without filter:
      and this adding the filter that some testing I think have the better results:
      There is the movements:
      My questions are:
      1. Why the does the filter acts so little?
      2. What is damping factor?
      3. How can I do to make better results?
      Thansk!
        dc42 administrators @samu_87
        @samu_87 what M566 settings do you have for X and Y in config.g? High values make input shaping less effective. The default value of 600 works well on most machines.
        samu_87undefined 1 Reply Last reply Reply Quote 0
        • samu_87undefined
          samu_87 @dc42
          @dc42 i have X600 and Y600
          I add my config.g maybe it can be useful
          G90        ; Send absolute coordinates...
          M83        ; ...but relative extruder moves
          M665 R280.8 L515 B200 H574.800 X0.0 Y0.0 Z0.0							; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0.0 Y0.0 Z0.0 A0 B0        ; Put your endstop adjustments here, or let auto calibration find them
          M550 P"Delta"        ; Set machine name
          M551 P"NoPassword"        ; Set password
          M552 S1        ; Enable network
          M586 P0 S1        ; Enable HTTP
          M586 P1 S0        ; Disable FTP
          M586 P2 S0        ; Disable Telnet
          M569 P0 S1        ; Drive 0 goes forwards
          M569 P1 S1        ; Drive 1 goes forwards
          M569 P2 S1        ; Drive 2 goes forwards
          M569 P3 S1        ; Drive 3 goes forwards
          M584 X0 Y1 Z2 E3
          M350 X16 Y16 Z16 E16 I1        ; Configure microstepping without interpolation
          M92 X200.00 Y200.00 Z200.00 E432                               	                              	; Set steps per mm
          M566 X600 Y600 Z2800 E6000.00 P1                                               			; Set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E900.00                                                    	; Set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z3000.00 E5000.00                                                      	; Set accelerations (mm/s^2)
          M906 X1600.00 Y1600.00 Z1600.00 E1000.00 I30                                                    ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30        ; Set idle timeout
          M208 Z0 S1        ; Set minimum Z
          M574 X2 P"xstop" S1
          M574 Y2 P"ystop" S1
          M574 Z2 P"zstop" S1
          M558 P1 C"!zprobe.in" R0.4 F240 H5 T4800
          G31 X0 Y0 Z0.15 P500
          M557 R160 S40                                 ; Define mesh grid
          M308 S0 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e1temp
          M950 H0 C"e1heat" T0                          ; create bed heater output on e1heat and map it to sensor 0
          M307 H0 B1 S1.00                              ; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                       ; map heated bed to heater 0
          M143 H0 S120                                  ; set temperature limit for heater 0 to 120C
          M308 S1 P"spi.cs1" Y"rtd-max31865"            ; configure sensor 1 as PT100 on pin spi.cs1
          M950 H1 C"bedheat" T1                         ; create nozzle heater output on bedheat and map it to sensor 1
          M307 H1 B0 S1.00                              ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                  ; set temperature limit for heater 1 to 280C
          M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                ; set fan 0 value. Thermostatic control is turned off
          ;CPU Fan
          M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as on-chip MCU temperature sensor
          M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
          M106 P2 H3 T20:70 ; set fan 2 value
          M563 P0 S"tool1" H1 F0 D0						; define tool 1
          G10 P0 X0 Y0 Z0                               ; set tool 1 axis offsets
          G10 P0 R0 S0                                  ; set initial tool 1 active and standby temperatures to 0C
          M204 P1800
          M579 X1.004 Y1.01
          M591 D0 P1 C"e0stop" S1										;Sensore di Fine_Filo
          M572 D0 S0.05
          M955 P0 C"spi.cs4+spi.cs3" I20	;Accelerometer
          ;T0 ;Enable Extruder
          M501
