    Made a mistake while upgrading, my system from 3.4.2 to 3.4.6
    Firmware installation
    • Schickfusundefined
      Schickfus
      Made mistake upgrading, my system from 3.4.2 to 3.4.6 on my Duet 3 MB6HC v1.01 (SBC mode).
      I can not do ssh so I hooked up a screen, keyboard and mouse. And made the upgrade.
      Then I went to my wifi connected notebook and wanted to check what had happened. To see if I could down load the config.g
      Made a M122 to see how far the installation had proceeded and by mistake I hit a M112.
      There was not a immediate shutdown so the upgrade proceeded but the firmware on the 1XD board and the MB6HC did not get installed. The installation stoped at 98%.
      I can't remember if I restarted the 1XD that could not have a firmware upgrade. But the installation ended.
      I made manual upgrade to 1XD
      M997 S0 to upgrade the main board
      Part of the M122 say that the 3.4.6 is installed
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.6 (2023-07-21 14:11:38) running on Duet 3 MB6HC v1.01 (SBC mode)
      Board ID: 08DJM-9P63L-DJ3T0-6J9FJ-3S86S-T80Z8
      Used output buffers: 1 of 40 (13 max)
      The printer runs. But I can't get the {state.time} to get updated. It is the same everytime my daemon.g echos it to the control.
      Is that enough? Or do I have to check other things to be upgraded?
      • chrishammundefined
        chrishamm administrators @Schickfus
        @Schickfus Can you confirm that you upgraded DSF as well? I cannot reproduce your problem on my setup with 3.4.6:
        Note that the 1-hour discrepancy is because I haven't updated the timezone on my SBC yet.
        Duet software engineer
        Schickfusundefined 1 Reply Last reply Reply Quote 0
          Schickfus @chrishamm
          @chrishamm
          Hi Chrishamm. How do I know how the DSF is installed correctly?
          /T
            Post the full output of M122.. The DSF version is near the end.
              Schickfus @Phaedrux
              @Phaedrux @chrishamm
              M122
              Static ram: 153252
              Dynamic ram: 66352 of which 0 recycled
              Never used RAM 128068, free system stack 130 words
              Tasks: SBC(ready,2014.0%,466) HEAT(notifyWait,9.4%,371) Move(notifyWait,1255.3%,214) CanReceiv(notifyWait,140.5%,773) CanSender(notifyWait,8.0%,327) CanClock(delaying,17.1%,344) TMC(notifyWait,23115.4%,90) MAIN(running,3453.6%,1231) IDLE(ready,29.3%,30), total 30042.6%
              Owned mutexes: HTTP(MAIN)
              Last reset 15:54:45 ago, cause: power up
              Last software reset at 2023-08-22 12:21, reason: User, GCodes spinning, available RAM 128036, slot 2
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
              Error status: 0x00
              Step timer max interval 136
              MCU temperature: min 33.3, current 39.0, max 53.9
              Supply voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 11.2, current 11.3, max 11.4, under voltage events: 0
              Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/870/854, gc cycles 2607
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min 0, mspos 8, reads 50647, writes 11 timeouts 0
              Driver 1: standstill, SG min 0, mspos 8, reads 50647, writes 11 timeouts 0
              Driver 2: standstill, SG min 0, mspos 8, reads 50647, writes 11 timeouts 0
              Driver 3: standstill, SG min 0, mspos 8, reads 50647, writes 11 timeouts 0
              Driver 4: standstill, SG min 0, mspos 8, reads 50647, writes 11 timeouts 0
              Driver 5: standstill, SG min 0, mspos 8, reads 50647, writes 11 timeouts 0
              Date/time: 2023-08-24 01:20:35
              Slowest loop: 61.41ms; fastest: 0.03ms
              === Storage ===
              Free file entries: 10
              DMs created 125, segments created 6, maxWait 1702072ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              Scheduled moves 4102, completed 4102, hiccups 0, stepErrors 0, LaErrors 0, Underruns [675, 0, 130], CDDA state -1
              === AuxDDARing ===
              Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
              Segments left: 0
              Movement lock held by null
              Telnet is idle in state(s) 0
              File* is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue* is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon* is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty
              === CAN ===
              Messages queued 428291, received 2749746, lost 0, boc 0
              Longest wait 2ms for reply type 6023, peak Tx sync delay 30891, free buffers 50 (min 45), ts 286427/286417/0
              Tx timeouts 0,0,9,0,0,0 last cancelled message type 30 dest 127
              === SBC interface ===
              Transfer state: 5, failed transfers: 0, checksum errors: 0
              RX/TX seq numbers: 63174/63174
              SPI underruns 0, overruns 0
              State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2ab5c
              Buffer RX/TX: 0/0-0, open files: 0
              === Duet Control Server ===
              Duet Control Server v3.4.6
              Code buffer space: 4096
              Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
              Full transfers per second: 38.50, max time between full transfers: 109.5ms, max pin wait times: 63.2ms/5.9ms
              Codes per second: 0.80
              Maximum length of RX/TX data transfers: 3676/1720
                @Schickfus That looks OK. Please share your daemon.g file as well and I'll try to reproduce your problem.
