    Accelerometer causes Duet 2 Wifi to crash?
    404
    • kuhnikuehnastundefined
      kuhnikuehnast
      Hi there- I have a strange error:
      I connected an Accelerometer.
      As soon as I post a M956 command the Board "crashes" (nothing happens and after a few seconds the board reboots). I can also find the file created in the accelerometer folder but it is empty...?
      Any suggestions what I am doing wrong?
      greetings kuhni
        kuhnikuehnast
        Just tried the other duet board I own (a cartesian printer) - there a file is created with the message
        Sample,X,Y,Z
        Failed to collect data from accelerometer
        very strange...?
          kuhnikuehnast
          another strange behavior:
          I can adress the Accelerometer with the command:
          M955 P0 I46 C"spi.cs4+spi.cs3"
          but if I then want to change something and post the code again (e.g. to change the Frequency)
          M955 P0 I46 C"spi.cs4+spi.cs3" Q500000
          I get the error
          M955: Accelerometer not found on specified port
          is this normal? Do you have to reset the Board to "re-activate" the possibility to declare an M955 command?
            dc42 administrators @kuhnikuehnast
            @kuhnikuehnast I'm not sure why that is happening, however you don't need to repeat the M955 C parameter or I parameter when you just want to change the data collection parameters.
            If the board reboots unexpectedly, please run M122 as soon as DWC has reconnected, and post the output here.
              kuhnikuehnast
              tried it:
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later
              Board ID: 08DGM-9T6BU-FG3SN-6J9F2-3S46K-1UYRD
              Used output buffers: 1 of 26 (15 max)
              Static ram: 23860
              Dynamic ram: 76056 of which 168 recycled
              Never used RAM 9140, free system stack 186 words
              Tasks: NETWORK(notifyWait,9.1%,242) HEAT(notifyWait,0.0%,339) Move(notifyWait,0.0%,363) MAIN(running,81.8%,320) IDLE(ready,9.0%,30), total 100.0%
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:00:10 ago, cause: software
              Last software reset at 2023-02-16 18:00, reason: HeatTaskStuck, GCodes spinning, available RAM 7200, slot 1
              Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20018d84 Task ACCE Freestk 336 ok
              Stack: 0045d69d 0045d0f6 6100f000 00000000 0045d69d 2001871b 00000000 00000000 2001871b 2001871b 2000d334 200187e8 00000006 00000028 a5a5a5a5 00000001 0045d797 400a0000 00000001 200186f8 0045b02b 400a0000 00456cb3 0c000000 200186f8 00000007 00000007
              Error status: 0x00
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 32.7, current 33.3, max 33.5
              Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/24/24, gc cycles 0
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min n/a
              Driver 1: standstill, SG min n/a
              Driver 2: standstill, SG min n/a
              Driver 3: standstill, SG min n/a
              Driver 4: standstill, SG min n/a
              Driver 5:
              Driver 6:
              Driver 7:
              Driver 8:
              Driver 9:
              Driver 10:
              Driver 11:
              Date/time: 2023-02-16 18:00:29
              Cache data hit count 386562846
              Slowest loop: 11.66ms; fastest: 0.19ms
              === Storage ===
              Free file entries: 9
              SD card longest read time 0.9ms, write time 5.7ms, max retries 0
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty
              === Network ===
              Slowest loop: 37.22ms; fastest: 0.00ms
              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 1 of 8
              = WiFi =
              Network state is active
              WiFi firmware version 1.27
              WiFi MAC address 84:f3:eb:42:7a:a5
              WiFi Vcc 3.40, reset reason Power up
              WiFi flash size 4194304, free heap 25784
              WiFi IP address 192.168.178.80
              WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00002002
                @kuhnikuehnast I suspect that there may be a problem with the INT connection from the accelerometer to the Duet spi.cs3 pin.
                kuhnikuehnastundefined 2 Replies Last reply Reply Quote 0
                  kuhnikuehnast @dc42
                  @dc42 so what should I do? When i connect the same board (and cable) to the other board it "works" - as mentioned above... "failed to collect data"
                    kuhnikuehnast @dc42
                    I now tried something else:
                    • I switched the CS and INT1- Pin (so I declared the M955 to:
                      M955 P0 I46 C"spi.cs3+spi.cs4"
                      instead of
                    but as soon as I ran the code:
                    M956 P0 S1000 A0
                    I got another crash. In this time this was the M122:
                    Used output buffers: 1 of 26 (18 max)
                    Static ram: 23860
                    Never used RAM 9140, free system stack 184 words
                    Tasks: NETWORK(notifyWait,9.4%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,82.0%,320) IDLE(ready,8.6%,30), total 100.0%
                    Owned mutexes:
                    Last software reset at 2023-02-17 08:38, reason: HeatTaskStuck, GCodes spinning, available RAM 7200, slot 0
                    Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20018da4 Task ACCE Freestk 344 ok
                    Stack: 00435245 00435248 61000000 00000001 200186f8 00000001 0000002f a5a5a5a5 00000001 20004c60 00456cab 0c000000 20018dff 200186f8 00000007 00000010 00456cd5 0c000000 200186f8 00000007 00456f17 200186f8 c3000007 00000007 000003e8 2000119c 00456723
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    MCU temperature: min 23.5, current 24.2, max 24.5
                    Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 5:
                    Driver 6:
                    Driver 7:
                    Driver 8:
                    Driver 9:
                    Driver 10:
                    Driver 11:
                    Date/time: 2023-02-17 08:38:07
                    Cache data hit count 405364224
                    Slowest loop: 10.11ms; fastest: 0.19ms
                    === Storage ===
                    SD card longest read time 0.9ms, write time 5.9ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    Code queue is empty
                    === Network ===
                    Slowest loop: 37.57ms; fastest: 0.00ms
                    = WiFi =
                    WiFi flash size 4194304, free heap 22360
                    WiFi signal strength -54dBm, mode 802.11n, reconnections 0, sleep mode modem
                    Do you see something different? So is my Duet broken? Or how could I solve this problem?
                    Hope you can help me!
                    greetings kuhni
                    dc42undefined kuhnikuehnastundefined 2 Replies Last reply Reply Quote 0
                      @kuhnikuehnast it could be that writing to the SD card is taking too long. You could try a new SD card. Alternatively, reduce the number of samples you are collecting, for example to 500.
                      kuhnikuehnastundefined 1 Reply Last reply Reply Quote 0
                        kuhnikuehnast @dc42
                        @dc42 tried now only 10 samples by
                        M956 P0 S1000 A0
                        same crash... 😞
                        Used output buffers: 1 of 26 (16 max)
                        Static ram: 23860
                        Never used RAM 9140, free system stack 188 words
                        Tasks: NETWORK(ready,9.6%,242) HEAT(notifyWait,0.0%,329) Move(notifyWait,0.0%,363) MAIN(running,81.5%,320) IDLE(ready,8.8%,30), total 100.0%
                        Last software reset at 2023-02-17 17:11, reason: HeatTaskStuck, GCodes spinning, available RAM 7200, slot 2
                        Stack: 0045d69d 0045d0f6 6100f000 00000000 0045d69d 2001871b 00000000 400a0000 2001871b 2001871b 2000d334 200187e8 00000006 00000028 a5a5a5a5 00000001 0045d797 400a0000 00000001 200186f8 0045b02b 400a0000 00456cb3 0c000000 200186f8 00000007 00000007
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        MCU temperature: min 33.3, current 33.9, max 34.1
                        Driver 5:
                        Driver 6:
                        Driver 7:
                        Driver 8:
                        Driver 9:
                        Driver 10:
                        Driver 11:
                        Date/time: 2023-02-17 17:12:23
                        Cache data hit count 396566500
                        Slowest loop: 12.22ms; fastest: 0.19ms
                        === Storage ===
                        SD card longest read time 0.9ms, write time 3.9ms, max retries 0
                        === MainDDARing ===
                        === AuxDDARing ===
                        Segments left: 0
                        Code queue is empty
                        === Network ===
                        Slowest loop: 32.53ms; fastest: 0.00ms
                        = WiFi =
                        WiFi flash size 4194304, free heap 25384
                          kuhnikuehnast @kuhnikuehnast
                          @dc42 btw what is the biggest size possible for the SD-Card? So I'll get to grab a new one...
                          sorry, got it already- so I'm out now heading to a store to get a SanDisk Extreme Pro 32 GB mircoSD 😄 cross fingers for me that this will solve the problem!
                            I think I solved the problem:
                            • it wasn't the SD-card- but as I changed the cable and re-crimped an USB-3-cable everything now seems to work! 🙂
                            yihaaa 🙂
                            • Phaedruxundefined Phaedrux has marked this topic as solved
