    3.4.5 wifi password bug - lower case only ?
    Firmware installation
    • c310undefined
      c310
      I have duetwifi 2 and it is not possible to use lower case letters in wifi password.
      on the router i have added configuration:
      SSID: D3D
      password d3dd3dd3d
      next is M587 S"D3D" P"d3dd3dd3d"
      this leads to
      Error: WiFi module reported: Timed out while trying to connect to D3D<LF>
      M587<LF>
      Remembered networks:<LF>
      D3D IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>
      however, if i change wifi password on the router to "D3DD3DD3D" and issue
      M587 S"D3D" P"D3DD3DD3D"
      i immediately get connected.
      M587<LF>
      ok<LF>
      WiFi module is connected to access point D3D, IP address 192.168.11.233<LF>
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2022-11-30 19:36:12<LF>
      I thought that is could be misconfigured terminal (pronterface), installed YAT with default settings and got same results.
      Is it a real bug, or there something wrong with my configuration?
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m587-add-wifi-host-network-to-remembered-list-or-list-remembered-networks
        Please read the notes on case sensitivity.
        c310undefined 1 Reply Last reply Reply Quote 0
        • c310undefined c310 has marked this topic as solved
        • c310undefined
          c310 @Phaedrux
          @Phaedrux thank you! resolved
