    DSF Rockpi 4B Se on armbian
    DSF Development
    707
    • Amagatthundefined
      Amagatth
      hum ok error is here , on the rockpi documentation they say gpio 4 d5 is pin 157
      Amagatthundefined 1 Reply Last reply Reply Quote 0
      • Amagatthundefined
        Amagatth @Amagatth
        @Amagatth with pin 37 i have an error " operation failed ( reason : failed to initialize settings. object reference not set to an instance of an object "
        My config.json
        "AutoUpdateFirmware": true,
        "PluginSupport": true,
        "RootPluginSupport": false,
        "PluginsFilename": "/opt/dsf/conf/plugins.txt",
        "LogLevel": "info",
        "SocketDirectory": "/run/dsf",
        "SocketFile": "dcs.sock",
        "StartErrorFile": "/run/dsf/dcs.err",
        "Backlog": 4,
        "SocketPollInterval": 2000,
        "BaseDirectory": "/opt/dsf/sd",
        "PluginDirectory": "/opt/dsf/plugins",
        "NoTerminateOnReset": false,
        "HostUpdateInterval": 4000,
        "MaxMessageAge": 60,
        "SpiDevice": "/dev/spidev1.0",
        "SpiBufferSize": 8192,
        "SpiTransferMode": 0,
        "SpiFrequency": 8000000,
        "SpiConnectTimeout": 500,
        "SpiTransferTimeout": 500,
        "SpiConnectionTimeout": 4000,
        "MaxSpiRetries": 3,
        "GpioChipDevice": "/dev/gpiochip4",
        "TransferReadyPin": 37,
        "BufferedPrintCodes": 32,
        "BufferedMacroCodes": 16,
        "MaxBufferSpacePerChannel": 1536,
        "MaxCodeBufferSize": 256,
        "MaxMessageLength": 4096,
        "FirmwareComments": [
        "printing object",
        "MESH",
        "process",
        "stop printing object",
        "layer",
        "LAYER",
        "BEGIN_LAYER_OBJECT z=",
        "HEIGHT",
        "PRINTING",
        "REMAINING_TIME"
        "ModelUpdateInterval": 250,
        "MaxMachineModelLockTime": -1,
        "FileBufferSize": 8192,
        "FileInfoReadLimitHeader": 12288,
        "FileInfoReadLimitFooter": 262144,
        "MaxLayerHeight": 0.9,
        "LayerHeightFilters": [
        "Pattern": "^\slayer_height\D+(?<mm>(\d+\.?\d))",
        "Options": 17
        "Pattern": "Layer height\D+(?<mm>(\d+\.?\d*))",
        "Options": 17
        "Pattern": "layerHeight\D+(?<mm>(\d+\.?\d*))",
        "Options": 17
        "Pattern": "layer_thickness_mm\D+(?<mm>(\d+\.?\d*))",
        "Options": 17
        "Pattern": "layerThickness\D+(?<mm>(\d+\.?\d*))",
        "Options": 17
        "Pattern": "sliceHeight\D+(?<mm>(\d+\.?\d*))",
        "Options": 17
        "NumLayersFilters": [
        "Pattern": "NUM_LAYERS\D+(\d+)",
        "Options": 17
        "FilamentFilters": [
        "Pattern": "filament used\D+(((?<mm>\d+\.?\d*)\smm)(\D+)?)+",
        "Options": 17
        "Pattern": "filament used\D+(((?<m>\d+\.?\d
        )m([^m]|$))(\D+)?)+",
        "Options": 17
        "Pattern": "filament length\D+(((?<mm>\d+\.?\d*)\smm)(\D+)?)+",
        "Options": 17
        "Pattern": "filament used \[mm\]\D+((?<mm>\d+\.?\d
        )(\D+)?)+",
        "Options": 17
        "Pattern": "material\#(?<index>\d+)\D+(?<mm>\d+\.?\d*)",
        "Options": 17
        "Pattern": "Ext\s*\#\d+\D+(?<mm>\d+\.?\d*)",
        "Options": 17
        "Pattern": "Filament used per extruder:\r\n;\s*(?<name>.+)\s+=\s*(?<mm>[0-9.]+)",
        "Options": 17
        "Pattern": "filament used extruder (?<index>\d+) \(mm\) = (?<mm>\d+\.?\d*)",
        "Options": 17
        "GeneratedByFilters": [
        "Pattern": "generated by\s+(.+)",
        "Options": 17
        "Pattern": "Sliced by\s+(.+)",
        "Options": 17
        "Pattern": "(KISSlicer.)",
        "Options": 17
        "Pattern": "Sliced at:\s
        "Options": 17
        "Pattern": "Generated with\s*(.+)",
        "Options": 17
        "PrintTimeFilters": [
        "Pattern": "estimated printing time .= ((?<h>(\d+))h\s)?((?<m>(\d+))m\s*)?((?<s>(\d+))s)?",
        "Options": 17
        "Pattern": "TIME:(?<s>(\d+\.?\d*))",
        "Options": 17
        "Pattern": "Build Time:\s+((?<h>(\d+\.?\d*)) hour(s)?\s*)?((?<m>(\d+\.?\d*)) minute(s)?\s*)?((?<s>(\d+\.?\d*)) second(s)?)?",
        "Options": 17
        "Pattern": "print time:\s+(?<s>(\d+\.?\d*))(s)?",
        "Options": 17
        "Pattern": "Total estimated \(pre-cool\) minutes: ((?<m>\d+\.?\d*))",
        "Options": 17
        "Pattern": "total print time \(s\) = (?<s>(\d+\.?\d*))",
        "Options": 17
        "Pattern": "Build time:\s+(?<h>(\d+\.?\d*)):(?<m>(\d+\.?\d*)):(?<s>(\d+\.?\d*))",
        "Options": 17
        "SimulatedTimeFilters": [
        "Pattern": "Simulated print time\D+(?<s>(\d+\.?\d*))",
        "Options": 17
        Falcounetundefined 1 Reply Last reply Reply Quote 0
        • Falcounetundefined
          Falcounet @Amagatth
          @Amagatth Can you install gpiod and issue sudo gpioinfo ?
          Hopefully the device tree has the detailed info and you can just read it there.
          • Amagatthundefined
            Amagatth @Falcounet
            @Falcounet
            gpiochip4 - 32 lines:
            line 0: unnamed unused input active-high
            line 1: unnamed unused input active-high
            line 2: unnamed unused input active-high
            line 3: unnamed unused input active-high
            line 4: unnamed unused input active-high
            line 5: unnamed unused input active-high
            line 6: unnamed unused input active-high
            line 7: unnamed unused input active-high
            line 8: unnamed unused input active-high
            line 9: unnamed unused input active-high
            line 10: unnamed unused input active-high
            line 11: unnamed unused input active-high
            line 12: unnamed unused input active-high
            line 13: unnamed unused input active-high
            line 14: unnamed unused input active-high
            line 15: unnamed unused input active-high
            line 16: unnamed unused input active-high
            line 17: unnamed unused input active-high
            line 18: unnamed unused input active-high
            line 19: unnamed unused input active-high
            line 20: unnamed unused input active-high
            line 21: unnamed unused input active-high
            line 22: unnamed unused input active-high
            line 23: unnamed unused input active-high
            line 24: unnamed unused input active-high
            line 25: unnamed "vcc5v0-host-regulator" output active-high [used]
            line 26: unnamed unused input active-high
            line 27: unnamed unused output active-high
            line 28: unnamed unused input active-high
            line 29: unnamed unused input active-high
            line 30: unnamed unused input active-high
            line 31: unnamed unused input active-high
            cdfi@CDFI:~$
            you want the other gpiochip ?
              Falcounet @Amagatth
              @Amagatth
              GPIO4 has 32 lines so 37 is not valid.
              I made a mistake in the GPIO line calculation above. It should be 3 * 8 + 5 = 29
              Can you try :
              "TransferReadyPin": 29,
              Amagatthundefined 2 Replies Last reply Reply Quote 0
              • Amagatthundefined
                Amagatth @Falcounet
                @Falcounet Thx i try it monday
                • Amagatthundefined
                  Amagatth @Falcounet
                  @Falcounet Hi falcounet,
                  The error change now i have error like on the image !Screenshot from 2023-03-30 14-26-36.png
                  when i try tout boot duet control server i have an error and it dont want to start
                  i have it on the journaltcl
                  mars 25 12:52:28 CDFI systemd[1]: Starting Duet Web Server...
                  mars 25 12:52:31 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository[50] Using an in-memory repository. Keys will not be persisted to storage.
                  mars 25 12:52:31 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager[59] Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data >
                  mars 25 12:52:32 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager[58] Creating key {e2589570-6e22-48e4-bc7f-a96ff057bc2b} with creation date 2023-03-25 11:52:32Z, activat>
                  mars 25 12:52:32 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager[35] No XML encryptor configured. Key {e2589570-6e22-48e4-bc7f-a96ff057bc2b} may be persisted to storage >
                  mars 25 12:52:33 CDFI DuetWebServer[1548]: Microsoft.Hosting.Lifetime[14] Now listening on: http://[::]:80
                  mars 25 12:52:33 CDFI DuetWebServer[1548]: Microsoft.Hosting.Lifetime[0] Application started. Hosting environment: Production; Content root path: /opt/dsf/dwc
                  mars 25 12:52:33 CDFI systemd[1]: Started Duet Web Server.
                  mars 25 12:52:33 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:18:50 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:18:55 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:00 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:05 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:10 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:15 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:20 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:25 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:30 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:35 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:40 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:42 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/precache-manifest.f4a5c16fc7874f9aeeb60a854f6db5f3.js - -
                  mars 30 14:19:42 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/service-worker.js - -
                  mars 30 14:19:43 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware[2] Sending file. Request path: '/service-worker.js'. Physical path: '/opt/dsf/sd/www/service-worker.js'
                  mars 30 14:19:43 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware[2] Sending file. Request path: '/precache-manifest.f4a5c16fc7874f9aeeb60a854f6db5f3.js'. Physical path: '/opt/dsf/>
                  mars 30 14:19:43 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/precache-manifest.f4a5c16fc7874f9aeeb60a854f6db5f3.js - - - 200 1921 applicat>
                  mars 30 14:19:43 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/service-worker.js - - - 200 1069 application/javascript 370.1715ms
                  mars 30 14:19:45 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:45 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/img/icons/apple-touch-icon-152x152.png - -
                  mars 30 14:19:45 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware[2] Sending file. Request path: '/img/icons/apple-touch-icon-152x152.png'. Physical path: '/opt/dsf/sd/www/img/icon>
                  mars 30 14:19:45 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/img/icons/apple-touch-icon-152x152.png - - - 200 3608 image/png 50.3444ms
                  mars 30 14:19:50 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:54 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A53 - -
                  mars 30 14:19:54 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A53 - - - 404 0 - 9.7355ms
                  mars 30 14:19:54 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/service-worker.js - -
                  mars 30 14:19:54 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware[6] The file /service-worker.js was not modified
                  mars 30 14:19:54 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/service-worker.js - - - 304 - application/javascript 80.8443ms
                  mars 30 14:19:55 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
                  mars 30 14:19:56 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A56 - -
                  mars 30 14:19:56 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A56 - - - 404 0 - 4.8931ms
                  mars 30 14:19:57 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/machine/connect?password=reprap - -
                  mars 30 14:19:57 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.Connect (DuetWebServer)'
                  mars 30 14:19:57 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "Connect", controller = "Machine"}. Executing controller action with sig>
                  mars 30 14:19:57 CDFI DuetWebServer[1548]: DuetWebServer.Controllers.MachineController[0] [Connect] Failed to initialize settings: Object reference not set to an instance of an object.
                  mars 30 14:19:57 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Mvc.Infrastructure.ObjectResultExecutor[1] Executing ObjectResult, writing value of type 'System.String'.
                  mars 30 14:19:58 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Executed action DuetWebServer.Controllers.MachineController.Connect (DuetWebServer) in 214.1531ms
                  mars 30 14:19:58 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Executed endpoint 'DuetWebServer.Controllers.MachineController.Connect (DuetWebServer)'
                  mars 30 14:19:58 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/machine/connect?password=reprap - - - 503 - text/plain;+charset=utf-8 567.867>
                  mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A59 - -
                  mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A59 - - - 404 0 - 13.3461>
                  mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/machine/connect?password=reprap - -
                  mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.Connect (DuetWebServer)'
                  mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "Connect", controller = "Machine"}. Executing controller action with sig>
                  mars 30 14:19:59 CDFI DuetWebServer[1548]: DuetWebServer.Controllers.MachineController[0] [Connect] Failed to initialize settings: Object reference not set to an instance of an object.
                  mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Mvc.Infrastructure.ObjectResultExecutor[1] Executing ObjectResult, writing value of type 'System.String'.
                  Falcounetundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                    Falcounet @Amagatth
                    @Amagatth No idea if that error can be related to a SPI communication issue. Probably @chrishamm can comment
                    • chrishammundefined
                      chrishamm administrators @Amagatth
                      @Amagatth Sounds like you messed up something in the DCS settings. Try to delete the config.json file once (sudo rm /opt/dsf/conf/config.json), restart DCS (it should recreate it automatically), make the chip/pin/SPI adjustments again, and check if it works then.
                      Duet software engineer
                      • Amagatthundefined
                        Amagatth @chrishamm
                        @chrishamm It work !! thx !!!
                        • Amagatthundefined
                          Amagatth @chrishamm
                          @chrishamm hi , i have a new error 😕 spi reset always each second
                          Warning: SPI connection has been reset its the error message
                            Phaedrux Moderator @Amagatth
                            @Amagatth said in DSF Rockpi 4B Se on armbian:
                            Take a look here: https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#spi-connection-reset
