    How to set up NC inductive z-probe in configurator?
    Firmware installation
    • 0nn0undefined
      0nn0
      I have some trouble understanding which type of probe to select for my z-probe setup in the RepRapFirmware Configuration Tool.
      I have a P+F 5V NPN inductive sensor with NC default state from RatRig which I would like to set up using the configurator tool.
      Which type of sensor do I select: Switch or Unmodulated?
      How can I set it up as an NC type of sensor using the configurator? Or is this only possible after uploading the firmware by editing the config files?
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @0nn0
        @0nn0 i wouldn't rely or worry about getting it right first time with the config tool.
        0nn0undefined 1 Reply Last reply Reply Quote 0
        • 0nn0undefined
          0nn0 @jay_s_uk
          @jay_s_uk
          So if I understand you correctly, it is more like a rough sketch then?
            jay_s_uk @0nn0
            @0nn0 yea, pretty much. be prepared to test each item and edit the config accordingly.
            Its so easy to edit the config through DWC. The config tool just gives you a starter for 10.
            Set you probe up as a switch for the moment
            0nn0undefined 1 Reply Last reply Reply Quote 1
            • 0nn0undefined 0nn0 has marked this topic as solved
            • 0nn0undefined
              0nn0 @jay_s_uk
              @jay_s_uk Thanks for the quick response
                dc42 administrators @0nn0
                @0nn0 on the Endstops page set it up as a Switch. On the IO Mapping page set up its input as active high.
                • 0nn0undefined
                  0nn0 @dc42
                  @dc42 Thanks for confirming this.
