    duet3 6hc servo control
    • spllgundefined
      spllg
      hello,
      i'm thinking of creating a servo motor controlled part cooler.
      my question: (how) is it possible to configure (m563 ..) part cooling to use a servo motor like a part cooling fan?
      thanks for your answer.
      g.
        dc42 administrators @spllg
        @spllg the only way I can think of at present to do this would be to configure both the servo and a dummy fan using M950 commands, then have the daemon.g file run a loop that monitors the speed of the dummy fan and issues an appropriate M208 command to the servo when the fan speed changes.
        spllgundefined 1 Reply Last reply Reply Quote 0
        • spllgundefined
          spllg @dc42
          @dc42 thanks for your answer. i think i will write a little python-script to posprocess the g-code.
