    Trouble with HTTP webcam
    Duet Web Control
    451
    • Notepadundefined
      Notepad
      Hi, I have a few reolink 510WA cameras and I was trying to set one up in the DWC as a monitor.
      I found the HTTP snapshot of the camera which is:
      'http://192.168.1.51:80/cgi-bin/api.cgi?cmd=Snap&channel=0&user=admin&password=111919'
      And I can successfully get individual snapshot images when putting the url into a web browser.
      I cannot unfortunately get it to show up in DWC and when I embed into an iFrame it just says refused to connect.
      Is there something I am missing?
      Any advice would be greatly appreciated as I was hoping to have this camera monitor a bank of printers.
      The real bamboo printer manufacturer
        DWC version?
        Notepadundefined 2 Replies Last reply Reply Quote 0
        • Notepadundefined
          Notepad @Phaedrux
          @Phaedrux
          Hi, the version is 3.4.5, Tho on a single machine we have is DWC 3.4.0 - I havent checked which machine DWC I was trying to update the webcam for.
          Also I just realised the G-Code directory button when you open .g files links to the dozuki page and not the new docs page. Is there a way for me to change this as clicking the button sends to a de-activeated webpage.
          • Notepadundefined
            Notepad @Phaedrux
            @Phaedrux
            Just doubled checked, The machine was running 3.4.0 - I have now updated it to 3.4.5 however the behaviour is identical.
            Notepadundefined 1 Reply Last reply Reply Quote 0
            • Notepadundefined
              Notepad @Notepad
              Bit of further digging, Using the f12 dev tools. I have a single error relating to the webcam component:
              Refused to display 'http://192.168.1.51/' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
              Unfortunately I am not savvy enough to know how to fix this, but it does seem like a clue
              • Notepadundefined
                Notepad @Notepad
                Bit of further digging, It looks like when I turn the Iframe option off I get this warning instead
                  dc42 administrators @Notepad
                  @Notepad I'm not an expert in this field, however it could be that you needs to allow cross-origin requests to the IP address of the webcam. See the C parameter in the M586 command https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m586-configure-network-protocols.
                  Notepadundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                  • Notepadundefined
                    Notepad @dc42
                    Thanks for the response, unfortunately it doesn't seem to have worked, but It could be how I am inputting the site data to the console. The following picture is all the combinations I have tried.
                    How does this look?
                    I also tried this: 41fc2dc9-a855-488d-bf67-f6cb9d45d54e-image.png
                    But it also hasn't worked.
                    Its annoying because it feels so close to getting it working but not close enough for it to actually work.
                      @Notepad I'll ask @chrishamm to take a look at this.
                      Notepadundefined 1 Reply Last reply Reply Quote 1
                      • Notepadundefined
                        Notepad @dc42
                        @dc42 Much appreciated
                        • chrishammundefined
                          chrishamm administrators @dc42
                          @dc42 @Notepad Setting the CORS site parameter on the Duet web server has no effect for other domains, only for those that want to access web resources from the Duet itself. You probably need to turn off CORS (CORB) on the IP webcam if it supports that. The other solution may be to disable CORS altogether in your browser, but I wouldn't recommend that as it can be a security risk.
                          Duet software engineer
