    Trying to get IDEX up and running, need help U3 not working
    1.6k
      Which firmware are you running? Use M115 to check. If it's 1.20beta8 then this is a known bug, in which case please upgrade to 1.20beta8+1.
      Please note, the single-quote character in your ssid will need to be sent as two single quote characters in the M587 command. This is because within a double-quoted string, one single-quote character means force the following character to lowercase.
      • ronnien59undefined
        ronnien59
        I am using the 1.20beta8+1.
        SENT: m115
        READ: FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20beta8+1 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-11-18
        READ: ok
        Not sure what you mean about the single quote. Do i need to do the following:
        M552 S0
        G4 P1000
        M587 S”Ronald”s Wi-Fi Network” P”lead9376”
        I have tried this and it still returns:
        SENT: M98 P/macros/SetNetwork
        READ: WiFi module started
        READ: M587: Bad or missing parameter
        READ: ok
          I think you may be using the wrong double-quote characters because the ones in your post are angled. Also, between the letter d and letter s you need two single quote characters, not one double quote. Like this:
          M587 S"Ronald''s Wi-Fi Network" P"lead9376"
          Cut and paste that line, and try it. I just tried it on one of my printers and it worked. When you send M587 without parameters to list remembered networks, you should see this:
          Ronald's Wi-Fi Network IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
            ronnien59
            Still not working. I will try again later. I may change my SSID to a simpler name and try again.
              Are you now using the correct double quote characters in your macro?
              You may find it easier to send the commands via USB from a terminal emulator program.
                ronnien59
                Yes i think that is the problem. I have just received my Duet ethernet and i am connected. I have everything homing but i cannot get the U axis to move once homed. Here is my config on my movement section.
                ; Movement section
                M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it)
                M569 P1 S0 ; Drive 1 goes forwards
                M569 P4 S0 ; Drive 4 goes forwards
                M569 P5 S1 ; Drive 5 goes forwards
                M584 X0 Y1 Z2 U5 E3:4 ; Create U axis for second X carriage before we try to configure it
                M574 X1 Y1 U1 Z0 S0 ; Set endstop configuration (X and Y endstops at low end, U endstop at high end, active high, no Z endstop)
                M906 X800 Y800 U800 Z800 E1000 ; Set motor currents (mA)
                M201 X800 Y800 U800 Z15 E1000 ; Accelerations (mm/s^2)
                M203 X15000 Y15000 U15000 Z100 E3600 ; Maximum speeds (mm/min)
                M566 X600 Y600 U600 Z30 E20 ; Maximum jerk speeds mm/minute
                M208 X280 Y304 U280 Z200 ; Set axis maxima (adjust to suit your machine)
                M208 X0 Y0 U0 Z-280 S1 ; Set axis minimum (adjust to make X=0 and Y=0 the edge of the bed)
                M92 X80.62 Y80.08 U80.62 Z400 ; Set axis steps/mm
                M92 E420:420 ; Set extruder steps per mm
                M350 X16 Y16 U16 Z16 E16 I1 ; Set 16x microstepping with interpolation
                G21 ; Work in millimetres
                G90 ; Send absolute coordinates…
                Am i missing something?
                  What driver are you using for the 6th driver (the U motor): the first driver on a DueX2 or DueX5, or something else?
                    ronnien59
                    it is on the DueX5
                      In this command:
                      you have specified U1 which means that the U endstop is at the low end of the U axis. However, the U endstop on an IDEX machine is normally at the high end. So use U2 in that command.
                        ronnien59
                        That has solved the problem. I can now start to calibrate. Thanks so very much for the help. I thought i had changed it and then changed it back for some reason.
