    extruder config.g
    Firmware installation
    • joe92undefined
      joe92
      hello I'm almost done with my config and have only one problem. when i want to use the extruder z1 moves instead. i only have this error in connection with the extruder, otherwise g32 and g29 run without problems
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sat Feb 04 2023 18:22:06 GMT+0100 (Central European Standard Time)
      M575 P1 S1 B57600                                ; enable support for PanelDue
      G90                                              ; send absolute coordinates...
      M83                                              ; ...but relative extruder moves
      M550 P"Duet 3"                                   ; set printer name
      M669 K1                                          ; select CoreXY mode
      G4 S1   ;wait for expansion boards to start
      M569 P0.0 S0                                     ; physical drive 0.0 goes backwards
      M569 P0.1 S0                                     ; physical drive 0.1 goes backwards
      M569 P0.2 S1                                     ; Z1 goes goes forwards
      M569 P0.3 S0                                     ; Z2 goes goes backwards
      M569 P0.4 S1                                     ; Z3 goes goes backwards
      M569 P0.5 S0                                     ; Z4 goes goes forwards
      M569 P121.0 S1                                   ; physical drive 121.0 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E121.0           ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                          ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E420.00                ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00              ; set maximum instantaneous speed changes (mm/min)
      M203 X21000.00 Y21000.00 Z4000.00 E8000.00          ; set maximum speeds (mm/min)
      M201 X3600.00 Y3400.00 Z4000.00 E850.00           ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                     ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                          ; Set idle timeout
      M584 R0 X0 Y1 Z0.2:0.3:0.4:0.5 E2				 ; motor bindings
      M208 X0 Y-15 Z0 S1                                 ; set axis minima
      M208 X350 Y350 Z300 S0                           ; set axis maxima
      M574 X1 S1 P"121.io2.in"                     ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io2.in
      M574 Y1 S1 P"io1.in"                        ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
      M558 P8 C"^121.io0.in" H15 F500 T6000         ; set Z probe type to switch and the dive height + speeds
      G31 P1000 X0 Y0 Z6.190                          ; set Z probe trigger value, offset and trigger height
      M557 X55:295 Y30:270 S30	; S30 for high density, S40 for testing
      M671 X410:410:-60:-60 Y350:-80:-80:350 S20	; belts in all 4 corners
      M308 S0 P"temp0" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out1" T0                               ; create bed heater output on out1 and map it to sensor 0
      M307 H0 B0 S1.00                                 ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                          ; map heated bed to heater 0
      M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 121.temp0
      M950 H1 C"121.out0" T1                           ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                 ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                     ; set temperature limit for heater 1 to 280C
      M308 S2 P"temp1" Y"thermistor" T100000 B4138     ; configure sensor 2 as thermistor on pin temp1
      M950 H2 C"out3" T2                               ; create chamber heater output on out3 and map it to sensor 2
      M307 H2 B1 S1.00                                 ; enable bang-bang mode for the chamber heater and set PWM limit
      M141 H2                                          ; map chamber to heater 2
      M143 H2 S280                                     ; set temperature limit for heater 2 to 280C
      M950 F0 C"121.out1" Q500                         ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"121.out2" Q500                         ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 S1 H1:2 T45                              ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"out7" Q500                             ; create fan 2 on pin out7 and set its frequency
      M106 P2 S1 H1:2 T20                              ; set fan 2 value. Thermostatic control is turned on
      M950 F3 C"out8" Q500                             ; create fan 3 on pin out8 and set its frequency
      M106 P3 S1 H1:2 T20                              ; set fan 3 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                 ; define tool 0
      G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
      G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
      M150 x1 Q4000000
      M150 W255 P255 S10 F0
      ; Allow Movement of Axis that have not been homed
      M564 H0
      `; bed.g
      M561 ; Clear any existing bed transform
      G28 ; home
      M98 P"/macros/klickyprobe/klickyprobe_attach.g"
      ; Probe bed at these 4 points:
      G30 P0 X290 Y290 Z-99999
      G30 P1 X290 Y60 Z-99999
      G30 P2 X60 Y60 Z-99999
      G30 P3 X60 Y290 Z-99999 S4
      M98 P"/macros/klickyprobe/klickyprobe_dock.g"
      G28 Z ; Home Z Axis``
      • joe92undefined
        joe92
        m122
        RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (SBC mode)
        Board ID: 08DJM-9P63L-DJ3S0-7J1F8-3SD6N-TVJV9
        Used output buffers: 1 of 40 (20 max)
        Static ram: 152760
        Dynamic ram: 67196 of which 108 recycled
        Never used RAM 130608, free system stack 200 words
        Tasks: SBC(ready,0.6%,487) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.6%,91) MAIN(running,91.7%,923) IDLE(ready,0.1%,30), total 100.0%
        Owned mutexes: HTTP(MAIN)
        Last reset 00:14:25 ago, cause: power up
        Last software reset at 2023-02-19 21:08, reason: User, GCodes spinning, available RAM 130032, slot 1
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        Step timer max interval 133
        MCU temperature: min 28.1, current 33.2, max 35.1
        Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 0, mspos 8, reads 49775, writes 14 timeouts 0
        Driver 1: standstill, SG min 0, mspos 8, reads 49775, writes 14 timeouts 0
        Driver 2: standstill, SG min 0, mspos 8, reads 49775, writes 14 timeouts 0
        Driver 3: standstill, SG min 0, mspos 8, reads 49775, writes 14 timeouts 0
        Driver 4: standstill, SG min 0, mspos 8, reads 49776, writes 14 timeouts 0
        Driver 5: standstill, SG min 0, mspos 8, reads 49776, writes 14 timeouts 0
        Date/time: 2023-02-19 21:26:16
        Slowest loop: 2.33ms; fastest: 0.03ms
        === Storage ===
        Free file entries: 10
        DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        === AuxDDARing ===
        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
        Segments left: 0
        Movement lock held by null
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty
        === CAN ===
        Messages queued 7712, received 17045, lost 0, boc 0
        Longest wait 3ms for reply type 6053, peak Tx sync delay 7, free buffers 50 (min 49), ts 4326/4325/0
        Tx timeouts 0,0,0,0,0,0
        === SBC interface ===
        Transfer state: 5, failed transfers: 0, checksum errors: 0
        RX/TX seq numbers: 34142/34142
        SPI underruns 0, overruns 0
        State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2ad48
        Buffer RX/TX: 0/0-0, open files: 0
        === Duet Control Server ===
        Duet Control Server v3.4.5
        Code buffer space: 4096
        Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
        Full transfers per second: 34.76, max time between full transfers: 52.2ms, max pin wait times: 39.8ms/11.8ms
        Codes per second: 0.06
        Maximum length of RX/TX data transfers: 3032/588
        m122 b121
        Diagnostics for board 121:
        Duet TOOL1LC rev 1.1 or later firmware version 3.4.4 (2022-10-14 11:46:33)
        Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
        All averaging filters OK
        Never used RAM 2592, free system stack 88 words
        Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,3.0%,57) MAIN(running,91.9%,351) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
        Last reset 00:14:56 ago, cause: power up
        Last software reset data not available
        Driver 0: pos 0, 420.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 54923, writes 11, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
        Peak sync jitter -3/2, peak Rx sync delay 214, resyncs 0/0, no step interrupt scheduled
        VIN voltage: min 24.0, current 24.0, max 24.1
        MCU temperature: min 34.6C, current 35.1C, max 35.4C
        Last sensors broadcast 0x00000002 found 1 85 ticks ago, 0 ordering errs, loop time 0
        CAN messages queued 17692, send timeouts 0, received 8000, lost 0, free buffers 37, min 37, error reg 0
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
        Accelerometer: LIS3DH, status: 00
        I2C bus errors 0, naks 3, other errors 0
          You seem to have a stray M584 command that is overriding your first command and rebinding E to the second driver instead of the toolboard driver.
          • joe92undefined
            joe92
            Thanks. i missed it 👍
            • joe92undefined joe92 marked this topic as a question
            • Phaedruxundefined Phaedrux has marked this topic as solved
            • joe92undefined joe92 has marked this topic as unsolved
