    SD on DuetPanel does not read with accelerometer
    • Daniel 0undefined
      Daniel 0
      Hello, I have a problem with reading the SD card on PanelDue, after installing an accelerometer above the Thermocouple daughterboard, it no longer reads the SD card if I remove the cable, why does it work? Thank you
        dc42 administrators @Daniel 0
        @Daniel-0 it's because of the extra capacitance of the accelerometer cable, which uses the same SPI bus as the external SD card.
        Daniel 0undefined 1 Reply Last reply Reply Quote 0
        • Daniel 0undefined
          Daniel 0 @dc42
          @dc42 Isn't it possible to disable the use of the accelerometer via firmware so that I don't have to open the printer to plug-unplug when I have to use it?
            droftarts administrators @Daniel 0
            @Daniel-0 It's the cable itself that is causing the issue, not the accelerometer. There isn't really any other option other than disconnecting the accelerometer cable, at the Duet end, to stop signals bouncing up and down it and interfering, at least as I understand it.
