    Home Assistant Integration
    Third-party software
    14
    47
    5.2k
    • nikschaundefined
      nikscha @Lyr3x
      @Lyr3x that did the trick, thanks!
      The integration is working well, can I do anything to test it for you?
      Stay in school
      Lyr3xundefined 2 Replies Last reply Reply Quote 0
      • Lyr3xundefined
        Lyr3x @nikscha
        @nikscha thanks πŸ™‚ will let you know! Of course if something is not working as intended don’t keep it to yourself.
        • Lyr3xundefined
          Lyr3x @nikscha
          Configflow is still giving me a headache. I need to refactor the code more to get this working properly.
          But I added a home assistant service to send gcodes:
          service: duet3d_printer.hevors_send_gcode
          data:
            gcode: G28
          Feedback appreciated!
          nikschaundefined 1 Reply Last reply Reply Quote 1
          • nikschaundefined
            nikscha @Lyr3x
            @Lyr3x Hmm now it doesn't work anymore^^
            I updated the integration though HACS, and after a restart the integration was gone from the integration panel. Didn't make any other changes. How can I debug this? Logs are empty too πŸ˜•
            Stay in school
            Lyr3xundefined 1 Reply Last reply Reply Quote 0
            • Lyr3xundefined
              Lyr3x @nikscha
              Edit: Alright, I just released a new version of the integration. ConfigFlow is now working as well as the service. The binary sensor is still dead. You need to remove the configuration from your configuration.yaml and just setup the integration via UI. I unfortunately need to ask you to reconfigure the Integration later again, because I want to attach the entities to a device. But its in a working mode now! Please do not hesitate with feedback.
              @nikscha Yep realized that as well, sorry. I decided to stop trying to patch the stuff I want to remove anyway and fix the config flow setup and remove the configuration.yaml code completely. I already have a working unpolished state. Bear with me a little more. Ill update you all here later!
              • nikschaundefined
                nikscha @Lyr3x
                @Lyr3x No worries! It's working now, config flow as well. I suggest naming the fields in the config flow. I tried doing this myself and creating a pull request but honestly I am just not that good at Python ^^
                I also tried making a textfield card to send typed Gcodes, but I also gave up and instead asked for help here
                I also tested some gcodes, most of them seem to work just fine but I noticed a strange delay when sending a M291 P"X" R"X" S3. This doesn't happen with S2, S1 or S0. Maybe this is intentional behaviour? Sending the same command from within DWC returns instantly though.
                Stay in school
                • Lyr3xundefined
                  Lyr3x @nikscha
                  @nikscha what do you mean with naming the fields? They all have labels
                  I’ll test the gcode tomorrow and see if I can find out what causes the delay!
                  nikschaundefined 1 Reply Last reply Reply Quote 0
                  • nikschaundefined
                    nikscha @Lyr3x
                    @Lyr3x The fields are prefilled, but it doesn't say what should be in there. This is what it looks like with the prefilled values removed: 4b9af3c0-5a02-49dc-b3d5-bad0a1dc0d38-image.png
                    What does the checkbox do for example?
                    Looking at the code I can figure out its the field "has_bed", and I think that should be mentioned in the config flow as well
                    Stay in school
                    • Lyr3xundefined
                      Lyr3x @nikscha
                      @nikscha Interesting. That is not what I see here
                      Did you remove the integration completely once?
                      Yeah, the checkbox is the check if you have a hotbed or not
                      • nikschaundefined
                        nikscha @Lyr3x
                        @Lyr3x Hmmmm πŸ€”
                        Not that I know of. Do you want me to test it?
                        Stay in school
                        Lyr3xundefined 1 Reply Last reply Reply Quote 1
                        • Lyr3xundefined
                          Lyr3x @nikscha
                          @nikscha Yep do that, maybe there is something cached from previous iterations. I tried that for you on a fresh local installation. Labels are working as intended πŸ‘
                          There is also no delay here with M291 P"X" R"X" S3 or any other GCode. It's exactly the same as with DWC πŸ™‚
                          • nikschaundefined
                            nikscha @Lyr3x
                            @Lyr3x That did the trick, the fields are now named.
                            The delay is still there tho.
                            Are you using a SBC?
                            Nvm I think I just communicated badly.
                            By "delay" I don't mean the time until the window pops up on DWC, but they time it takes HASS to aknowledge the service call. When calling
                            service: duet3d_printer.send_code
                            data:
                             gcode: M291 P"X" R"X" S3
                            from the service tab in dev tools, it takes about 5-10 seconds for the 'call service' button to turn green. This isn't the case with other gcodes.
                            Stay in school
                            • Lyr3xundefined
                              Lyr3x @nikscha
                              @nikscha said in Home Assistant Integration:
                              service: duet3d_printer.send_codedata: gcode: M291 P"X" R"X" S3
                              Ah gotcha. That is specific to the API call. It seems to be synchronous or it times out. If you press the OK button, the request is done. The integration does not validate the GCodes but just send them to the DSF API. If you make a similar call via curl you see the exact same behavior.
                              • nikschaundefined
                                nikscha @Lyr3x
                                @Lyr3x Yeah that makes sense
                                Stay in school
                                • Lyr3xundefined
                                  Lyr3x @nikscha
                                  Edit 4: With v0.1.1 standalone mode is fully supported and so are multiple tools. I also implemented proper setup to prevent duplicated integrations for the same board, so multiple integrations are support now as well.
                                  Edit 3: We are on v0.0.5 now. Added experimental standalone mode. Can’t test it because I am only using SBC.
                                  Edit 2: Released v0.0.2. All sensors are created properly and getting async status updates every 5 seconds. Ill follow up later to make the interval configurable and I also need to take another look at finishing up the setup when the printer becomes available later
                                  Edit 1: Introduced a bug in the version so that the state is not always updated properly. Working on it πŸ™‚
                                  Hey folks!
                                  I refactored quite a lot and we now have a proper integration between the DSF and Home Assistant. When you create the integration via ConfigFlow you have some options you can choose from, including the option to add an LED controller, which is handy if you have LED's connected to your Duet.
                                  The Device itself represents the physical Duet board and shows your correct model as well as the firmware version. All entities now have unique id's and should not conflict anymore. All sensors, binary sensors and the send_gcode service should work properly now πŸ™‚
                                  Keep in mind that if you have the integration already installed, you need to remove the integration once more and install it again. That is necessary, because I have rewritten the way of how entities are registered in Home Assistant.
                                  You'll find all infos here in the first release: https://github.com/Lyr3x/hass-Duet3D/releases/tag/v0.0.2
                                  @dc42 it would be nice if we can upload the Duet3D logo here: https://github.com/home-assistant/brands/pulls - we can use the logo then with this integration.
                                  I'll look for a better solution for the Position sensor soon.
                                  If you find any issues are need additional sensors, please create a GitHub issue from now on:
                                  https://github.com/Lyr3x/hass-Duet3D/issues
                                  I am also more then happy to accept PRs
                                  nikschaundefined 1 Reply Last reply Reply Quote 3
                                  • nikschaundefined
                                    nikscha @Lyr3x
                                    @Lyr3x Working well so far, many thanks for your efforts!! 😊 😊
                                    Stay in school
                                    • Lyr3xundefined
                                      Lyr3x
                                      Thanks, @T3P3Tony, for the support with the Logos. The integration now appears with a proper icon and the logo!
                                      Unfortunately, I was forced to update the DOMAIN object one last time, which results in the situation where everyone needs to re-install the integration completely. Sorry for that! Will try to avoid future breaking changes πŸ™
                                      deckingmanundefined 1 Reply Last reply Reply Quote 1
                                      • repier37undefined
                                        repier37
                                        Thanks @Lyr3x for your work.
                                        I have worked on porting the octoprint card to work with you integration.
                                        Anyone interested can check it out here : https://github.com/repier37/ha-duet-card/
                                        It has not been tested much besides on my setup, so feel free to report any issues.
                                        btw, @Lyr3x to make your integration work on my setup I had to add authentication. check the pull request if you like to integrate it.
                                          deckingman @Lyr3x
                                          @Lyr3x Firstly, thanks for your work on this integration which I have now added to my HA instance. I've also just added an ESP32 based "node" to control things like LED lights as well as monitoring humidity and a few other things. I use ESP Home so it's nice that I can have these sensor as well as the sensors from your integration all showing up on the same card.
                                          Some LED strip lights that I have installed will illuminate the lower part of my printer (Z travel is circa 600 mm). So what I'd like to do is set up an automation that will turn these lights on when the Z position is greater than (say) 200mm. What I'm unsure of is how to "extract" the Z position from the sensor.duet3d_position_x_y_z. I note that the state of this entity is in the format [n,n,n]. I can use entity state as a trigger for the automation but how would deal with the fact that it's the third value that I'm interested and the first two values are to be ignored? I've never had an entity with multiple state values so don't know how to deal with it.
                                            deckingman
                                            @Lyr3x Further to the above, I've found a "hack" that'll do for now but I'm sure there must be a more elegant solution. My hack is to create a template sensor to "extract" the Z position as follows.......
                                            - platform: template
                                              sensors:
                                                zpos:
                                                  friendly_name: "Zpos"
                                                  unit_of_measurement: "mm"
                                                  value_template: "{{states('sensor.duet3d_position_x_y_z') .split(',')[2].strip(']') |int}}"
                                            It isn't pretty but it works and will do the job for now. I can use this new "zpos" sensor in my automation to turn on certain lights when the bed is at 200mm or more below the nozzle (and turn them off again if it's above).
                                            • deckingmanundefined deckingman referenced this topic
