    FTP PWD issue
    Firmware wishlist
    551
    • AndMazundefined
      AndMaz
      Hi
      It seems that FTP server responds with an empty string when I cd into a dir then cdup back to parent dir and then execute pwd
      A proper response should include /. This issue breaks my FTP client
      Update I can also repro the issue in FileZilla. Here are the logs
      12:02:00	Status:	Logged in
      12:02:00	Status:	Retrieving directory listing...
      12:02:02	Status:	Directory listing of "/" successful
      12:02:06	Status:	Retrieving directory listing of "/backup"...
      12:02:09	Status:	Directory listing of "/backup" successful
      12:02:13	Status:	Retrieving directory listing of "/"...
      12:02:13	Command:	CWD /
      12:02:13	Response:	250 Directory successfully changed.
      12:02:13	Command:	PWD
      12:02:13	Response:	257 ""
      12:02:13	Error:	Server returned empty path.
        dc42 administrators @AndMaz
        @AndMaz thanks for reporting this. Can you point me to where in the FTP protocol specification it says that the response should be "/" ? I looked in RFC959 but didn't find it.
        AndMazundefined 1 Reply Last reply Reply Quote 0
        • AndMazundefined
          AndMaz @dc42
          @dc42 thanks you for quick answer.
          I can't point to exact place in RFC959 where it states that root is / but empty string as PWD doesn't seem to be correct. I mean, the working dir can't be empty. In Unix-like systems the root directory is denoted by the / sign.
          Initially I assumed that the problem came from my FTP client but the issue also happens in FileZilla, that implements all the FTP-related RFCs properly (at least I hope so)
            @AndMaz I've just tested FileZilla with two Duets:
            So it appears to be returning "/". Wireshark confirms this.
            Which version of RRF are you running?
            AndMazundefined 2 Replies Last reply Reply Quote 0
            • AndMazundefined
              AndMaz @dc42
              @dc42 I'm using 3.4.2.
              What version did you use during your tests?
              dc42undefined 2 Replies Last reply Reply Quote 0
                @AndMaz I am using 3.5beta but I don't think anything has changed in that area. I can re-test using 3.4.5 tomorrow,
                  @AndMaz I just tested it using 3.4.5 on one of the machines, and it still works.
                  • AndMazundefined
                    AndMaz @dc42
                    @dc42 thank you. I guess that I bumping firmware version will solve it
                    • AndMazundefined
                      AndMaz @dc42
                      @dc42 BTW in your tests did you cd into some dir then cdup? I'm asking this because the pwd right after connecting works properly, i.e., no bug
                        @AndMaz I managed to provoke this twice by doing CDUP and then selecting the root:
                        I will fix it in RRF 3.5beta3 and 3.4.6.
                        • AndMazundefined
                          AndMaz @dc42
                          @dc42 thank you for 🙂 https://github.com/Duet3D/RepRapFirmware/commit/f5fa23c3fd9eab9dc97cbefe317c3b0ee31cdf71
                          Unrelated Is is possible to add a recursiveDelete (default to false) to GET /rr_delete ? At the moment it's doesn't seem to be possible to remove a dir if it contains something inside. I would like to avoid overloading HTTP server with a bunch of delete reqs.
                          0 dc42 committed to Duet3D/RepRapFirmware
                          Fix for FTP change to root directory (included in 3.5beta2 release)
                          • T3P3Tonyundefined T3P3Tony moved this topic from General Discussion
                            T3P3Tony administrators @AndMaz
                            @AndMaz I have moved this to the firmware wishlist and that is a new feature.
                            • AndMazundefined
                              AndMaz @T3P3Tony
                              @T3P3Tony thank you. Do you want me to create a dedicated ticket for this?
                              (This started as a FTP issue but then ended with a HTTP feature request)
                                @AndMaz yes probably better if you do, with a descriptive title. Then you can make this thread as solved. thanks!
                                • AndMazundefined
                                  AndMaz @T3P3Tony
                                  @T3P3Tony don't know how to mark it as solved but here it goes
                                  Update The original issue is solved https://github.com/Duet3D/RepRapFirmware/commit/f5fa23c3fd9eab9dc97cbefe317c3b0ee31cdf71 and released in v3.5beta2 (Link https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-350beta2)
                                  • T3P3Tonyundefined T3P3Tony marked this topic as a question
                                  • T3P3Tonyundefined T3P3Tony has marked this topic as solved
