    how to separate the tool fan from the part cooling fan
    Duet Web Control
    • Simoneundefined
      Simone
      im having a problem whit the part cooling fan controlling also the tool fan how i can separate the two
      so i can keep the tool fan always at 100%?
      the problem is my gcode or the settings of my system?
      Simoneundefined 1 Reply Last reply Reply Quote 0
      • Simoneundefined
        Simone @Simone
        the two seems linked togheder if i move the firts one the second does the same and vice versa.
          jay_s_uk @Simone
          @Simone the tool fan is the part cooling fan of the currently active tool and not the hot end cooling fan
            You can click on Change Visibility and hide one of them if you wish.
            • Phaedruxundefined Phaedrux has marked this topic as solved
