    Features menu
    Duet Web Control
    507
    • Auréundefined
      Auré @Phaedrux
      @Phaedrux said in Features menu:
      what screen size and resolution is the tablet?
      Screen size 10.1 and resolution 1280*800
      Reprap core XY, Ender 3 upgraded.
      If you keep trying, you'll eventually succeed. So: the more you fail, the more likely you are to succeed.
      A quote from Jacques Rouxel
        What DWC version is installed? Which firmware version?
        Auréundefined 1 Reply Last reply Reply Quote 0
        • Auréundefined
          Auré @Phaedrux
            I assume you're using an SBC. Beta 4 is out now, so you can try updating with sudo apt update and sudo apt upgrade and see if that makes a difference, otherwise it would be a question for @chrishamm on how the mobile view is flowing to that screen size.
            • Auréundefined
              Auré @Phaedrux
              @Phaedrux Yes I use a PI 3B+. I try to update tomorow for get the Beta 4. I have send a message at @chrishamm for this problem. When "display the computer version" is activate I can use the hotend features menu. But the size is a little lower, but it's possible pinch-to-zoom. For information my tablet run with Android 7.
              • Auréundefined
                Auré @Auré
                I have upgrade but the result is the same. So I continue with the computer version display on my tablet.
                • chrishammundefined
                  chrishamm administrators @Auré
                  @Auré The menu is now at the bottom provided that's what you mean by "Features". You can switch back to the traditional menu by going to Settings -> General and disable "Show bottom navigation" there.
                  Duet software engineer
                  • Auréundefined
                    Auré @chrishamm
                      @Auré It is available but not on all pages. It's been moved to a separate "Status" page in recent DWC versions.
                      • Auréundefined
                        Auré @chrishamm
                        @chrishamm Hi thanks you for your answer. Ok I see now. I don't understand why this menu been moved on mobile version, It's not possible to control all the axis, the hotend and the bed on the same page.
