    Drive PWM laser using external mosfet module?
    Laser Cutters
    9
    14
    1.2k
    • Reefwarriorundefined
      Reefwarrior @o_lampe
      @o_lampe Can you perhaps advise as to how I should connect what? 🙂
      Reefwarriorundefined 1 Reply Last reply Reply Quote 0
        Reefwarrior @Reefwarrior
        So there are 3 connectors on the diode laser. + / - / TTL
        As soon as voltage is applied (12V) to + and -; the laser 'fires'.
        Can this thing be driven by the duet board? And if so, how?
          dc42 administrators @Reefwarrior
          @reefwarrior the TTL input is usually a PWM-capable input for controlling the laser. This can be driven directly from the LASER/VFD output of a Duet 3 (including Duet 3 Mini) or from a PWM output of a DueX board or Expansion Breakout board.
          If you have a Duet 2 without one of those expansion boards, then the recommended approach is to use a 74HCT02 gate to level-shift one of the expansion connector heater outputs. See the "Duet 2 Additional Hardware" tab at https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_laser for details. If you find that too hard then you can purchase the Expansion Breakout Board.
          Reefwarriorundefined Denisundefined 2 Replies Last reply Reply Quote 0
            Reefwarrior @dc42
            @dc42 Thank you for the help! 🙂
            • Reefwarriorundefined Reefwarrior has marked this topic as solved
            • SupraGuyundefined
              SupraGuy
              Very timely, as I was just looking for this information myself to drive a PWM laser from a Duet 2 Wifi.
              I ended up purchasing boards from JLCPCB.com, and they appear to have a minimum order quantity of 5 (And for some reason, it's cheaper to buy 15.) ... So I have 15 on the way, populated with the SMT components C1 and U2. It was a bit unclear as to which side H1 connected to. It looks like it should go on the bottom of the board, though I'm not sure which header it connects to. If it's on the expansion board, that could be a problem for me, and I might need to figure some other stuff out, but it appears to occupy pins 1-8 of the 50 pin expansion header.
              Anyway, I've got the boards on the way, and 8 pin headers coming separately. I'll probably just solder wire to the board for the DC in and laser out, since neither JLCPCB nor Digikey seemed to have appropriate connectors in stock when I looked.
              For what the extra cost, maybe I should have just bought a Duet 3 6HC instead.
              Lead screw driven printer, powered by Duet 2 Wifi
              MPCNC powered by Duet 2 Wifi
              CoreXY printer driven by Duet 3 6HC
              LowRider CNC powered by Duet 2 Wifi
              ktapperundefined 1 Reply Last reply Reply Quote 0
              • ktapperundefined
                ktapper @SupraGuy
                @supraguy You got any extra printed boards?
                • Denisundefined
                  Denis @dc42
                  @dc42 If my laser is 24 volts, can I connect to the PWM from the LASER/VFD output and power it from the 24v input or from the heater?
                    dc42 administrators @Denis
                    @Denis said in Drive PWM laser using external mosfet module?:
                    If the laser accepts a 5V or TTL level PWM input signal, then you can connect the LASER/VFD output to that and the laser power supply voltage is immaterial. Make sure that you have the Duet and laser grounds connected.
                    ollissundefined 1 Reply Last reply Reply Quote 0
                    • ollissundefined
                      olliss @dc42
                      @dc42 said in Drive PWM laser using external mosfet module?:
                      I had out9 connected to pwm. and the power for the laser connected to the out1 connector, because I wanted to turn the power on/off with it. I tested the laser and everything seemed to work fine until I realized that even though out1 is off my diode laser fan still runs.
                      Luckily nothing seems to have broken.
                      so did i understand correctly that i can't control the laser power directly from the duet board when i want to turn it on/off?
                      Maybe I should put a relay in between.
                        T3P3Tony administrators @olliss
                        @olliss the output connectors switch the ground side, not the power supply side so that wont work. you can put a external switch (like a relay, SSR etc) in between to turn off the power.
